Local Time 18:20 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Adding features to Maximite Control Center
EDNEDN
Posted: 01:40am 02 Oct 2023
Is it possible to add features to the Maximite Control Center?
I was looking for the source tree on-line but I haven't found it yet.
Posted: 03:12am 02 Oct 2023
I have not made the source of MMEdit and MMCC available and have no desire to.
I have usually been open to suggestions for improvement.
EDNEDN
Posted: 08:30pm 04 Oct 2023
I'm having problems with Maximite Control Center's VT-100 emulation.
Most things work pretty reasonably.   But the save and restore cursor functions are sick.   Specifically:
savecursor DECSC      Save cursor position and attributes    ^[7
restorecursor DECRC   Restore cursor position and attributes ^[8
Besides the fact the save of the cursor doesn't work, the restore cursor function causes some problem where key strokes are no longer seen or echoed after the restore is issued.
Terra Term works correctly.   Here is a little test program that works correctly on Terra Term but fails running with the Maximite Control Center.   All of the text (with different character attributes) after the "Hello again" should get erased.
But it doesn't....
init_screen()
 clear_screen()
 Print "Hello world."
 for x=1 to 20
   for y=1 to x
     print "  ";
   next y
   print "Doing a print loop with a long line..........."
 next x
 for g=1 to 20
   goto_xy(80-g, g)
   print g;
 next g
 goto_xy(10, 25)
 print "Hello again ";
 save_cursor()
 bold_on()
 print "Bold ";
 char_attr_off()
 Print "and_off  ";
 low_intesity()
 print "low_intensity ";
 char_attr_off()
 underline_on()
 print "Underline ";
 char_attr_off()
 blinking_on()
 print "Blink ";
 char_attr_off()
 underline_on()
 print "Reverse ";
 char_attr_off()
 print "all done"
 print
 print "more text prior to the cursor restore."
 print
 pause 500
 restore_cursor()
 print "        "
 print
 print
 print
 print
 print
end
sub init_screen()
 'print Chr$(27);"[?3l";                          ' 80  columns
 'print Chr$(27);"[?3h";                          ' 132 columns
 'char_attr_off()
End Sub
sub goto_xy(x,y)
 print Chr$(27);"["; format$(y,"%-1g"); ";"; format$(x,"%-1g"); "H";
end sub
sub char_attr_off()
 print Chr$(27);"[m";
end sub
sub bold_on()
 print Chr$(27);"[1m";
end sub
sub low_intesity()
 print Chr$(27);"[2m";
end sub
sub underline_on()
 print Chr$(27);"[4m";
end sub
sub blinking_on()
 print Chr$(27);"[5m";
end sub
sub reverse_video()
 print Chr$(27);"[7m";
end sub
sub save_cursor()
 print Chr$(27);"7";
end sub
sub restore_cursor()
 print Chr$(27);"8";
end sub
sub clear_screen()
 goto_xy(1,1)
 print Chr$(27);"[2J";
end sub
Edited 2023-10-05 07:32 by EDNEDN
Posted: 09:20pm 04 Oct 2023
MMCC was never intended to be a replacement for TeraTerm (or any other decent dedicated terminal program)
It will never implement the full set of escape sequences.
I can include save/restore cursor position but not the attributes, that would be beyond the scope of MMCC.
EDNEDN
Posted: 09:39pm 04 Oct 2023
I understand!    Just getting the Save and Restore of cursor position into it would help a lot.    I'm playing around with making a BASIC debugger and need to go off to a corner of the screen to display stuff, and then when the next line of code is executed (interpreted) the cursor needs to be moved back to wherever it was.
Because MMEdit and MaxiMite Control Center are so heavily used, it would be best to do the work within that context and not force people to bring up Terra Term.
Posted: 09:55pm 04 Oct 2023
I used a little ANSI routine to simulate "PRINT@" to allow me to print a string at a defined X and Y position. It's easier than reading the values back, which not all ANSI systems support anyway.
Abbreviated library functions:
' Vcls            clear screen
' Vch             cursor home to top left
' Vat row col     move cursor to row,column
' Vbox x,y,w,h,t  draw a box width w height h at x,y using 'Terminal' font box characters.
'                 t=0 for single line, 1 for double
' Vl y,x,l,t      draw a horizotal or vertical line to divide a box.
'                 l is length, t=0 for single line, 1 for double, negative for horizontal
' Vatt n$         set text attributes to n$ - none b /b in /in low u /u
'                 (none,bold,inverse,low_intensity,underlined)
' Vfc n$          set text/foreground colour by name or str$(number) 0-15
' Vbc n$          set background colour by name or str$(number) 0-16 (16 is light grey)
'                 Colours names are black, red, green, yellow, blue, magenta, cyan, white, grey
' ch              print the Escape sequence 'Chr$27 [' - used internally"
Sub ch:Print Chr$(27);"[";:End Sub
Sub Vcls:ch:Print "2J";:End Sub
Sub Vch:ch:Print "H";:End Sub
Sub Vat(row,col)
Local vz$
vz$=Str$(row)+";"+Str$(col)+"H":ch:Print vz$;
End Sub
Sub Vfc(color$)  'set text foreground colour
Local vz$        'if we have a colour number 0-15 then use it
If Len(color$)<3 And Val(color$)<16 Then
 vz$="38;5;"+color$+"m"
 ch
 Print vz$
Else
 ch
 Select Case LCase$(color$)  'otherwise use the colour name
  Case "black":Print "30m";
  Case "red":Print "31m";
  Case "green":Print "32m";
  Case "yellow":Print "33m";
  Case "blue":Print "34m";
  Case "magenta":Print "35m";
  Case "cyan":Print "36m";
  Case "white":Print "37m";
  Case "grey","gray":Print "90m";
 End Select
EndIf
End Sub
Sub Vbc(color$)  'set text background colour
 vz$="48;5;"+color$+"m"
 ch
 Print vz$
ElseIf Val(color$)=16 Then
 vz$="48:2:115:115:115m"
 ch
 Print vz$
Else
 ch
  Case "black":Print "40m";
  Case "red":Print "41m";
  Case "green":Print "42m";
  Case "yellow":Print "43m";
  Case "blue":Print "44m";
  Case "magenta":Print "45m";
  Case "cyan":Print "46m";
  Case "white":Print "47m";
  Case "grey","gray":Print "100m";
  Case Else :Print "39m"; 'default background
 End Select
EndIf
End Sub
Posted: 11:28pm 04 Oct 2023
I will update the programs later today.
They will have cursor position save/restore only.
EDNEDN
Posted: 11:36pm 04 Oct 2023
  TassyJim said  I will update the programs later today.
Thank You very much!
Posted: 04:03am 05 Oct 2023
MMCC has been updated.
EDNEDN
Posted: 02:12pm 05 Oct 2023
And Cursor Save/Restore is confirmed to be working for me.
Thank You!
