Forum Index : Microcontroller and PC projects : Onboard LED of the pico w
andreas
Posted: 10:54am 22 May 2023
Is there a way to turn off a Pico W's onboard LED other than physically scratching the leads?
I know the manual says on page 10 that the GPIO pin is not accessible via BASIC - but it would be nice if there was an OPTION for this to reduce power consumption.
-andreas
Posted: 10:56am 22 May 2023
manual page 77
andreas
Posted: 11:00am 22 May 2023
  matherp said  manual page 77
You are my darling!
OPTION HEARTBEAT OFF is it!
-andreas
Posted: 05:38pm 22 May 2023
If you seriously want to save power, turn WIFI off, or use a normal pico.
andreas
Posted: 04:26pm 23 May 2023
  Volhout said  If you seriously want to save power, turn WIFI off, or use a normal pico.
Yes, but it's the pico's job to let me know when a burglar is stealing my bike ;-)
-andreas
Posted: 05:39pm 23 May 2023
In that case use the pico to disable the wi-fi completely until it's triggered by your alarm device (vibration sensor or whatever). Then switch it on. Even better if there's a GPS on there as well then it can let you where the bike is. :)
NPHighview
Posted: 06:56pm 23 May 2023
I'm not close to my workbench right now (about 1,000 km away), but how do you disable WiFi programmatically? In the WebMite manual, I see two possibilities to test:
OPTION TCP SERVER PORT 0 (just one service, not the whole capability)
OPTION WIFI DISABLE (though that's implied, not explicit)
Posted: 07:01pm 23 May 2023
OPTION WIFI "",""
but whether it reduces power I don't know and it is a permanent option that causes a reset
Posted: 08:57pm 23 May 2023
I suppose that if you were to use a non-W version with a separate wifi device you could just use a pin to switch its power off (via a mosfet). You could kill a GPS module the same way.
