Forum Index : Microcontroller and PC projects : Picomite MP3
| mibinho Newbie Joined: 06/03/2023 Location: GermanyPosts: 7 |
Hello, Is it possible playback a mp3-file with mmbasic like here: https://learn.adafruit.com/mp3-playback-rp2040/pico-mp3 ? -- the vermin have inherited the earth. |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 757 |
The links seems to be down... But the only benefit for mp3 is that it is much smaller. I am happy with wav playback because 32GB of SD Card is huge.. Okay if you want to build some music player it will be hard with wav I guess... Edit: + give Peter a break! I don't know how he even doing all this magic in such a short time. Greetings Daniel Edited 2023-03-30 04:38 by Amnesie |
https://learn.adafruit.com/mp3-playback-rp2040/pico-mp3 -- the vermin have inherited the earth. |
Wav is also fine for me. I want a short 5 seconds "Startup Sound" Edited 2023-03-30 04:47 by mibinho -- the vermin have inherited the earth. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11513 |
That isn't decent quality mp3 and is incompatible with the mp3 files you have stored. The processor isn't powerful enough to do 44100Hz MP3 let alone anything faster |
Addtional complication is the sample rate conversion. MP3 can be 8kHz....48kHz. That is find for direct writing to a DAC. Picomite has a PWMat 44.1kHz. Conversion of rates is definitely a nasty task... PicomiteVGA PETSCII ROBOTS |
