Forum Index : Microcontroller and PC projects : Difference in mmbasic for PICOW and PICO
atmega8
Posted: 02:11pm 07 Mar 2023
Hello Forum-Members, Peter,
a general question, since it is not easy to keep track:
Does mmbasic for PICOW have the same range of functions as mmbasic for PICO?
In other words:
All Options, RO Variables (MM.XYZ), Commands and Functions from mmbasic for PICO are also included in PICOW?
My apologies if the question is redundant...
Dietmar
Posted: 02:25pm 07 Mar 2023
AFAIK all the GUI commands and CTRLVAL are omitted.
I'm not sure if the heartbeat LED works in the same way as it's not on GP25 now.
Extra commands are added to handle the wifi. (I've not kept track of these as I haven't got a Pico W).
Apart from that I *think* it's the same as the non-VGA PicoMite.
(Now Peter will appear to inform me that I'm wrong. :) )
atmega8
Posted: 03:03pm 07 Mar 2023
  Mixtel90 said  AFAIK all the GUI commands and CTRLVAL are omitted.
> option heartbeat off
> option heartbeat on
Works
What is "CTRLVAL" ?
Edited 2023-03-08 01:04 by atmega8
Posted: 03:14pm 07 Mar 2023
It's a function used with the GUI commands, so it's useless if they are missing.
atmega8
Posted: 03:35pm 07 Mar 2023
  Mixtel90 said  It's a function used with the GUI commands, so it's useless if they are missing.
OK, ACK
Posted: 04:30pm 07 Mar 2023
The other difference is that the W version is about 20% slower at the same CPU clock speed and the maximum clock speed is 264MHz, plus it has less memory available (84Kb vs 100Kb-VGA and 128Kb-normal)
atmega8
Posted: 04:48pm 07 Mar 2023
Thank you, this is still comprehensible.
twofingers
Posted: 06:57pm 08 Mar 2023
@Peter
I think it might make sense to give the Picoweb its own device ID (mm.device$) because of the differences.
Best regards
Michael
pwillard
Posted: 12:12am 09 Mar 2023
Let's put it in perspective... my LAST boot-to-Basic machine had 64K of TOTAL ram.
Posted: 08:03am 09 Mar 2023
Mine had a 256k paged RAM card. Mind you, it's not a lot of use when it's not contiguous and BASIC can't address it. :)
Posted: 08:31am 09 Mar 2023
Luxury! You were lucky. I used to dream of ...
Posted: 08:44am 09 Mar 2023
Aye, times were 'ard! There were eleven of us and we all had to huddle together round a pile of punched card chad in winter...
PhilP
Posted: 10:29am 11 Mar 2023
Should SETTICK work? It does not seem to on my Pico W with version 5.070719. I am trying to use it to download Openweather data every 15 minutes to display on LCD. Everything else works and I hate using a long PAUSE.
Phil
Posted: 10:41am 11 Mar 2023
  PhilP said  Should SETTICK work?
Works for me...
