Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Amiga Basic for the CMM2
RicM
Posted: 12:21am 06 Nov 2023
Dear Members,
Is is possible in import Amiga Basic over to the CMM2 without using the Kickstart Roms
Kind Regards,
RicM
Posted: 09:21am 06 Nov 2023
Why put an inferior BASIC onto a CMM2?  ;)
No. AFAIK you couldn't do it *with* the ROMS either.
Posted: 09:35am 06 Nov 2023
What are you actually trying to achieve @RicM, do you specifically want Amiga Basic (presumably AmigaBASIC) running on the CMM2 (I can confidently say "not a chance"), or do you have a particular Amiga Basic program that could be ported to MMBasic in order to run on the CMM2 ?
Edited 2023-11-06 23:47 by thwill
Martin H.
Posted: 11:48am 06 Nov 2023
with or without the Kickstart roms ..
Amiga Software (Kick start is also a Software) is based on Motorola 680xx CPUand written for the Chipset, which is build in to the Amiga.
Without an Emulation, even modern PC cannot run Amiga Software.
SO no, it couldn't run on CMM2.
The only option would be to port/translate the Amiga Basic program to MM Basic. And even that requires comprehensive knowledge of both systems
Edited 2023-11-06 21:55 by Martin H.
'no comment
hitsware2
Posted: 04:01pm 06 Nov 2023
For certain purposes , Amiga Basic was far
ahead of MMBasic . Musical ability for sure .....
( though that ability may have depended on the
Paula chip )
my site
Posted: 04:31pm 06 Nov 2023
The best way to get AmigaBasic to run on the cheap, and without the Kickstarter ROMs is probably to run ARM port of AROS Research Operating System on a Raspberry Pi or the X86 version on a PC. This is legal as the ROMs aren't involved. I've only found this through research, I've not tried it.
Martin H.
Posted: 04:44pm 06 Nov 2023
Paula chip )
A different Basic doesn't replace the Hardware, it is running on, so the CMM2 doesn'tget a PAULA Chip by installing a Software
Amiga Basic
'no comment
darthvader
Posted: 10:38pm 06 Nov 2023
Best for you RicM is just to emulate the A500.
You can do it with the Teensy 4.1 , it work very well ;)
And if you like other 'old' basic you can emulate couple of other 'old' computer too on the same board.
TeensyUAE emulator
PeteCotton
Posted: 11:24pm 06 Nov 2023
Slightly off topic - but did you ever try AMOS?
I used to love Amiga BASIC back in the day, however it was very slow (despite running on a beast of a computer for the era). I quickly moved on to AMOS - a third party Amiga BASIC.
The publisher is still around and has a Windows based Dev environment (AOZ Studio) that can actually compile for the Amiga (or so I believe - I've never tried doing that).
It might be interesting if you are dabbling with an Amiga emulator.
https://www.aoz.studio/the-aoz-story
stanleyella
Posted: 03:32pm 07 Nov 2023
I remember amiga cost £400 ,atari st, same games but not as good, £300 but midi interface. lot of money then.
Martin H.
Posted: 03:37pm 07 Nov 2023
  RicM said  Dear Members,
Kind Regards,
RicM
maybe it would be the best way, du Use Amiberry  on a Raspberry Pie
and run AmigaBasic there
Edited 2023-11-08 01:40 by Martin H.
'no comment
