Forum Index : Microcontroller and PC projects : MMBasic for Windows: Weird mode 12 behaviour
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
Hello everyone I'm trying to understand why page 0 stops rendering after a cls. I'm using the last version shared by matherp. Steps to reproduce: 1) Save in a file and run the following code: mode 7,12 font 1 page write 0 print @(100,0) "Hello page 0" print @(100,32) "Hello page 0 - "+str$(int(rnd()*100)) page write 1 print @(100,16) "Hello page 1" print @(100,48) "Hello page 1 - "+str$(int(rnd()*100)) It will print four lines with the Hello page X text. 2) Type CLS in the basic console 3) Run the code again Only the text from page 1 will be rendered. It's necessary to restart the MMBasic environment to make page 0 work again. Did I miss something? Edited 2023-11-26 13:46 by LeoNicolas |
I'm running MMBasic on Wine, I don't know if it could be the cause. Please, let me know if the problem is happening in your computers. The cls command can be inside the program as well. The same behaviour will manifest. The is a problem for my game because I can't clear the pages 0 and 1 before starting the stage. If I do it, I completely lose the page 0. |
Not near a computer for a few days but try "CLS 0" |
Thank you matherp. "cls 0" works fine but "cls 1" is not clearing the page 1. Edited 2023-11-27 04:31 by LeoNicolas |
The number after CLS is a colour, not a page number. Visit Vegipete's *Mite Library for cool programs. |
Thank you vegipete I'd assumed wrong. |
