Forum Index : Microcontroller and PC projects : PicoMite/VGA/WEB V5.07.08 release candidates
| Page 1 of 18 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12252 |
V5.07.08RC1 https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip I think it is time to put V5.07.08 to bed so no more functional changes just fixes for any bugs found. The big ticket things in V5.07.08 are UDP support for the WebMite, Mod file playback for all versions, H/W watchdog, support for regular expressions in the instr and linstr functions (particularly useful for web parsing), and a range of changes to help improve performance for games developers and for plotting data Compared to V5.07.07, 08 has the following detail changes: New functionality WEB TCP SEND cb%, data%() WEB TCP CLOSE cb% OPTION UDP SERVER PORT n WEB UDP INTERRUPT intname WEB UDP SEND addr$, port, data$ OPTION WIFI SSID$, PASSWD$, [NAME$] [,IPADDRESS$, MASK$, GATEWAY$] INSTR([start],text$, search$ [,size]) LIINSTR(text%(),search$ [,start] [,size] PIO DMA TX now accepts 0 for the number of conversions when using a ringbuffer for continuous output PIO DMA RX now accepts 0 for the number of conversions when using a ringbuffer for continuous input ADC RUN array1%(),array2%() OPTION MODBUFF ENABLE/DISABLE [sizeinK] PLAY MODFILE fname$ PLAY MODSAMPLE sampleno, channelno [,volume] WATCHDOG HW OFF WATCHDOG HW nmSec BITBANG WS2812 W, pin, nbr, value%[()] OPTION WEB MESSAGES ON/OFF Implements interlock to stop other ADC use while ADC DMA is running. BLIT WRITE [#]b, x, y [,mode] MM.INFO(ADC DMA) MATH WINDOW in(),min, max, out(),[minfound, maxfound] /* and */ commands for multiline comments BLIT MEMORY address%, x, y[,col] BLIT COMPRESSED address%, x, y[,col] BLIT FRAMEBUFFER F/L/N, F/L/N, xfrom, yfrom, xto, yto, width, height [,col] EDIT fname$ Bug Fixes MM.INFO(OPTION ANGLE) returns an incorrect value. Fixed in V5.07.08b5 FORMAT$ function may not yield expected results (WebMite only). Waiting for SDK change Minor bugs in CALL and MM.CMDLINE$. Fixed in V5.07.08b5 LOAD SPRITE requires exact spacing of the width,number,height fields. Fixed in V5.07.08b5. Changing volume when PLAY TONE is playing the same on both channels causes one channel to disappear. Fixed in V5.07.08b5. A TCP request while in the editor causes the WebMite to crash. Fixed in V5.07.08b5. Memory leak in WEB MQTT PUBLISH. Fixed in V5.07.08b5. EXECUTE command does not work at the command prompt. Fixed in V5.07.08b5. CLS after NEW when a framebuffer is active can crash system. Fixed in V5.07.08b5. Using EXECUTE in a program that has been AUTORUN crashes the system. Fixed in V5.07.08b5. Bug in FRAMEBUFFER COPY to N. Fixed in V5.07.08b7 Bug in FRAMEBUFFER CLOSE. Fixed in V5.07.08b7 Race condition when PLAY TONE is used with defined time and a new tone is issued during the termination. Fixed in V5.07.08b8 Fixes various bugs in ADC use after ADC DMA conversions. Fixes bug in PIN(TEMP) after another ADC channel is used. Fixes bug in PIO assemble Fixes bugs in BLIT WRITE when target overlaps the screen Fixes bug in web transmit page when the size of included variables exceeds the size of the html file by a margin |
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 739 |
Thank you Peter |
| carlschneider Senior Member Joined: 04/08/2023 Location: South AfricaPosts: 158 |
Thanks for all your efforts Peter, much appreciated. Cheers Carl Retirement is tough on Hobbies without a day job |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3891 |
Amazing. What a terrific body of work. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Thank you ,its great ![]() Plasma |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4410 |
+2 MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| IanRogers Senior Member Joined: 09/12/2022 Location: United KingdomPosts: 152 |
Aww! I only just updated with b17. Thanks anyway. I'd give my left arm to be ambidextrous |
Hi Peter My understanding from previous comments made by others is that there were problems with the Tick's. I also understand that this was addressed and resolved. Could I trouble you to provide a brief synopsis of what the problem was/how it manifested? I have a situation where the Tick’s appear to no longer interrupt after a period of working fine. Or are the Tick interrupts non latching and of short duration and could get lost in the priority order of the interrupt servicing routines at the core code level? Cheers Carl Retirement is tough on Hobbies without a day job |
| vegipete Guru Joined: 29/01/2013 Location: CanadaPosts: 1196 |
Working good so far. Great work! Edited 2023-09-20 16:03 by vegipete Visit Vegipete's *Mite Library for cool programs. |
| pwillard Guru Joined: 07/06/2022 Location: United StatesPosts: 347 |
Agreed. I'm not having any issues. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6276 |
@Peter, In case we want to use the library to store tiles and sprites in CSUB, this is command line work. LIBRARY SAVE cannot be executed from withing a program, nor from a FLASH SLOT (tried it). It would be nice to have a virgin pico, insert a SD card, and run a single program (without any command line typing) and the pico initializes the library. Is there any way to pull this off ? MM.STARTUP ?? Or are we stuck with manual filling the library. Volhout PicomiteVGA PETSCII ROBOTS |
@Peter, Using picomiteVGAV50708RC1 program memory on the VGA is 100k I have a file size 80k on disk, that contains compressed tile data as CSUB (using your program to generate them). When I load this file, I get "not enough memory" error. In the editor, it feels the whole file is correctly in memory. But when I do a library save, nothing gets in the library, and "memory" gives 0 byte in program memory. tile1_csub.zip Volhout EDIT: A file size 62k loads correctly. PicomiteVGA PETSCII ROBOTS |
I always reset the options cos thought they got erased when flashing new firmware but seems to remember?? option list PicoMite MMBasic Version 5.07.08RC1 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION AUTORUN ON OPTION CPUSPEED (KHz) 378000 OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13 OPTION TOUCH GP12,GP11 GUI CALIBRATE 0, 3888, 3842, -897, -655 OPTION SDCARD GP22 OPTION AUDIO GP0,GP1, ON PWM CHANNEL 0 > |
Yes: The CSUb ends up with two copies, the ascii and the binary. This is why csub/fonts etc. should be loaded into the library before the main program is loaded |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1162 |
Volhout, It is probably not exactly what you are after but this may gives some ideas for using programmed function keys to simplify saving the library. Simple scripting MMbasic Gerry F4 H7FotSF4xGT |
| Bernie3D Newbie Joined: 02/08/2023 Location: United StatesPosts: 20 |
Thanks Peter for all. Do you ever sleep? |
Thanks for the tip. I was aware of the function keys. They are helpfull with development, but this is not usefull for the game roll out. At the moment this has to happen Load "file1 Library save Load "file2 Library save Load "file3 Library save Load "file4 Library save Load "game Run Edited 2023-09-21 15:38 by Volhout PicomiteVGA PETSCII ROBOTS |
| TheMonkeys Regular Member Joined: 15/12/2022 Location: AustraliaPosts: 59 |
🤔🤔🤔 Hmmm... A little weirdness. Since upgrading from V5.0707B11 to V5.07.08RC1 this morning, I'm copping a watchdog every 36 minutes. I re-uploaded the basic code, but no change. Have I missed something? On the third occasion, I was watching. Both my heartbeats froze, then after my 20 second timeout, it (webmite) re-booted, as expected. from my logfile: 21-09-2023 started@10:04:15 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10 (***installed V5.07.08RC1) 10:04:15 dat/activity.log: 3 rotates 10:04:57 0: Rename "update.bas" As ".trash/update.bas" 10:05:15 0: Kill ".trash/update.bas" 10:14:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011 21-09-2023 started@10:17:09 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10 10:29:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011 21-09-2023 dogged@10:38:40 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10 10:39:58 #Config: ts:3 sp:23 dog:20 debug:11 10:44:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011 10:59:10 Schedule: heater on [setHeater(2)] 10:59:52 State: tmax=31.3 tmin=28 ts:3 tstat=30 debug=&B1011 11:02:10 Schedule: heater off [setHeater(1)] 11:05:10 Schedule: heater auto [setHeater()] 21-09-2023 dogged@11:14:49 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10 11:14:52 State: tmax=31.3 tmin=28 ts:3 tstat=30 debug=&B11 11:20:52 #Config: ts:3 sp:23 dog:20 debug:3 11:21:04 #Config: ts:3 sp:23 dog:20 debug:11 11:29:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011 21-09-2023 started@11:38:28 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***small edit to init code) 11:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 11:45:36 0: Rename "update.bas" As ".trash/update.bas" 11:45:52 0: Kill ".trash/update.bas" 21-09-2023 dogged@11:50:55 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 11:54:44 #Config: ts:3 sp:23 dog:20 debug:11 11:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 12:07:21 2:indexing dom 12:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 21-09-2023 dogged@12:27:04 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 12:27:47 #Config: ts:3 sp:23 dog:20 debug:11 12:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 12:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 12:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 21-09-2023 dogged@13:03:12 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***froze@13:02:45) 13:05:54 #Config: ts:3 sp:23 dog:20 debug:11 13:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 13:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 21-09-2023 dogged@13:39:18 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 13:43:57 #Config: ts:3 sp:23 dog:20 debug:11 13:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 13:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 14:05:10 rembeg: 14:05 remend: 15:05 remdur: 60 14:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60 21-09-2023 dogged@14:15:27 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 14:18:26 #Config: ts:3 sp:23 dog:20 debug:11 14:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60 14:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60 21-09-2023 dogged@14:51:35 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***froze@14:51:09) 14:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B11 remend:905 remdur:60 15:02:12 #Config: ts:3 sp:23 dog:20 debug:11 15:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 21-09-2023 started@15:28:40 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40(***froze@15:27:17) ***froze completely - USB restart 21-09-2023 started@15:30:22 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 Any suggestions? Cheers, Chris |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3453 |
If no one comes up with anything better... As you have upgraded a full version number it may be worth saving Options, Program, Flash slots and A: then applying Clear_flash.uf2 and reloading it all. |
Hi Phil, Oops, my miss-type. It was V5.0708B11 Cheers, Chris. |
| Page 1 of 18 |
