Local Time 20:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 1-Wire Comms - First time user...
Zonker
Posted: 04:35pm 21 Feb 2023
Good morning gents...
I have a small project I want to do getting data from a DS28EA00 Thermometer IC monitoring the temp of a PCB here at work... I tried to upload the 1.09 meg PDF file for the IC, but the up-loader says it's to big... I am using the R pi pico waveshare LCD 0.96 board to do the programming on, with version 5.07.06 firmware installed... There is only one IC connected so I am using the "skip ROM" (&hCC) command to get access to the commands...
The commands I am using are
Convert Temp (&h44), and Read Scratchpad (&hBE)
I have a scope connected to the data line and am seeing the reset and data...
OneWire write GP27,1,2,&hCC,&h44 'send skip ROM & Convert temp command (reset before)
PAUSE 1000 ' 750ms for a 12 bit convert
OneWire write gp27,1,2,&hCC,&hBE 'send skip ROM & Read Scratchpad memory (reset before)
OneWire read gp27,2,2,temp_lsb,temp_msb 'get the temp data (reset after)
The chip seems to be sending the data back but how do I properly capture it using the OneWire read command..?? After sending the read scratchpad memory command, the chip sends the data immediately and I don't think I am getting the correct data back...
Was hoping to find a 1-wire expert out here for some advice...
Thanks in advance for any help with this..!!
Posted: 04:58pm 21 Feb 2023
You could post a link to the PDF.
There are some rather old (ca-2020 etc) posts which might help, including some code (e.g. by Chopperp).
Maybe more on fruitoftheshed?
Zonker
Posted: 05:57pm 21 Feb 2023
Thanks John...
I will take a look around and see if I can find more on this...
Thanks for your help...
Posted: 08:19pm 21 Feb 2023
I was playing around with one-wire on the pico some time ago.
I came to the conclusion that the time between the write and following read is too long.
I did not follow on with the investigation unfortunately.
Can you try running the pico at maximum speed.
Posted: 09:45pm 21 Feb 2023
It might sound silly, but have you tried treating as a DS18B20?
Use the TEMPR function and see what happens.
Posted: 11:13pm 21 Feb 2023
Watching this thread with MUCH interest, as I am about to start playing with the DS28E07 memory IC on the 1-wire bus, but I will likely start my own thread on that - unless everything works and I have no issues, but I expect there might be some, as I too have never used the 1-wire commands.
Posted: 08:35am 22 Feb 2023
If it's not fast enough going from Write to Read maybe a WriteAndRead is needed?
Zonker
Posted: 02:36am 23 Feb 2023
Evening Gents...
As it turns out, Tassy Jim was spot on... I took a look at both PDF data sheets and except for the I/O, they work the same protocol... Worked like a champ...
I do think we need to figure out how to make the 1-wire functions work right... Maybe they do work right and I just don't know how to get an example working correctly... I think I saw the part answering the Read Scratchpad command before I could get the One wire read function called... I think it was causing the garbled data I was getting..  (not sure)...
Anyway, I think we should be able to connect more 1-wire ICs and figure out how to use the code... It would be awesome to have an easy function to handle the search & serial # handling too.. With 1 MPU I/O line you could make multi device nets...
I might buy some interesting 1-wire ICs and do some tinker...
Thanks...
