Forum Index : Microcontroller and PC projects : ESP32 MMBasic
lew247
Posted: 03:59pm 29 Jun 2023
Does anyone want to have a go at porting MMBasic to the ESP32?
Peter said in a previous thread
  matherp said
The S3 module he is using has 8Mb of RAM and 8Mb of flash. There is an even better one with 8/32 both connected via octal SPI and memory mapped. I said in a previous thread that this is by far the best candidate for MMBasic of anything out there at the moment but not something I am considering
If anyone is willing to have a go I'll buy one of these Esp32 devkits with 32 MB Octal flash & 8 MB Octal PSRAM
Or If anyone wants to port to the ESP and design a new board all in one go one of these with 32 MB Octal flash & 8 MB Octal PSRAM
The only stipulation I would have is it uses a linear voltage regulator and LDO then there won't be noise introduced do the switch mode pst
And USB-C port(s)
It could include VGA, DVI AND OR HDMI (outputing a dvi signal) as the device is capable of hi-res 16 bit now, games ports, microsd card reader, standard usb for plugging in a usb stick, and whatever other sockets anyone wanted
If anyone is interested let me know and I'll see about getting a board to them.
I will only be doing this for one person if they are genuine about porting to the ESP as I'm not working definitaly not rich or even well off but I consider it money well spent for all the help I've had on the forum
Sasquatch
Posted: 04:42pm 29 Jun 2023
I already have a couple of the ESP32-S3-DevKitC-1-N32R8V on order.  Not sure what I will use them for yet.  I'll likely do some benchmarks in 'C' to compare to CMM2, PicoMite etc.  Given the specified 240MHz clock speed for the S3 module and published benchmarks (CoreMark) it looks to be about as fast as an overclocked PiPico and well short of CMM2 performance.  Not much information on overclocking the S3 yet.  So the main advantage over the PicoMite would likely be the large pool of fast memory.
The VGA library for S3 on GitHub is just "bare-bones" so it might be a bit early to port anything over just yet.  I sounds like he plans to expand it to a "proper library" with support for Text, Sprites, Tiles etc.
We may find that there are other limitations making an MMBasic port impractical or otherwise not worth the effort.  Still at $18 and currently available it's probably worthy of further investigation.
Edited 2023-06-30 02:46 by Sasquatch
-Carl
stanleyella
Posted: 08:08pm 29 Jun 2023
  Sasquatch said  I already have a couple of the ESP32-S3-DevKitC-1-N32R8V on order.  Not sure what I will use them for yet.  I'll likely do some benchmarks in 'C' to compare to CMM2, PicoMite etc.  Given the specified 240MHz clock speed for the S3 module and published benchmarks (CoreMark) it looks to be about as fast as an overclocked PiPico and well short of CMM2 performance.  Not much information on overclocking the S3 yet.  So the main advantage over the PicoMite would likely be the large pool of fast memory.
got one but can't do c or python. nice board. my thoughts, use as vga interface for 8bit pic but better total control.try interface with fabgl but how?
mmbasic picomite is very clever compared. all sorted for the user.
lew247
Posted: 01:03pm 30 Jun 2023
It's actually a S3-WROOM-2
ESP32-S3-WROOM-2-N32R8V, 32 MB Octal flash & 8 MB Octal PSRAM, w/ Pin Header
Sasquatch
Posted: 05:12pm 30 Jun 2023
LOL, if you follow your own links in the OP, the WROOM part number refers to the small surface mount module, and the DevKitC part number refers to the PCB module with USB connectors and holes for pin-headers.  The DevKitC module has the WROOM module mounted on it.  So they are two different part numbers for two different parts.
-Carl
-Carl
lew247
Posted: 06:46am 01 Jul 2023
Forget the original post
offer rescinded
I cba with idiots making fun of me
ice2642
Posted: 08:12am 01 Jul 2023
  lew247 said  Does anyone want to have a go at porting MMBasic to the ESP32?
And USB-C port(s)
Hello,
I buy this board today TTgo vga32
If you port the mmbasic, and it is compatible, I can test here when it arrive.
Best regards,
MMBasic 5.0707 on PicoMite VGA
Posted: 08:19am 01 Jul 2023
  ice2642 said  I buy this board today TTgo vga32
Peter may prove me wrong (though I judge he is currently not in the mood) but the chances of anyone porting MMBasic to yet another board in the next 12-24 months seem unlikely. IIRC there are ~1000 hours of work in each port; personally I have about 2-300 hours of free time a year. I suggest time would be better spent appreciating the presents we already have rather than dreaming of Christmas .
YMMV,
Edited 2023-07-01 18:25 by thwill
stanleyella
Posted: 01:34pm 01 Jul 2023
YMMV,
Yes. a rpipico and mmbasic and mmedit is a brill system to explore microcontrollers.
I've only used it for a year unlike others on the forum so only know the picomite but this cheap board does everything I want.
I only bought a esp32 board because it was posted as a suggestion on another forum.
Sasquatch
Posted: 01:44pm 01 Jul 2023
  lew247 said  Forget the original post
offer rescinded
Sorry @lew247,
It was not my intention to make fun of anybody and I apologize if I offended you!
I was LOL due to the fact that there seems to be several conversations about several different devices running through these two threads about the ESP-32 causing a bit of confusion.  I had simply posted the part number for the device that I had ordered, then you posted an alternate part number, and then I had to go and check to see what I had in fact ordered, then go back through the two threads to remind myself what devices we were currently discussing.  For some reason I found the entire thing a bit amusing.  It was not in my mind to make fun of or offend anyone.
I can assure you that I am not the average idiot (although I do find myself having a few more "senior moments" these days.)  I have been employed in electronics and computer related industries since the mid '80s and I was an electronics hobbyist for a good decade before that.  I like to think that I have learned a thing or two along the way.
-Carl
-Carl
stanleyella
Posted: 02:04pm 01 Jul 2023
What's an "average idiot"? Is there a scale for eejits like there is for chilli's? :)
ice2642
Posted: 06:49pm 01 Jul 2023
  stanleyella said  What's an "average idiot"? Is there a scale for eejits like there is for chilli's? :)
The common idiot does simpler idiocy, the professional idiot already achieves a higher level of idiocy and there are the virtual idiots who in certain situations emulate a state of idiocy without actually being a constant idiot.
Best regards,
Posted: 08:21pm 01 Jul 2023
My late cat understood about 26.4% of that. Does that make me an idiot?
(Don't answer that.....  ;)  )
stanleyella
Posted: 09:43pm 01 Jul 2023
What's the difference between a duck... one of it's legs are both the same
stanleyella
Posted: 09:55pm 01 Jul 2023
an idiotometer project. how long you took to make sense of that is how much you're an eejit
cicciocb
Posted: 10:18pm 01 Jul 2023
Maybe you are not aware but a basic for the ESP32 exists, with a lot of features.
It works on all the flavors of the ESP32 (including the -c3, -s2 and the -s3) and the support for VGA out is coming
The name is Annex RDS
Posted: 10:23pm 01 Jul 2023
If you can make sense of it, are you at the top or bottom of the scale?
cicciocb
Posted: 10:39pm 01 Jul 2023
Have a look at the help file and you'll be able to answer yourself to the question
Annex32 Help FIle
JohnL
Posted: 04:59am 02 Jul 2023
  cicciocb said  Maybe you are not aware but a basic for the ESP32 exists, with a lot of features.
Definitely has lots of features thanks to great work by Cicciocb.
However, there are issues with bug maintenance and new releases. Its been few months since some bugs have been acknowledged but no fixes or new release updates.
Unfortunately, Cicciocb is a one man band with limited time and Annex basic has very limited licensing for personal hoby use only.
Very little activity on his forum in recent time.
https://cicciocb.com/forum/index.php?sid=a01f6b0f52bfa81f65f8e9ccabac99a4
Perhaps may be worth while considering relaxing licensing and making it open source?
Look at Arduino and Micropython.
Posted: 07:13am 02 Jul 2023
It took me some time, but I finally got Annex RDS onto a ESP32. :) I found the installation very confusing because the help file on the web page is remarkably unhelpful in that respect! I couldn't have installed it at all without help from this forum.
Also, I know there's an awful lot of info in the help file, but the font is very small for those of us with fairly small monitors and very old eyes. Is there a downloadable PDF that I could zoom?
It's very nice being able to program the beast from across the room using a web browser though. :) I like the RDE too, with the same proviso of very small fonts.
It's a very nice BASIC. :)
