Forum Index : Microcontroller and PC projects : Editor-Probems with PicoMiteVGAV5.07.07b19
| Erik008 Newbie Joined: 05/03/2023 Location: GermanyPosts: 2 |
Hello all, I recently started using PicoMite with version PicoMiteVGAV5.07.07b19 and I am having problems with the editor. So I write a program, which everything works wonderfully. For example, if I want to insert a new line, I move the cursor to the desired line, press return, and then insert something new. All other lines move down to make room. But now when I insert something new, those lines that moved down are no longer visible. Does anyone know this problem? Or is it a feature? Greetings, Erik |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
this problem is solved in next Versions: See https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15582 Edited 2023-03-07 16:45 by Martin H. 'no comment |
Great. Thanks for the information. Erik |
