Forum Index : Microcontroller and PC projects : webmite with sd card an TFTP / telnet
Plasmamac
Posted: 01:55am 10 May 2023
hi,
if i connect a sd card socket to the webmite can i put a file to the sdcard via TFTP or Telnet ?
thx
Plasma
Posted: 06:24am 10 May 2023
Hi Plasmamac,
I tried Telnet (using Teraterm) and it gives you basically the commandline interface you have through USB serial and COM serial. I have not tested if there is support for X-modem.
But I am sure "AUTOSAVE" works, and you can edit. After a AUTOSAVE and <ctrl-Z>, you can always save the file to SD (B:) or A:
Posted: 06:47am 10 May 2023
  Plasmamac said  hi,
thx
That's how MMEdit's file manager does it.
You have to install/activate the Windows TFTP application.
So, yes, it can be done. TFTP is 'fast'
Edit
MMEdit has a few problems with telnet so it is not very user-friendly at this stage.
I have lots of work to do...
Edited 2023-05-10 18:07 by TassyJim
