Local Time 17:08 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in RGB() command?
George H
Posted: 01:27am 21 Aug 2023
PicoMite MMBasic Version 5.07.08b9
Option Colourcode On
It seems the computed values for red and green are swapped. Or could it be board specific? RGB(255, 0, 0) lights the led green.  RGB(0,255,0) lights it red.
Using the Waveshare RP2040-Matrix board.
Posted: 02:15am 21 Aug 2023
No problem on any of my displays, must  board specific.
What display controller chip does the LCD use?
Check the manual to see if there are special settings for it.
George H
Posted: 02:32am 21 Aug 2023
It's the WS2812.  With a 1-wire interface, not sure how it could be wired wrong - I can work around it but it's strange.
Posted: 04:17am 21 Aug 2023
5.07.08b11
My WS2812 gives the correct colours. A single chip.
Mine needs type O and if I use type B, all I get is white.
It also works correctly on much earlier firmware.
Try both WS2812 types.
Posted: 07:08am 21 Aug 2023
Of course, there's no guarantee that they have used the same version of the WS2812 that we know. There may be other variations.
Posted: 08:40am 21 Aug 2023
This is a classic symptom of incorrect WS2812 timing and nothing to do with the RGB command. As others have said try the different variants and if nothing works then your LED is perhaps faulty of a new variant that the firmware doesn't understand
George H
Posted: 05:42pm 21 Aug 2023
Tried both types (B and O) and same behavior. Found another WS2812 and behavior is normal so I guess it's these little Waveshare boards.
Posted: 06:31pm 21 Aug 2023
  Quote  so I guess it's these little Waveshare boards.
Which board? Please post link. Did you try "S"?
Edited 2023-08-22 04:32 by matherp
Posted: 06:34pm 21 Aug 2023
This one:  LINK
SCHEMATIC
Says it's a WS2812B, but has a mosfet level shifter.
I don't know when the change happened, but at one point the reset pulse time was lengthened from >50us to >280us. That breaks things sometimes. Link
Edited 2023-08-22 04:49 by Mixtel90
barewires
Posted: 07:27am 22 Aug 2023
[code]
#waveshare rp2040-zero-GRBblack-blink.py
#MicroPython v1.19.1-879-g294098d28 on 2023-02-20; Raspberry Pi Pico W with RP2040
#by chatgpt and RS 25022023
import machine
import neopixel
import utime
# set up neopixel LED
NUM_LEDS = 1
np = neopixel.NeoPixel(machine.Pin(16), NUM_LEDS, bpp=3)
green = (128,0,0,255)
red = (0,128,0)
blue = (0,0,128)
black = (0,0,0)
def doneopixel(color):
   np[0] = color  # set LED color
   np.write()     # update LED
   utime.sleep(.1)
# main loop
while True:
   # generate RGB color
   color = red
   doneopixel(color)
   color = green
   doneopixel(color)
   color = blue
   doneopixel(color)
   color = black
   doneopixel(color)
   utime.sleep(1.1)
[/code]
Posted: 07:45am 22 Aug 2023
This is about as simple a test as you can get to identify the LED colours in normal MMBasic. It should work aas expected with standard WS2812B and WS2812 (by changing the B to O). I've not tested this, by the way.
do
 bitbang ws2812 b, gp12, 1, &hCC0000 'red
 pause 500
 bitbang ws2812 b, gp12, 1, &h00CC00 'green
 pause 500
 bitbang ws2812 b, gp12, 1, &h0000CC 'blue
 pause 500
loop
This data sheet indicates that the display order is GRB, not RGB. Note that this data sheet predates the change to >280ms reset time (LINK). MMBasic appears to swap R and G values to make the command compatible with the RGB(rr,gg,bb) format.
(I thought this site was interesting.)
Edited 2023-08-22 18:16 by Mixtel90
Posted: 08:28am 22 Aug 2023
Looks like there is a new variant of the WS2812B, I'll increase the reset pulse in the next beta
Posted: 08:34am 22 Aug 2023
I've not managed to find a newer data sheet. I found a link, but it's dead.
George H
Posted: 07:51pm 22 Aug 2023
Yes, that's the board I'm using, sorry.  They were posted up here a while back.  Thanks for sleuthing the details, Mick.
George H
Posted: 07:52pm 22 Aug 2023
Thanks Peter, when the next release is available I'll give it a try and report back.
Edit: tried 'S', no change.
Edited 2023-08-23 09:21 by George H
George H
Posted: 11:28pm 22 Aug 2023
  Mixtel90 said  This is about as simple a test as you can get to identify the LED colours in normal MMBasic. It should work aas expected with standard WS2812B and WS2812 (by changing the B to O). I've not tested this, by the way.
do
 pause 500
 pause 500
 pause 500
loop
Mick that test gives the same green/red swapped behavior as before.  Also, seems to make no difference whether I use O, S, or B.
I can report that the little board overclocks nicely to 376Mhz.
Posted: 06:56am 23 Aug 2023
T thought it would as it's using the MMBasic RGB translation rather than controlling the WS2812 directly, which would, apparently, use GRB according to the data sheet.
It seems odd that using a "conventional" WS2812B under MMBasic is fine yet this board isn't. The WS2812B's RGB order hasn't changed AFAIK so I can only think that it's a timing issue with those particular devices.
