Forum Index : Microcontroller and PC projects : Blit from Flash
vegipete
Posted: 07:57pm 14 Sep 2023
Peter's sample code for copying sprites from CSUB data in flash is very useful.
The MMBasic code
Local y%=yin% * 24 * w%
  Local x%=xin%*12
  Local b%=MM.Info(writebuff)+x%+y%
  Local a%=c%+s%*288
  For yy%=0 To 23
    Memory copy a%, b%,12
    Inc b%,w%
    Inc a%,12
  Next
is remarkable similar to the source code
  start_x1 = x1 + w - max_x;
  start_x2 = x2 + w - max_x;
  while(w > max_x){
    ReadBufferFast(start_x1, y1, start_x1 + max_x - 1, y1 + h - 1, buff);
    DrawBufferFast(start_x2, y2, start_x2 + max_x - 1, y2 + h - 1, -1, buff);
    w -= max_x;
    start_x1 -= max_x;
    start_x2 -= max_x;
at the end of the cmd_blit(void) routine in the file Draw.c
If you squint, there are also similarities with the routine DrawBitmapColour() and the MMBasic command GUI BITMAP.
This blather is a lead-up to wondering if it could be possible to have a variation of the blit command that pulls the source data from a CSUB all in one go.
