Forum Index : Microcontroller and PC projects : For Jim ref Crunch & ON ERROR SKIP [nn]
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1126 |
Hi Jim Question regarding "Crunch" in MM Edit & Command "ON ERROR SKIP [nn]" I assume it is the responsibility of the programmer to ensure that there are no commented lines within the range of the SKIP[nn] number if using Crunch? May need a warning somewhere if there isn't already one. Still on V5.0.5 Thanks for MM Edit. Brian ChopperP |
What device are you programming for? As far as I can remember, SKIP skips over commands, not lines and comments inserted in the skip zone make no difference. I rarely use SKIP for anything other than one command at a time so haven't had much experience with it doing the unexpected. I think there was an issue with user defined SUBs and what to skip over but I don't remember which platform it involved. Jim VK7JH MMedit |
Hi Jim OK, misread the instructions. Sorry Using it when opening files on an F4 as it sometimes cracks a hissy-fit. Need to skip to after the Close # command if it plays up. Will count commands rather than lines. Thanks Brian ChopperP |
