Forum Index : Microcontroller and PC projects : MMEdit and Armmite F4
| Glen0 Senior Member Joined: 12/10/2014 Location: New ZealandPosts: 101 |
Just wanting to know which "Mite" type to select from the dropdown in MMEdit when connecting to an Armmite F4. I am running what I believe is the latest Version. 5.1.7 Also can anybody tell me if there is any manual later than DRAFT 5 5.07.00 Beta15 for the Armmite F4 Cheers |
In MMEdit, I would try 'armmite'. As it's mainly cosmetic, it's not critical if a few keywords are wrong. In MMCC it is more significant. If you have a file system, use micromite+, otherwise micromite. That should have all the options set correctly. Jim VK7JH MMedit |
Thanks Jim Much appreciated. Haven't used my Armmite for a while now. I need easy-to-use DAC"s Cheers |
