Forum Index : Microcontroller and PC projects : Webmite V5.07.08 betas : UDP and other stuff
| Page 1 of 5 |
V5.07.08b0 WebMiteV5.07.08b0.zip This version fixes a bug where a TCP request while in the editor (or autosave) caused the Webmite to crash New functionality WEB TCP SEND cb%, data%() WEB TCP CLOSE cb% These two commands allow more flexibility in using the TCP server. Unlike WEB TRANSMIT PAGE or WEB TRANSMIT FILE, WEB TCP SEND does not create any sort of header, nor does it close the TCP connection after transmission. It just sends exactly what is in the LONGSTRING data%() and it is up to the Basic programmer to close the connection when appropriate. An example of use is given below. Dim q%(100),r%(100) LongString append q%(),"HTTP/1.1 200 OK"+Chr$(13)+Chr$(10) LongString append q%(),"Server:CPi"+Chr$(13)+Chr$(10) LongString append q%(),"Connection:close"+Chr$(13)+Chr$(10) LongString append q%(),"Content-type:text/html"+Chr$(13)+Chr$(10) LongString append q%(),"Content-Length:80"+Chr$(13)+Chr$(10)+Chr$(13)+Chr$(10) LongString append r%(),"<title>WebMite</title>" LongString append r%(),"<h2>Temperature Monitor</h2>" LongString append r%(),"The temperature is 0"+Chr$(13)+Chr$(10) Dim buff%(4096/8) WEB TCP INTERRUPT WebInterrupt Do '<do some processing here>' Loop Sub WebInterrupt Local a%, p%, t%, s$ For a% = 1 To MM.Info(MAX CONNECTIONS) WEB TCP READ a%, buff%() p% = LInStr(buff%(),"GET") t% = LInStr(buff%(),"HTTP") If (p% <> 0) And (t% > p%) Then LongString print q%() WEB TCP SEND a%,q%() WEB TCP SEND a%,r%() WEB TCP CLOSE a% Else WEB transmit code a%,404 EndIf Next a% End Sub The second functional enhancement implements a simple way of communicating over UDP The new commands are: OPTION UDP SERVER PORT n WEB UDP INTERRUPT intname WEB UDP SEND addr$, port, data$ OPTION UDP SERVER PORT sets up a listening socket on the port specified. Any UDP datagrams received on that port will be processed and the contents saved in MM.MESSAGE$. The IP address of the sender will be stored in MM.ADDRESS$. Note: If the UDP datagram is longer than 255 characters then any extra is discarded. WEB UDP INTERRUPT sets up a BASIC interrupt routine that will be triggered whenever a UDP datagram is received WEB UDP SEND is used to send a datagram to a remote receiver. In this case the IP address must be specified and can be either a numeric address (e.g. "192.168.1.147") or a normal text address (e.g. "google.com"). The port number of the receiver must also be specified and, of course, the message itself. The SEND command can be used as a response to an incoming message or stand-alone. e.g. WEB udp interrupt myint WEB udp send "192.168.1.155",77,"starting udp echo" Do Loop Sub myint Print "received "+mm.message$+" from "+mm.address$ WEB udp send mm.address$,77,mm.message$ End Sub Edited 2023-05-29 21:20 by matherp |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5930 |
Thanks for fixing the editor. To UDP: please confirm. The server listens only to the port set in OPTION, but you can send to any port? Volhout P.S. dit you see any solution to logging in in an open wifi network (no security (no WPA/WPA2/WEP, no password required). Edited 2023-05-29 22:01 by Volhout PicomiteVGA PETSCII ROBOTS |
@Peter, What is the intended way to implement correct daylight savings time (UTP->DST)? IS there anything in the NTP we can use, or do we write a algorithm in MMBasic (could be stored in the library ?). Volhout Edited 2023-05-29 22:22 by Volhout PicomiteVGA PETSCII ROBOTS |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Thanks a lot Matherp ![]() Plasma |
deleted..duplicate Edited 2023-05-29 22:35 by Volhout PicomiteVGA PETSCII ROBOTS |
Yes Don't know but probably not. You will need to write something in Basic - Geoff has this code in his super-clock program Edited 2023-05-29 22:35 by matherp |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 531 |
Peter, thanks for implementing UDP but i can't get V5.07.08b0 running stable. Even cleared flash with clear_flash.uf2 but this version shows strange behavior. - If no OPTION WIFI set, there seems to be no problem. Just tested on commandline. - Having WIFI set to connect to my LAN and if the connection is unsuccessful (Fritz!Box), as on every second try, there seems to be no problem either. - If successfully connected to LAN then after entering a few chars at the console input, the pico hangs. Even the heartbeat led stops blinking. It is not possible to connect via telnet, even immediately after restart. Only OPTION WIFI was set. Hardware is geniue Pico with V5.07.07 running like a charm. Regards, Gerald 73 de OE1HGA, Gerald |
When you get the weather for a city from Open Weather Map they will also give you the time zone which includes an adjustment for DST. This example is for Paris (untested but should work): CONST Key = "nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn" CONST Query = "GET /data/2.5/weather?q=Paris,fra&APPID="+Key+Chr$(10)+Chr$(13) DIM buff%(4096/8) WEB OPEN TCP CLIENT "api.openweathermap.org", 80 WEB TCP CLIENT REQUEST Query, buff%() WEB CLOSE TCP CLIENT i = val(JSON$(b(), "timezone")) PRINT "The timezone for Paris (incl DST) is:" i/3600 WEN NTP i/3600 Geoff Edited 2023-05-30 00:24 by Geoffg Geoff Graham - http://geoffg.net |
Strange as it obviously worked for me. I've done a complete re-compile and this version will force an option reset. let me know if this fixes the issue. This version should also work both sending and receiving broadcast UDP packets WebMiteV5.07.08b1.zip Couple of typos in Geoff's code but with these fixed it works a treat as mm.startup in the library Sub mm.startup Const Key = "nnnnnnnnnnnnnnnnnnnnnnn" Const Query = "GET /data/2.5/weather?q=Paris,fra&APPID="+Key+Chr$(10)+Chr$(13) Dim buff%(4096/8) WEB OPEN TCP CLIENT "api.openweathermap.org", 80 WEB TCP CLIENT REQUEST Query, buff%() WEB CLOSE TCP CLIENT i = Val(Json$(buff%(), "timezone")) WEB NTP i/3600 End Sub Edited 2023-05-30 02:30 by matherp |
V5.07.08b0 first version - same problems as ville56 V5.07.08b0 second version - looks like it works , i test the new commands can we get tcp and udp server at the same time ? Plasma |
TCP server, udp server, tftp server, and telnet server all at the same time ![]() Note I've updated the above post to b1 Edited 2023-05-30 02:32 by matherp |
Peter, the last version from your post seems to have fixed the problem. many thanks, Gerald 73 de OE1HGA, Gerald |
| hhtg1968 Senior Member Joined: 25/05/2023 Location: GermanyPosts: 204 |
many thanx to matherp. the bug in the editor is solved! |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3782 |
Very happy to see UDP. What a powerful little device the Pico W is running MMBasic. Thanks for all your fine work. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
http://www.fruitoftheshed.com/MMBasic.Function-to-Test-a-DateTime-to-see-if-Daylight-Savings-should-be-applied.ashx |
Doesn't work for southern hemisphere unless I'm missing something whereas Geoff's idea is universal for the Pico-W |
Thanks captain! I almost forgot about the integer divide, thanks to your example this came back to mind.... Going to use this in a library... Volhout PicomiteVGA PETSCII ROBOTS |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Hi all, This thread doctored Captain's code for the Southern Hemisphere for non-WebMites. Geoff's code using Openweather now works for me and is far simpler. Cheers, Andrew |
| andreas Senior Member Joined: 07/12/2020 Location: GermanyPosts: 226 |
Is there a possible memory leak or why is "General" memory increasing? I have tested this program on a pico w (5.07.08b1) to measure brightness sensor on gp28 and send the values to a MQTT broker. With each turn the "General" RAM is increasing upto a "out of memory error" after a while of measurements: > list SetPin gp28, ain Do helligkeit = Pin(gp28) Print "Helligkeit: ";helligkeit On ERROR SKIP WEB MQTT CONNECT "192.168.178.54",1883,"anon", "anon" If Not MM.Errno Then WEB MQTT PUBLISH "brightness",Str$(helligkeit,3,2) WEB MQTT CLOSE EndIf Pause 1000 Memory Loop (..some loops..) Helligkeit: 2.876385836 Program: 1K ( 1%) Program (14 lines) 79K (99%) Free Library: 1K ( 1%) Library 79K (99%) Free Saved Variables: 16K (100%) Free RAM: 1K ( 1%) 1 Variable 79K (73%) General 26K (26%) Free Helligkeit: 2.878669109 Program: 1K ( 1%) Program (14 lines) 79K (99%) Free Library: 1K ( 1%) Library 79K (99%) Free Saved Variables: 16K (100%) Free RAM: 1K ( 1%) 1 Variable 79K (74%) General 26K (25%) Free Helligkeit: 2.877728938 Program: 1K ( 1%) Program (14 lines) 79K (99%) Free Library: 1K ( 1%) Library 79K (99%) Free Saved Variables: 16K (100%) Free RAM: 1K ( 1%) 1 Variable 80K (74%) General 25K (25%) Free Helligkeit: 2.88041514 Program: 1K ( 1%) Program (14 lines) 79K (99%) Free Library: 1K ( 1%) Library 79K (99%) Free Saved Variables: 16K (100%) Free RAM: 1K ( 1%) 1 Variable 80K (75%) General 25K (24%) Free [4] helligkeit = Pin(gp28) Error : Not enough memory > option list WebMite MMBasic Version 5.07.08b1 OPTION SYSTEM I2C GP0,GP1 OPTION AUTORUN ON OPTION LIBRARY_FLASH_SIZE 14000 OPTION COLOURCODE ON OPTION DISPLAY 50, 100 OPTION WIFI FritzBox, ********************* OPTION TELNET CONSOLE ON OPTION SDCARD GP5, GP2, GP3, GP4 -andreas |
Hi Andreas, What is OPTION LIBRARY_FLASH_SIZE 14000 ???? This is not listed in the user manual... I thought the library was fixed size (1 flash slot) Volhout Edited 2023-05-30 22:15 by Volhout PicomiteVGA PETSCII ROBOTS |
| Page 1 of 5 |
