Local Time 18:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Memory loss
PhilP
Posted: 10:26am 21 Feb 2023
I have been using Micromites (MM170 and MM470) for a long time. My weather station using an MM470 has been working well for years.  I now want to change the program but somehow have lost the source file on an old PC. Of course I can see the program via EDIT and can cut and paste screen full of code into Notepad however this is very tedious and error prone for a large program.
I think I recall a way to transfer the program from the MM into a file on the PC. I have tried Tera Term using XMODEM>RECEIVE but nothing happens. I uploaded the original large program using MMedit (v3.6.9 ver5.01) making use of the auto-crunch so remarks are gone. Can anyone jog my simple brain please?
Posted: 10:35am 21 Feb 2023
You probably first have to start XMODEM SEND on the MM.
Posted: 10:51am 21 Feb 2023
In Teraterm, under file, start logging
then LIST ALL
then close the log and you have your program (without things that were crunched out).
If your version of MMBasic doesn't do LIST ALL, you will have to press a key for every page then edit out the press any key lines.
Posted: 04:37am 22 Feb 2023
If it has an SD card(or you can hook one up) MM+ manual p20, 21
"SAVE fname$
Save the current program to the SD card."
PhilP
Posted: 10:17am 23 Feb 2023
Thanks for both suggestions gents which I have got around to trying and they both work. I stumbled a bit about having to add quotes around the filename$. Of the SD card will only work for a MM+ but the Tera Term should also work for a MM170.
