Forum Index : Microcontroller and PC projects : mmedit prob?
I downloaded @phil99 zip and extracted win 10 then clicked the file and it opened in mmedit as should but try running and no mmedit terminal. I saved the file and opened it again and it worked with the mmedit terminal. can we have the terminal stay on screen longer please.I got to click on icon on tool bar to see my errors:) |
It sounds like you ran the file from Windows Explorer without actually extracting it from the ZIP first. In that case the file you 'run' is in a temporary folder and that causes problems. That's a Microsoft problem, not mine. Jim VK7JH MMedit |
Thanks. I think it was because it was unzipped in downloads and then clicked it and opened mmedit where mmedit saves to docoments/mmbasic programs. I saved the file from mmedit.Re ran mmedit and all was ok. Sorry to bother you. |
