Forum Index : Microcontroller and PC projects : How to Transfer Files to Picomite.
Dinosaur![]() Guru Joined: 12/08/2011 Location: AustraliaPosts: 357 |
Hi All I am finding it difficult to get a smooth file transfer and run procedure in MMEdit & MMCC to the Picomite. As always the simple things are the hardest to find. Environment:Linux Debian 12, Minicom Terminal Emulator. So, the steps are. 1.Open Minicom after having preset settings first. Picomite goes to prompt. 2.Open MMEdit and make any changes to the program I want to send to the Picomite. In MMEdit 3.Run in Terminal Does nothing at all. 4.Deploy (whatever that is) Does nothing at all Help file shows blank page on Deploy. 5.Start MMCC seperately (perhaps deploy was meant to do that ?) 6.Select Mode/File Manager. 7.In MMCC select file to send. 8.Press >>> button I get a small Notice window with no text in it and it can't be enlarged and disappears after 3 or 4 seconds. Terminal emulator window shows "XModem Receive "MyFile.bas" (so that proves the link) MCC window shows Connected, sending 1 File, processing file:.... Blocks 6, Transfer failed to start! Finished Terminal Emulator window shows Error: Remote did not respond. Can someone please correct me where I am going wrong. The ideal scenario is: I edit program, I send program to Picomite, I run program in Picomite all from within MMEdit. Two windows would be open, The terminal Emulator and MMEdit. Am I being to ambitious ? Regards Hervey Bay Qld. |
| Andy-g0poy Regular Member Joined: 07/03/2023 Location: United KingdomPosts: 85 |
There is no real need for minicom. (if you need a terminal emulator putty is available for linux, and is quite a bit better than minicom) run MMCC connect to the pico Fromm the three dropdowns select picomite , ttyAMC0 (or whatever your com port is) , 9600 Click on the connect button to the right of the target string. In the console area you should see connected. hit return a few times and you should see the > prompt That's your system talking to the pico run MMEDIT load your program as normal, and edit. To send to the pico click the last icon on the toolbar (green and red arrow) The MMCC terminal will show progress such as: connected- 127.0.0.1 Control /mnt/rusty/primary/Development/Raspberry-Pi-Pico/Pico-Programs/SI5353/SI5351-test.bas Uploading using: 'target port\ttyACM0:9600 s\picomite Upload started NEW > AUTOSAVE Upload completed 1 Saved 7911 bytes > Time taken: 7478mS RUN Thats it job done The menu item Action > deploy (or hit F2) does the same. Andy |
Hi All Andy, that worked straight of. Like I said the simplest things are hardest to find. But now it is listed here for someone else that uses the same search string. Many thanks for that. Regards Hervey Bay Qld. |
Hi All Happy with that, but would have liked Alt Key access to Menu's etc. I am so used to pressing Alt keys whilst typing code, that grabbing the mouse to open the file Menu is a hard habit to get used to. Particularly when I still use Geany a lot. Regards Hervey Bay Qld. |
MMEdit Help menu MM Edit help Using MMEdit and you will find the first steps for running programs. While you are in the Help. Under reference Keyboard shortcuts. Worth a read. VK7JH MMedit |
Hi All Thanks for that, but I had already been there AND no reference to Alt key mapping. Regards Hervey Bay Qld. |
Ctrl-O to open ctrl-S to save <F2> to 'load and run' VK7JH MMedit |
Hi All That's not exactly the time honoured Alt f for File menu Alt e for edit Alt t for cut etc Regards Hervey Bay Qld. |
