Local Time 17:12 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I felt the need to collect some notes on the PICOMITEWEB
pwillard
Posted: 03:06pm 28 Feb 2023
I found that I was jumping around the forum to make sure I was using the PICOMITEWEB correctly. Hence, I put together some notes and assembled them into an Interim Addendum until Pete and Geoff officially get around to adding some additional info to the PICOMITE documentation.  Corrections and reprimands are welcome.
So here it is.  Small Book
Posted: 03:42pm 28 Feb 2023
atmega8
Posted: 05:29pm 28 Feb 2023
Very usefull, thank you!
Wasn't there an mm.info (ipaddress) or similar?
Could you please under:
Creating A TCP Server
explain how to deal with:
web transmit [PAGE/FILE/CODE] req%, ........
and show a simple "Hello World answer" from the TCP Server,
that will show up, if i access the Picow with Browser?
How does, and what belong together?
That's one small step for you man, one giant leap for mankind (me).
Edited 2023-03-01 03:32 by atmega8
pwillard
Posted: 05:54pm 28 Feb 2023
Might I state that I collected this information and assembled it into a document so I could have it readily available... not because I'm *good* at this stuff yet. Being good at it is where I'm trying to end up.
Edited 2023-03-01 03:55 by pwillard
atmega8
Usefull for your Docu
found it:
? MM.INFO(ip address)
also usefull maybe:
print mm.info(mac address)
Off course an arp -a from the client side will also do the Job;-)
192.168.178.37        28-cd-c1-09-e3-80     dynamisch
Edited 2023-03-01 03:58 by atmega8
pwillard
Posted: 05:59pm 28 Feb 2023
I don't think mm.info(mac address) is a thing.
Also, keep in mind that I'm not trying to duplicate work being done by LucV, who is creating a HOW TO set of documents.
Edited 2023-03-01 04:33 by pwillard
LucV
Posted: 06:48pm 28 Feb 2023
Hi there,
@atmega8
Look at the thread with the name PicoMiteWeb lessons.
Chapter 3 and 4 cover building your first web server.
More chapters coming up.
Luc
Luc's tech Blog
Posted: 07:55pm 28 Feb 2023
mm.info (ip address) gives the pico's address, I think he was after the IP of the connected client. That is something I would like very much.
atmega8
Posted: 09:45pm 28 Feb 2023
  LucV said  Hi there,
@atmega8
Luc
Thank you Luc,
easy to understand.
Go on with your Lessons!
Dietmar
atmega8
Posted: 09:47pm 28 Feb 2023
  pwillard said  I don't think mm.info(mac address) is a thing.
Ok, makes sense.
THX
atmega8
Posted: 09:48pm 28 Feb 2023
Ok, makes sense.
THX
Posted: 04:45am 01 Mar 2023
That little book really is excellent work.
You're a    pwillard!
pwillard
Posted: 11:51am 01 Mar 2023
Thanks...
Note: I am still making edits to the file... so use the link in the original post to get the updated version.
bigfix
Posted: 12:30pm 01 Mar 2023
Great job !
Please put a version number or date on the front page
So we can distinguish updated versions
pwillard
Posted: 01:36pm 01 Mar 2023
Good idea... done.
pwillard
Posted: 12:17pm 09 Mar 2023
Updated... with NTP info
dgrissom
Posted: 11:19pm 10 Mar 2023
First, thanks to everyone's efforts on
I'm kind of a neophyte with PicomiteWEB.
I'm playing with the client examples and have been able to successfully pull data from the api.openweathermap.org using the code example from this forum.
However, I can't get the "Using the JOKE API"  example code to run without a "syntax error" on the line:  "WEB open tls client "official-joke-api.appspot.com",443"
Initially the code is at:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15600#198429
I am pasting the code examples into MMEdit for testing.
There is probably a simple solution but I am open to any suggestions?
David G
Prattville, AL USA
Posted: 08:31am 11 Mar 2023
Which exact version did you program into the Pico?
? MM.VER
may say.
dgrissom
Posted: 02:20pm 11 Mar 2023
Thanks for responding.
Today the code is working fine!
I don't know what caused it to error out yesterday.  I'm scratching my head on this one.
(BTW, I was using version:   5.070721)
With that said the jokes are pretty corny so far...
homa
Posted: 09:56pm 14 Mar 2023
@pwillard: useful PDF book!
makes sense to include the extension from a23 for dynamic graphics and explain it a bit more?!
  matherp said  V5.07.07a23
This has some fun new features
First there are two new "display" drivers
VIRTUAL_C and VIRTUAL_M
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15691
