Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite VGA debugging via Terminal?
Martin H.
Posted: 01:04pm 29 Mar 2023
Maybe I missed it,
Is there a way to output text only through the terminal?
It would be helpful for debugging to send values of variables to the terminal during the program without it appearing on the VGA screen.
Mart!n
Edit
Appendix A describes how this would work via Com1 and 2. Can I also use the serial connection which I have already established via usb anyway?
Edited 2023-03-29 23:30 by Martin H.
'no comment
Posted: 01:51pm 29 Mar 2023
If you are using the VGA as a graphic display then using PRINT won't display on it, but it will display on the console. Likewise TEXT will display on the graphic screen but not on the console.
The console can be redirected to a COM port but it doesn't need to be. It's USB by default, of course.
Posted: 01:57pm 29 Mar 2023
Use OPTION LCDPANEL NOCONSOLE in your program. Then all graphics commands will still work on the screen and print statements will only go to the terminal
Martin H.
Posted: 02:14pm 29 Mar 2023
  matherp said  Use OPTION LCDPANEL NOCONSOLE in your program. Then all graphics commands will still work on the screen and print statements will only go to the terminal
That does the Job
and OPTION LCDPANEL CONSOLE  to turn it on again
Thank you
'no comment
