Forum Index : Microcontroller and PC projects : Raspberry Pi 5.....
Latest model.... PI5... Please note the RP1 chip on this board.... Smoke makes things work. When the smoke gets out, it stops! |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
Key features include: 2.4GHz quad-core 64-bit Arm Cortex-A76 CPU VideoCore VII GPU, supporting OpenGL ES 3.1, Vulkan 1.2 Dual 4Kp60 HDMI® display output 4Kp60 HEVC decoder Dual-band 802.11ac Wi-Fi® Bluetooth 5.0 / Bluetooth Low Energy (BLE) High-speed microSD card interface with SDR104 mode support 2 × USB 3.0 ports, supporting simultaneous 5Gbps operation 2 × USB 2.0 ports Gigabit Ethernet, with PoE+ support (requires separate PoE+ HAT, coming soon) 2 × 4-lane MIPI camera/display transceivers PCIe 2.0 x1 interface for fast peripherals Raspberry Pi standard 40-pin GPIO header Real-time clock Power button 'no comment |
Good video! :) Unfortunately, by the time you've included the new PSU and cooler (probably obligatory if you want to get any real work out of it) then the price is going to be far closer to £100 (if not more) than £80. That's pushing things a bit. Edited 2023-09-28 18:46 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
I dont know if they are technically still state-of-the-art. for ~120€ you can buy a refurbished Lenovo ThinkCentre M700 Tiny With Power suply, Case , i5-6500T, 8 GB ,240 GB SSD,Win 10 Pro. this is cheaper than the PI, where you have to buy housing, power supply and external memory 'no comment |
For some reason Raspberry Pi haven't shown any interest in what is probably the best version of the Pi to date... :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Well you know what it's like, other people always think they can do better .Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
This is true... ![]() Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
The problem being the O.S. ............ my site |
Good question (for audio work) my site |
Apparently The Register have played with a Pi 5 and, without a cooler, couldn't get it to run hotter than 80C. The chip is more efficient so a cooler may not always be needed. Audio is now only via a USB DAC as the 3.5mm audio jack has been removed. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
rpi 400 is not as good as an optiplex £80 mini pc same for rpi 5. alternatives for price and not linux. I think a refurb lenovo or dell better. ok it's a small board but add kb, mouse, psu and monitor |
