Forum Index : Microcontroller and PC projects : OPTION AUTORUN ON
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 1954 |
Most of the options are set from the command prompt but can AUTORUN be part of the code? |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
> list Option AUTORUN off > run > option list PicoMite MMBasic Version 5.07.08RC21 OPTION SYSTEM SPI GP6,GP3,GP4 OPTION CPUSPEED 252000 'KHz OPTION DISPLAY 28, 80 OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0 OPTION TOUCH GP5,GP7 GUI CALIBRATE 0, 368, 294, 882, 666 OPTION SDCARD GP22 OPTION AUDIO GP20,GP21', ON PWM CHANNEL 2 OPTION MODBUFF ENABLE Saved 20 bytes > list Option AUTORUN 1 > run > option list PicoMite MMBasic Version 5.07.08RC21 OPTION SYSTEM SPI GP6,GP3,GP4 OPTION AUTORUN 1 OPTION CPUSPEED 252000 'KHz OPTION DISPLAY 28, 80 OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0 OPTION TOUCH GP5,GP7 GUI CALIBRATE 0, 368, 294, 882, 666 OPTION SDCARD GP22 OPTION AUDIO GP20,GP21', ON PWM CHANNEL 2 OPTION MODBUFF ENABLE -- > list Option AUTORUN on > RUN > option list PicoMite MMBasic Version 5.07.08RC21 OPTION SYSTEM SPI GP6,GP3,GP4 OPTION AUTORUN ON OPTION CPUSPEED 252000 'KHz OPTION DISPLAY 28, 80 OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0 OPTION TOUCH GP5,GP7 GUI CALIBRATE 0, 368, 294, 882, 666 OPTION SDCARD GP22 OPTION AUDIO GP20,GP21', ON PWM CHANNEL 2 OPTION MODBUFF ENABLE so, yes it can be part of the Program Edited 2023-12-05 05:25 by Martin H. 'no comment |
I only used autorun on in a program. I was told only to use it when the code was debugged.. whenever that is but it's great if you can't remember what a board did :) |
I think that might be what comments are for, Stan. :) The advice not to use it until your code is working is good. Especially if you change Break too.... Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
