Local Time 19:07 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite DCF77 Signal Locator
DrifterNL
Posted: 05:12pm 02 Mar 2023
PilotPirx's post "PicoMite DCF77 Decoder" reminded me that I once wrote software, for an other microcontroller system, to help locate the DCF77 signal and thus help in aiming the antenna.
I rewrote my software and tweaked it some for the PicoMite.
The signal from the DCF77 module is connected to GP7.
'PicoMite DCF Signal Locater
'Connect signal from DCF77 module to GP7
'Turn the antenna slowly to find the signal
'Signal is shown as a bar graph
'and counter going up to 100
Option explicit
SetPin gp7, fin
Const SG = 1, SB = 5, SD = 1
Dim integer signal, signal_quality, bar_graph
signal_quality = 0
start:
Pause Max(100 - signal_quality, 50)
signal = Pin(gp7)
If signal = 1 Then
  signal_quality = Min(signal_quality + SG , 100)
ElseIf signal > 1 Then
  signal_quality = Max(signal_quality - SB, 0)
   Else
      signal_quality = Max(signal_quality - SD, 0)
EndIf
For bar_graph = 0 To signal_quality / 5
If bar_graph > 0 Then Print "#";
Next
Print signal_quality;
If (signal = 0) And (signal_quality > 80) Then
  Print " DCF DATA"
Else
  Print " "
EndIf
GoTo start
Floating Point Keeps Sinking Me!
Back To Integer So I Don't Get Injured.
Posted: 05:24pm 02 Mar 2023
Hi DrifterNL,
Always nice to see this type of tool that helps people set up a system. But looking at the code I estimate the dcf77 module outputs digital data and you use a frequency measurement to see how many digital edges are ib tje datastream?
Please explain how this works?
DrifterNL
Posted: 07:08pm 02 Mar 2023
Hi Volhout,
If the DCF77 antenna is aimed relatively correctly the DCF77 module outputs a 1Hz signal.
If the antenna isn't aimed correctly the output is a random Hz.
The software basically increments the value in signal_quality if the signal on GP7 is 1Hz and decrements the value if the signal is other than 1Hz.
The longer the signal is good (1Hz) the higher the value up to 100.
The longer the signal is bad (<>1Hz) the lower the value down to 0.
This value is used to print a bar graph and a number between 0 and 100.
Edited 2024-03-21 08:15 by DrifterNL
