Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mm.info(flash  size)
nbrok
Posted: 08:26am 23 Mar 2023
@Peter
A stupid question: what does mm.info(flash size)?
When I type print mm.info(flash size) it returns 0
I know it would report the size of flash memory, but what memory?
I use the 5.07..07b28 version.
Did I discover a new bug or is the flash memory an optional thing?
The flash slots do work and the A: drive also.
Edited 2023-03-23 18:27 by nbrok
Greetings,
Nick de pe1goo
Posted: 08:36am 23 Mar 2023
Yeah, I am getting that also.
mm.info(flash) returns the flash slot currently running a program - normally 0
mm.info(option flash size) returns the size of the flash memory chip
Posted: 08:41am 23 Mar 2023
Manual page 74 says to use the former.
When did the syntax change?
...or the manual needs updating.
EDIT: Option Flash Size crashes the PM, but it could be cos I am using a version below, so I will update and try again.
Edited 2023-03-23 18:43 by Grogster
nbrok
Posted: 09:28am 23 Mar 2023
  matherp said  mm.info(flash) returns the flash slot currently running a program - normally 0
Thanks... so it becomes the time that the manual has to be updated, because a lot has changed.
Edited 2023-03-23 19:29 by nbrok
Greetings,
Nick de pe1goo
nbrok
Posted: 09:31am 23 Mar 2023
  Grogster said  Manual page 74 says to use the former.
To inform you, mine is not crashing, latest beta as mentioned in my first message.
Greetings,
Nick de pe1goo
Posted: 09:32am 23 Mar 2023
  Quote  so it becomes the time that the manual has to be updated, because a lot has changed.
manual is updated when there is a new release
Posted: 12:06pm 23 Mar 2023
... which depends on three things, Peter's boredom threshold, Geoff's workload and the phase of the moon. :)
Martin H.
Posted: 12:38pm 23 Mar 2023
  Mixtel90 said  ... which depends on three things, Peter's boredom threshold, Geoff's workload and the phase of the moon. :)
and the relative lunar humidity
'no comment
