Forum Index : Microcontroller and PC projects : PicoMite: firmware testing remotely via MMB4L
Hi folks, Even though this has to be in the running for the least interesting YouTube video ever I still wanted to post as it shows the (almost) culmination of three years playing with MMBasic; though I didn't know this was where I was going at the time. It shows: - Windows 10 - running the Windows Subsystem for Linux (WSL2) - running MMBasic for Linux (MMB4L) - running 'gonzo' my serial file transfer program/shell - running a script - that transpiles (using 'sptrans'), - sends, and - executes all my MMBasic firmware tests (using 'sptest') - to a remote PicoMite over the USB/serial link. I wouldn't watch all (or indeed any) 12+ minutes of it. https://www.youtube.com/watch?v=Tg5I-5hEJSA I've found no significant bugs in the RC6 firmware, though there are some odds and ends that I will probably bend Peter's ear about after I've just worked out some issues on my side. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom, Nice work. I was wondering what unit testing was about so I have previously had a look/play with your sptest suite. Looking forward to seeing the updated tests on GitHub. Gerry F4 H7FotSF4xGT |
| Kabron Regular Member Joined: 30/11/2017 Location: GermanyPosts: 65 |
Quality!! Dangerous for eyes! |
Comment from YouTube which I think must have been by @Kabron because it's the same avatar: I'll try and explain. I have a set of Unit Tests that I originally wrote whilst porting MMBasic to Linux (MMB4L). These are sets of fairly self-contained subroutines that each try to assert/test a single piece of MMBasic behaviour. e.g. Here is a SUB to test the INC command operating on a scalar: Sub test_inc_scalar() Local i%, f!, s$ Inc i% assert_int_equals(1, i%) Inc i%, 2 assert_int_equals(3, i%) Inc i%, -4 assert_int_equals(-1, i%) Inc f! assert_float_equals(1.0, f!, 0.001) Inc f!, 3.21 assert_float_equals(4.21, f!, 0.001) Inc f!, -5.19 assert_float_equals(-0.98, f!, 0.001) Cat s$, "foo" assert_string_equals("foo", s$) Cat s$, "bar" assert_string_equals("foobar", s$) End Sub My 'sptest' framework automates the running of these tests and collects the result to present in an ANSI colour coded formatted report on the console. In the past I've run these tests on MMB4L, MMB4W and the CMM2 and reported any failures and variations between the MMBasic platforms to @matherp ... many of these issues are in the boundary conditions, probably to Peter's annoyance because it would be rare for anyone to encounter them in production. However running the tests on the PicoMite has presented a challenge because they depend on a fairly extensive framework (sptest) of #INCLUDEd libraries, e.g. the top of the file containing my tests for INC starts with: #Include "../sptools/src/splib/system.inc" #Include "../sptools/src/splib/array.inc" #Include "../sptools/src/splib/list.inc" #Include "../sptools/src/splib/string.inc" #Include "../sptools/src/splib/file.inc" #Include "../sptools/src/splib/vt100.inc" #Include "../sptools/src/sptest/unittest.inc" The PicoMite has no #INCLUDE support (yes I could mess with the LIBRARY now, but it would be awkward) so instead I use my transpiler (sptrans) in its simplest mode of operation to flatten out each test file into a single monolithic .bas file. Because 'sptrans' is quite slow and the PicoMite is a relative slouch I don't run sptrans on the PicoMite but instead use MMB4L (running in a WSL2 container on my fastest Windows machine). Once transpiled the file has to be transferred to the PicoMite using XMODEM and executed. Doing all this naively for 30+ test files would involve a lot of manual steps so I automate it using my shell and file transfer program (gonzo) running on MMB4L which can (a) find all the tests, and for each one, (b) transpile it, (c) xmodem send it to the PicoMite, (d) remotely execute it, and finally (e) capture the serial output (results) from the USB tethered PicoMite and present them to me in the MMB4L console. All the tooling is written in MMBasic, except of course for MMB4L which is a port of Geoff and Peter's C code. Any questions ? Tom Edited 2023-04-24 05:59 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
