Local Time 14:42 07 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question regarding Webmite: Direct connection?
shellberight
Posted: 04:15pm 01 Aug 2023
Is it possible to configure Webmite to allow a direct wireless connection?
Example would be to connect my cell phone directly to it to retrieve web browser data without the need to have it connected to a router, then connect to the router, then access the webmite.
THanks
Posted: 04:31pm 01 Aug 2023
The WebMite always runs in station mode. You could probably do what you want by setting your phone as a wireless hotspot and then connecting to it from the webmite
shellberight
Posted: 03:58am 02 Aug 2023
I wasn't sure if Webmite supported the Raspberry Pi Pico Soft Access Point as shown here: https://microcontrollerslab.com/raspberry-pi-pico-w-soft-access-point-web-server-example
Follow up question, does it support html & image objects from a connected SD card?  I don't see it indicated in it's documentation.  I know that the other two versions of the picomite do support an SD card for additional storage.
Posted: 05:58am 02 Aug 2023
Yes
SD card on the WEBmite is no problem.
