Local Time 18:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Var Save very slow?
Bleep
Posted: 08:49am 24 Jun 2023
I have a program running a 1 second loop, the code takes roughly 0.2S so I have a WatchDog timer set to 1500 (1.5Sec) however I was finding that the timer was timing out sometimes, I tracked it down to Var Save, every Var Save seems to take about a third of a second, first is this expected? second, if not any chance of a fix?
Sample code follows for a VGA, but it's the same on standard.
> option list
PicoMiteVGA MMBasic Version 5.07.07b32
OPTION SYSTEM I2C GP22,GP15
OPTION COLOURCODE ON
OPTION KEYBOARD UK
OPTION DISPLAY 60, 106
OPTION SDCARD GP5, GP2, GP3, GP4
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
OPTION RTC AUTO ENABLE
OPTION DEFAULT FONT 7, 1
> list
Dim float a(1),b,c(2)
a(0)=42.42:a(1)=3.14159
b=6.9532
c(0)=4.59:c(1)=659.32
Timer =0
VAR Save b
Print Timer
Timer =0
VAR Save b,a(),c()
Print Timer
VAR Save b,a(),c()
VAR Save b,a(),c()
VAR Save b,a(),c()
VAR Save b,a(),c()
Print Timer
> run
391.639
393.078
1958.415
Any help appreciated.
Regards, Kevin.
Posted: 09:00am 24 Jun 2023
VAR SAVE was never really intended for heavy usage. The idea was to give somewhere where some variables could be stored through power off and then recovered next time the device was re-booted. It's probably ok on the Pico, but on some other platforms it uses relatively short lifetime flash and, in theory, it's possible to wear it out. Because of this usage pattern I don't think its speed has ever been of any consequence. The best way to save some variables on a PicoMite is probably to write them to a file. on A:.
Bleep
Posted: 09:16am 24 Jun 2023
I'm only saving once an hour, so this is not a problem, it' just the fact that it takes up quite a chunk of time, when I do use it, especially if I have to do 2 seperate Var Saves, which happens at midnight.
Regards, Kevin.
Posted: 09:26am 24 Jun 2023
I've never noticed it to be slow, but then again I've never used it in any other way. :). VAR SAVE is a flash write command so it may be stopping all interrupts until it completes. That might screw things up a bit.
disco4now
Posted: 11:02am 24 Jun 2023
Each time VAR SAVE is called its has to erase the 16K of flash allocated for saved variables, then write the actual variables to the flash. You could look at using RTC battery backed memory.
  The Manual said
Saved Variables
Because the PicoMite does not necessarily have a normal storage system it needs to save data that can be
recovered when power is restored. This can be done with the VAR SAVE command which will save the
variables listed on its command line in non-volatile flash memory. The space reserved for saved variables is
16KB.
These variables can be restored with the VAR RESTORE command which will add all the saved variables to
the variable table of the running program. Normally this command is placed near the start of a program so that
the variables are ready for use by the program.
This facility is intended for saving calibration data, user selected options and other items which change
infrequently. It should not be used for high speed saves as you may wear out the flash memory. The flash used
for the Raspberry Pi Pico has a high endurance but this can be exceeded by a program that repeatedly saves
variables. If you do want to save data often you should add a real time clock chip. The RTC commands can
then be used to store and retrieve data from the RTC's battery backed memory. See the RTC command for
more details.
F4 H7FotSF4xGT
Bleep
Posted: 06:14pm 24 Jun 2023
Hi, well if it is erasing the whole 16k block that might explain why it takes so long, but still 0.39 Sec per erase/save seems a very long time even to do that, though I'm unsure it's doing that because I'm doing 2 separate Var Saves, with different variables being saved, in separate parts of the program & I think they are all still present? if each Var Save erased first then only the latest set of Var Save variables would be preserved. I'll have to check that? :-(
I'm not using an RTC, I'm using the built-in Date/Time, its currently only gaining 2 seconds a day, which I'm correcting at midnight ;-) along with a Var Save of 5 bits of data. Total Wh, In/out, Daily Wh In/out and a current status integer & then later writing some current status info to a daily log file. I don't have an sd either so this is all going to internal flash, this is very minimalist, only a 2 line lcd, because it's running off solar/battery only 8mA display on or 5mA display off from 12V supply.
Regards Kevin.
Edited 2023-06-25 04:17 by Bleep
Posted: 06:42pm 24 Jun 2023
VAR SAVE updates any existing saved variables of the same name and adds any new ones that have been listed. VAR RESTORE simply restores all saved variables.
If your program is running continuously it might be better to simply write changed data with the time to a log file every so often. If it hasn't changed since it was last written then don't write it again. The "every so often" might be a SETTICK interrupt every minute or something.
