Forum Index : Microcontroller and PC projects : MMBasic Maze Generator
| JesseW Newbie Joined: 12/02/2023 Location: United StatesPosts: 4 |
I hope this is the place to post mmbasic code. If it isn't, pls let me know... This is my first mmbasic program. Maze generators have been around forever. But this one is really nice looking. It kinda resembles a waffle forming, then morphing into the maze. It uses the age-old algorithm of randomly seeking new cells then backing out when it gets cornered until it can see new cells again, then continues. This is version 1, which simply creates the maze in a 2 dimensional array while displaying it's progress on the screen as it goes. In Mode 1 it takes just under 15 seconds and in Mode 2 it's done in just under 4 seconds. If I continue with this, I will add a maze browser that lets you travel the maze from the inside, using rudimentary 3d drawing techniques. In any case, I hope you enjoy it. ' WarSOFT Maze Generator v1 ' by Jesse Warford ' (c) 2023 WarSOFT Apps ' ' This is version 1 that just creates an integer array in memory and displays ' a maze on the screen. A future version may allow traversing the maze from ' the inside using crude 3D ' Option Explicit Option Base 0 Option Default Integer Randomize Timer MODE 1 'will also work with mode 2 as-is with no other alterations ' general purpose Dim i, n ' directions Dim dx(3) = (0, 1, 0, -1), dy(3) = (-1, 0, 1, 0) ' screen resolution cut into cells Dim csiz = 10, hsiz = 5 '8x8px cell plus 1px border, half size Dim hr = MM.HRes / csiz, vr = MM.VRes / csiz '#cells horiz & vert ' def & init maze area ' --------------------- ' bits: 0 (001-01) - from dir lo bit ' 1 (002-02) - from dir hi bit ' 2 (004-04) - up this cell is open going up ' 3 (008-08) - right " ' 4 (016-10) - down " ' 5 (032-20) - left " ' 6 (064-40) - visited - already visited during maze generation ' 7 (128-80) - (reserved) ' -------------------- ' mask - const &hff or 255, used for clearing bits ' bs.fdir - the direction taken to get to this cell, ie. "from" dir ' bs() - Bit Set (from) direction array ' bz() - bit set (to) direction array ' br.fdir - used for clearing direction bit. not used yet... ' br() - Bit Reset (or bit clear) direction array ' -------------------- Dim mask = &hff 'used for clearing bits, but not used yet... ' def bit SET vars - <OR> Dim bs.fdir = &h03 Dim bs(3) = (&h04, &h08, &h10, &h20) Dim bz(3) = (bs(2), bs(3), bs(0), bs(1)) Dim bs.visited = &h40 ' def bit RESET vars - <AND> Dim br.fdir = mask - bs.fdir Dim br(3) = (mask - bs(0), mask - bs(1), mask - bs(2), mask - bs(3)) Dim br.visited = mask - bs.visited Dim maze(hr, vr) For i = 0 To hr - 1 For n = 0 To vr - 1 maze(i, n) = 0 'init all cells as unvisited and untested Next n Next i ' maze generation init Dim sx = Fix(Rnd * hr), sy = Fix(Rnd * vr) 'starting position Dim x = sx, y = sy 'set current position Dim nx, ny 'new position to test Dim d, od, dd 'current and old direction maze(x, y) = bs.visited 'set starting cell as visited Box x * csiz, y * csiz, csiz, csiz 'draw starting cell empty ' test border cells of current cell for unvisited Do d = Fix(Rnd * 4) 'choose random direction od = d 'remember starting dir dd = Fix(Rnd * 2) 'dd = test dir: clockwise If dd = 0 Then dd = -1 ' or counter-clockwise Do nx = x + dx(d) 'new cell coords based on ny = y + dy(d) ' current direction If nx >= 0 And nx < hr And ny >= 0 And ny < vr Then 'ck for out of bounds If (maze(nx, ny) And bs.visited) = 0 Then 'ck visited flag maze(x, y) = maze(x, y) Or bs(d) 'set move to dir in from cell x = nx:y = ny 'update current pos maze(x, y) = maze(x, y) Or d 'set dir used to get here maze(x, y) = maze(x, y) Or bz(d) 'set move from dir in to cell maze(x, y) = maze(x, y) Or bs.visited 'set visited flag Box x * csiz, y * csiz, csiz, csiz 'draw current cell empty d = -1 'so backup doesn't trip Exit 'exit test new dir loop EndIf EndIf d = d + dd 'if the last test dir cell was visited, try next dir If d = 4 Then 'increment or decrement direction d = 0 'using round-robin ElseIf d = -1 Then 'try both clockwise and counter-clockwise to keep d = 3 ' the maze from always drawing around the edge EndIf Loop Until d = od 'keep going till all directions have been tried If d = od Then 'if all are visited, it's a dead end, so backup d = maze(x, y) And bs.fdir 'get direction to go backwards (from) x = x - dx(d):y = y - dy(d) 'set new cell coords w/new dir's nx = x * csiz + hsiz * dx(d) + 1 'erase breadcrumb by drawing an ny = y * csiz + hsiz * dy(d) + 1 ' empty box w/no borders, erasing Box nx, ny, csiz - 2, csiz - 2, 1, 0, 0 ' the cells merged borders EndIf Loop Until x = sx And y = sy 'keep going and backing up ' till returned to start Dim a$ Do While a$="" a$=Inkey$ Loop Run |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 693 |
Hi Jesse, I have tried your maze generator. I find it sufficiently complex in mode 2 :-) But how do I recognize the entry or exit or start/end to search the way? Otherwise, I do not quite understand the sense. An S for start or E for end would be helpful for marking. Matthias |
this version wasn't intended to be "playable", only a demonstration of the techniques used to create it, mainly visual, as the coding techniques have been around for ages. If you wish to solve it, feel free to add a starting and ending point. thx for the feedback! jesse |
Nice! Comment out the line "Randomize Timer" and it runs perfectly on a CMM2. My 3D maze engine from "Escape to the Green Hills of Earth" unfortunately doesn't understand mazes with thin walls so it can't display the first person view. Maybe I must make changes... Visit Vegipete's *Mite Library for cool programs. |
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 723 |
I wish the RANDOMIZE command hadn't been removed from CMM2. Sometimes you want to seed the RNG with a known value for testing. Using RANDOMIZE with a constant would have allowed that when used in conjunction with an algorithm for generating pseudo-random numbers. Using a true RNG doesn't allow setting a known environment. |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4380 |
I suppose work around it using your own functions. John |
See the colour maximite 2 manual page 54 |
You might also want to look at my program "Amazin". It creates mazes using depth-first recursive descent and then solves them. You can find a link from CMM2.FUN. -Bill |
