Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : switch on Pico via control pin on Pico
asknik2022
Posted: 11:01am 09 May 2023
If the Pico is powered by usb direct , can i connect an on off switch to one of the pins in order to turn the pico on or off
The same question would appply to an arduino nano
Is it possible?
Posted: 11:25am 09 May 2023
Will
3V3EN Enable 3.3V regulator (low = off, high = enabled).
do what you want?
Posted: 01:03pm 09 May 2023
On the Arduino Nano there is no on/off pin as such but switching the Reset pin to ground shuts the chip down.
Posted: 01:08pm 09 May 2023
Similar to the RUN pin on the pico...
Edited 2023-05-09 23:11 by Volhout
Posted: 04:02pm 09 May 2023
3V3EN is ideal. It is a genuine power on/off switch if you are using the on-board switching supply a it puts it into a low power mode and disables the output. It works upside down, of course. With 3V3EN connected to GND the power is off.
Posted: 04:06pm 09 May 2023
  Mixtel90 said  3V3EN is ideal. It is a genuine power on/off switch if you are using the on-board switching supply a it puts it into a low power mode and disables the output. It works upside down, of course. With 3V3EN connected to GND the power is off.
But you must make provisiones that peripherals cannot backpower the rp2040 through io lines.
asknik2022
Posted: 04:55pm 09 May 2023
So I just connect a switch between GND and 3V3EN
Posted: 05:18pm 09 May 2023
As Volhout points out, it's fine if you are powering your external stuff from the PicoMite's 3V3 pin. It will all switch on and off together then. If it's powered from a different supply then it's not quite so straightforward. Apart from that, then yes. :)
