Forum Index : Microcontroller and PC projects : Picomite W
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
Hi, if, for any reason, we need to reconnect to WIFI/WLAN, what is the procedure for this? PICO W seams not to reconnect by itself, when WIFI (router etc) is down and comes back. Does PICO W always needs a reboot for this? Or can we try to reastablish a connection from runnimg Pico W? THX to all |
Try setting a watchdog in your program and OPTION AUTORUN ON. That is something I usually try and avoid but it is working well for me in my picoW experiments. It even manages to reconnect to my Fritz!Box which needs two attempts to get an IP address. Jim VK7JH MMedit |
Hello Jim, nice to hear that hopefully well soldered Fritz!Boxes also work Down Under ;-) Thank you for your Answer and this workaround. Absolut acceptable regarding Peters efforts and progress of Pico W mmbasic. Greetings from DE |
