Local Time 22:45 14 Apr 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWEB V5.07.07a24+ - Now with TFTP
     Page 1 of 5
Posted: 06:39pm 12 Mar 2023
V5.07.07a24
PicoMiteWebV5.07.07a24.zip
Note the times taken and the file size
See here for how to enable TFTP on windows (tested on W11). Linux users: you are on your own
The TFTP server is automatically enabled if you are connected to wifi and makes transferring files easy and fast. NB: The protocol TFTP does not support directory listing etc. so don't ask. It is also completely insecure so only use on your local network.
  Quote   tftp
Transfers files to and from a remote computer running the TFTP service.
TFTP [-i] host [GET | PUT] source [destination]
 -i              Specifies binary image transfer mode (also called
                 octet). In binary image mode the file is moved
                 literally, byte by byte. Use this mode when
                 transferring binary files.
 host            Specifies the local or remote host.
 GET             Transfers the file destination on the remote host to
                 the file source on the local host.
 PUT             Transfers the file source on the local host to
                 the file destination on the remote host.
 source          Specifies the file to transfer.
 destination     Specifies where to transfer the file.
Posted: 07:18pm 12 Mar 2023
Super. Goodbye, XMODEM.
atmega8
Posted: 09:17pm 12 Mar 2023
Wow, that makes Tbi gs much easier and faster!
Very helpfull Feature.
Thank you Peter.!
atmega8
Thank you Peter.!
Michal
Posted: 09:24pm 12 Mar 2023
It's fast over tftp.
Michal
panky
Posted: 10:21pm 12 Mar 2023
Info for Linux users on tftp here
  Tongue in cheek -      some command line needed but then again, isn't PowerShell just another terminal!
My Pico-W modules arrive this week - can't wait to experiment - thanks Peter for another great contribution,
Doug.
Hans
Posted: 01:38am 13 Mar 2023
  matherp said  V5.07.07a24
Hi All;
Watch for a topic called "TFTP Pi to PICO". I'm in the process of creating a document and it is so simple you beginners will be able to do it too.
Happy TFTPing,
Hans ...
Posted: 06:40am 13 Mar 2023
Works from Linux after installing tftp package
Works from Windows 11 after enabling tftp client in apps and features.
I like the way it can run and transfer files while still having the web server active.
Well done.
Posted: 01:28pm 13 Mar 2023
  TassyJim said  Works from Windows 11 after enabling tftp client in apps and featuresJim
Thanks for that. I struggled with the installation of the SolarWinds TFTP server. It ran through most of the steps, then said the installation had failed. I ran it again, and it asked if I wanted to Repair or Remove. I chose Repair, but TFTP from the PowerShell didn't work. I uninstalled and repeated: again failed, again repaired.
Now with Jim's suggestion, after searching for Windows Features, I went here:
Clicked TFTP Client and OK, and now it works. Great improvement in speed of transfer and ease of use.
Posted: 02:04pm 13 Mar 2023
Just to be clear to anyone else.
You need to install a TFTP client and not a server to use the new functionality. The link I provided explains both and I should have made it clear that only the client is needed and in windows that is just a matter of enabling it.
Michal
Posted: 03:19pm 13 Mar 2023
Here is a neat client and server for Win32 and Win64:
http://philippe.jounin.pagesperso-orange.fr/tftpd32_download.html
Michal
Pluto
Posted: 07:26pm 13 Mar 2023
TFTP is really very fast for transfer to PicoMiteWEB's flash memory
-it seems not to like filenames with spaces.
-I thought that it would load to Pico's program memory directly (and start), but loading to the flash is of course much more useful!
Thanks again Peter for the new tool!
With earlier versions my Pico got "****PANIC****" after a few (5...15) updates from openweathermap. Haven't run V5.07.07a24 long enough yet to see any possible problems.
What is generally causing the ****PANIC****? Any risk of destroying the Pico? Is just telling me that it is overloaded?
/Pluto
Pluto
Posted: 08:06pm 13 Mar 2023
*** PANIC *** again with V5.07.07a24 after reading 15 times from openweathermap. MMCC output:
Weather for Porvoo
Temperature is         -1.08
Pressure is    990
light snow
Connected
Weather for Kaskinen
Temperature is         -1.77
Pressure is    978
light snow
Connected
*** PANIC ***
Out of Heap memory
Error: Invalid address - resetting
Port: COM6 removed
Disconnected
Port: COM6 inserted
Connected to COM6 at 115200
PicoMiteWeb MMBasic Version 5.07.07a24
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
Connecting to WiFi...
Connected 192.168.8.189
Starting server at 192.168.8.189 on port 80
...and "light snow" has now turned into heavy snow. Time to use the shovel again. The piles are getting quite high and I can soon take a big step up on the roof.
Posted: 10:22pm 13 Mar 2023
Your program would be useful - are you closing the connection?
Posted: 12:53am 14 Mar 2023
  Pluto said  -it seems not to like filenames with spaces.
It works if you enclose them in quotes
E:\>tftp 192.168.1.100 get "PicoWeb Test 1.bas"
Edit
The length may be an issue.
This transfers:-
E:\PicoMiteWeb>tftp -i 192.168.1.100 get "Compr img test.bas"
Transfer successful: 1205 bytes in 1 second(s), 1205 bytes/s
But this won't - same file different name:-
E:\PicoMiteWeb>tftp 192.168.1.100 get "Compressed image test.bas"
Connect request failed
You can however send if the target name is shorter.
E:\PicoMiteWeb>tftp 192.168.1.100 put "Compressed image test 2.bas" "cmp2.bas"
Edited 2023-03-14 12:59 by phil99
Posted: 07:59am 14 Mar 2023
maximum name length for tftp is 20 chars - don't know why
Pluto
Posted: 08:20am 14 Mar 2023
Peter, here is the program and the options in use.
'openweathermap
CLS
Dim buff%(512)
Dim APIKEY$="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
WEB ntp 2
Dim report$="weather?q=Porvoo,FI"
Dim b$= "GET /data/2.5/"+report$+"&APPID="+APIKEY$+Chr$(10)+Chr$(13)
SETTICK 1000*60,Klocka
Klocka
DO
update=0
WEB open tcp client "api.openweathermap.org",80
WEB TCP CLIENT REQUEST b$,buff%(),10000
WEB close tcp client
Print "Weather for " + Json$(buff%(),"name")
Print "Temperature is ",Val(Json$(buff%(),"main.temp"))-273
Print "Pressure is ",Json$(buff%(),"main.pressure")
Print Json$(buff%(),"weather[0].description")
TEXT 0,10,"Hemma:",,,2,rgb(blue),rgb(White)
text 0,40,"Temperatur:"+str$(Val(Json$(buff%(),"main.temp"))-273)+"'C",,,1
TEXT 0,60,"Lufttryck: "+Json$(buff%(),"main.pressure")+"mBar"
text 0,80,Json$(buff%(),"weather[0].description")
WindDir
TEXT 0,100,"Vind: "+Json$(buff%(),"wind.speed")+" m/s "+riktning$
TEXT 0,120,"Regn: "+Json$(buff%(),"rain.1h")+" mm/h"
Update=1
pause 60000*2
Update=0
report$="weather?q=Kaskinen,FI"
TEXT 160,10,"Holmin:",,,2,rgb(blue),rgb(White)
text 160,40,"Temperatur:"+str$(Val(Json$(buff%(),"main.temp"))-273)+"'C"
TEXT 160,60,"Lufttryck: "+Json$(buff%(),"main.pressure")+"mBar"
text 160,80,Json$(buff%(),"weather[0].description")
WindDir
TEXT 160,100,"Vind: "+Json$(buff%(),"wind.speed")+" m/s "+riktning$
TEXT 160,120,"Regn: "+Json$(buff%(),"rain.1h")+" mm/h"
Update=1
'Klocka
pause 60000*2
loop
end
SUB WindDir
grad=val(+Json$(buff%(),"wind.deg"))
riktning$=""
if grad>337.5 or grad<=22.5 then riktning$="Nord"
if grad>22.5 and grad<=67.5 then riktning$="N-O"
if grad>67.5 and grad<=112.5 then riktning$="Ost"
if grad>112.5 and grad<=157.5 then riktning$="S-O"
if grad>157.5 and grad<=202.5 then riktning$="Syd"
if grad>202.5 and grad<=247.5 then riktning$="S-V"
if grad>247.5 and grad<=292.5 then riktning$="V"
if grad>292.5 and grad<=337.5 then riktning$="N-V"
end sub
sub Klocka
If Update then
Tid$=left$(time$,5)
text mm.hres/2,mm.vres*7/8,Tid$,CM,,3,rgb(blue),rgb(white)
end if
end sub
option list
PicoMite MMBasic Version 5.07.07a24
OPTION CPUSPEED (KHz) 252000
OPTION LCDPANEL ILI9341, LANDSCAPE,GP17,GP14,GP13
OPTION WIFI ZZZZZZZZZ, ***********
OPTION TCP SERVER PORT 80
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 3921, 3913, -894, -632
/Pluto
Posted: 08:36am 14 Mar 2023
I don't like the SETTICK which is asynchronous to complex web and json activity - both very stack intensive. Please try it a different way and then let me know.
Pluto
Posted: 09:18am 14 Mar 2023
Removed the SETTICK and all calls to SUB Klocka (for displaying time). It run for 8 updates of the first location and got panic at the 8th update of the second position.
Will now strip it to only read data for one location.
Posted: 09:26am 14 Mar 2023
Pluto,
Try this version.
The settick sets a flag and alternates between the two locations. My system is up to 14 reads so far. I don't have a display so all output is to PRINT.
 'openweathermap
 ' CLS
 DIM buff%(512)
 DIM APIKEY$="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
 WEB ntp 2
 DIM report$="weather?q=Porvoo,FI"
 DIM b$= "GET /data/2.5/"+report$+"&APPID="+APIKEY$+CHR$(10)+CHR$(13)
 SETTICK 1000*120,Klocka
 Klocka
 DO
   IF update THEN getfirst
   IF update2 THEN getsecond
 LOOP
SUB getfirst
 update = 0
 WEB OPEN tcp client "api.openweathermap.org",80
 WEB CLOSE tcp client
 PRINT "Weather for " + Json$(buff%(),"name")
 PRINT "Temperature is ",VAL(Json$(buff%(),"main.temp"))-273
 PRINT "Pressure is ",Json$(buff%(),"main.pressure")
 PRINT Json$(buff%(),"weather[0].description")
 PRINT "Hemma:" ',,,2,rgb(blue),rgb(White)
 PRINT "Temperatur:"+STR$(VAL(Json$(buff%(),"main.temp"))-273)+"'C" ',,,1
 PRINT"Lufttryck: "+Json$(buff%(),"main.pressure")+"mBar"
 WindDir
 PRINT "Vind: "+Json$(buff%(),"wind.speed")+" m/s "+riktning$
 PRINT "Regn: "+Json$(buff%(),"rain.1h")+" mm/h"
END SUB
SUB getsecond
 update2 = 0
 PRINT "Holmin:" ',,,2,rgb(blue),rgb(White)
 PRINT "Lufttryck: "+Json$(buff%(),"main.pressure")+"mBar"
 WindDir
END SUB
SUB WindDir
 grad=VAL(+Json$(buff%(),"wind.deg"))
 riktning$=""
 IF grad>337.5 OR grad<=22.5 THEN riktning$="Nord"
 IF grad>22.5 AND grad<=67.5 THEN riktning$="N-O"
 IF grad>67.5 AND grad<=112.5 THEN riktning$="Ost"
 IF grad>112.5 AND grad<=157.5 THEN riktning$="S-O"
 IF grad>157.5 AND grad<=202.5 THEN riktning$="Syd"
 IF grad>202.5 AND grad<=247.5 THEN riktning$="S-V"
 IF grad>247.5 AND grad<=292.5 THEN riktning$="V"
 IF grad>292.5 AND grad<=337.5 THEN riktning$="N-V"
END SUB
SUB Klocka
 STATIC choice
 choice = 1 - choice
 IF choice THEN
   update = 1
 ELSE
   update2 = 1
 ENDIF
END SUB
     Page 1 of 5
