Local Time 03:10 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Easy .uf2 file creation?
carlschneider
Posted: 11:54pm 14 Sep 2023
Hi
I notice that some code is being delivered in a .uf2 file as a means of installing the complete package with all supporting files through a simple drag and drop.
XModem in MMEdit is padding transferred files to 128 byte boundaries when transferring in MMCC, which is a problem for some files; such as a javascript file I noticed recently.
TFTP on Windows is a CLI and takes some driving to achieve binary file transfers.
Is there a simple way to wrap all the required files in a .uf2 delivery file to ensure correct delivery of the payload that could be adversely affected by padding?
Guidance would be appreciated
Cheers Carl
Retirement is tough on Hobbies without a day job
Posted: 12:21am 15 Sep 2023
  Quote  XModem in MMEdit is padding transferred files to 128 byte boundaries when transferring in MMCC, which is a problem for some files; such as a javascript file I noticed recently.
XMODEM pads the file whichever program you use to initiate the XMODEM transfer. That's XMODEM - not MMEdit.
If you have installed TFTP and connect to your webmite via Telnet/TCPIP instead of USB, MMEdit's file manager will use TFTP for the transfers instead of XMODEM.
No need to get your hands dirty at the command-line.
One day I might white my own TFTP client and incorporate it into MMEdit.
If you don't use MMEdit but do use Windows, create a batch file with this content, changing the IP address to suit
echo %1
echo %~nx1
tftp -i 10.1.0.232 PUT %1 %~nx1
pause
and place it on your desktop.
You can then drag and drop files onto the desktop icon and transfer to your webmite that way.
carlschneider
Posted: 01:24am 15 Sep 2023
Thanks Jim and noted.
Hopefully that will assist Fred when he does the update.
Cheers Carl
Posted: 06:52pm 15 Sep 2023
  carlschneider said  Is there a simple way to wrap all the required files in a .uf2 delivery file
You need to load all the files onto a Pico first (which is what you are trying to avoid) but for others who want to create a single uf2 file containing everything, this is how I do it:
You need picotools: https://github.com/raspberrypi/picotool.  I had to install a driver using Zadig https://zadig.akeo.ie/ (When it loads just click on InstallDriver even though Driver: will show NONE)
Creating an Image of the Pico Flash is easy (using Windows):
1. Load all the files onto a Pico and set any options
2. Plug the Pico in while holding down BOOTSEL switch.  Same as loading new firmware
3. Run a command window where pocotool.exe is located
4. Run this command: picotool save -a filename.uf2
Posted: 01:32pm 16 Sep 2023
Same command should work on Linux
(That command line is basically a Linux one on Windows.)
Linux normally has the required driver(s) already.
Edited 2023-09-16 23:33 by JohnS
carlschneider
Posted: 12:38am 17 Sep 2023
Thanks Peter, much appreciated.
I note that all files, program memory, flash slots and options need to be setup before the uf2 is created. I’m guessing there are a whole lot of other things being copied to the uf2 that I have not even considered.
It really makes a binary level copy of everything that’s on the Pico and effectively wipes everything that was there before when it is loaded through the BOOTSEL route.
I was wondering if there is a way of embedding some files that could then be written by the bas program to the A: drive? Something like Define Font and Csubs that store data that can then be read and written to a file on the A: drive. That way it doesn’t have to be a uf2 file and the bas program creates its own running environment on first launch at the cost of some bloat.
Thanks for the comments John - I found a brew that loaded the Picotool on the MacBook and have successfully read the Pico contents and saved to a uf2 file.
Cheers Carl
