Forum Index : Microcontroller and PC projects : # big font
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 627 |
Hi there, does anyone know how to read the bits (pixels) from the fonts in picomite? For example to print big characters with "#" (like on printers in the past ...) or to display a letter on the 8x8led ;-) # # # # ###### # ##### ### ##### ## ## ## ## # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # ###### # # ##### # # # # # # # # ####### # # # # # # # # # # # # # # # # # # # # ###### # # ##### ### ##### |
If your display is suitable, Print the text to the display then use the PIXEL function to read each pixel. Jim VK7JH MMedit |
MM.INFO(FONT ADDRESS n) Returns the actual address of the memory location containing the start of the binary data defining FONT n Then PEEK(BYTE addr%) to access the data. The data looks like this. First four byte define the fontwidth,fontheight,first charcter in data, number of characters in font , the data then follows. const unsigned char F_6x8_LE[580] = { 0x06,0x08,0x20,0x60, 0x00,0x00,0x00,0x00,0x00,0x00, // Chr$(32) 0x20,0x82,0x08,0x00,0x82,0x00, // Chr$(33) ! 0x51,0x45,0x00,0x00,0x00,0x00, // Chr$(34) " 0x51,0x4F,0x94,0xF9,0x45,0x00, // Chr$(35) # 0x21,0xEA,0x1C,0x2B,0xC2,0x00, // Chr$(36) $ 0x00,0x69,0x90,0x20,0x4C,0xB0, // Chr$(37) % 0x62,0x4A,0x10,0xAA,0x46,0x80, // Chr$(38) & 0x60,0x84,0x00,0x00,0x00,0x00, // Chr$(39) ' 0x10,0x84,0x10,0x40,0x81,0x00, // Chr$(40) ( 0x40,0x81,0x04,0x10,0x84,0x00, // Chr$(41) ) 0x00,0x8A,0x9C,0xA8,0x80,0x00, // Chr$(42) * 0x00,0x82,0x3E,0x20,0x80,0x00, // Chr$(43) + 0x00,0x00,0x00,0x30,0x42,0x00, // Chr$(44) , 0x00,0x00,0x3E,0x00,0x00,0x00, // Chr$(45) - 0x00,0x00,0x00,0x01,0x86,0x00, // Chr$(46) . 0x00,0x21,0x08,0x42,0x00,0x00, // Chr$(47) / 0x72,0x29,0xAA,0xCA,0x27,0x00, // Chr$(48) 0 0x21,0x82,0x08,0x20,0x87,0x00, // Chr$(49) 1 0x72,0x20,0x84,0x21,0x0F,0x80, // Chr$(50) 2 0xF8,0x42,0x04,0x0A,0x27,0x00, // Chr$(51) 3 0x10,0xC5,0x24,0xF8,0x41,0x00, // Chr$(52) 4 0xFA,0x0F,0x02,0x0A,0x27,0x00, // Chr$(53) 5 0x31,0x08,0x3C,0x8A,0x27,0x00, // Chr$(54) 6 0xF8,0x21,0x08,0x41,0x04,0x00, // Chr$(55) 7 0x72,0x28,0x9C,0x8A,0x27,0x00, // Chr$(56) 8 0x72,0x28,0x9E,0x08,0x27,0x00, // Chr$(57) 9 0x01,0x86,0x00,0x61,0x80,0x00, // Chr$(58) : 0x01,0x86,0x00,0x60,0x84,0x00, // Chr$(59) ; 0x10,0x84,0x20,0x40,0x81,0x00, // Chr$(60) < 0x00,0x0F,0x80,0xF8,0x00,0x00, // Chr$(61) = 0x40,0x81,0x02,0x10,0x84,0x00, // Chr$(62) > 0x72,0x20,0x84,0x20,0x02,0x00, // Chr$(63) ? 0x72,0x20,0x9A,0xBA,0x27,0x00, // Chr$(64) @ 0x72,0x28,0xA2,0xFA,0x28,0x80, // Chr$(65) A 0xF2,0x28,0xBC,0x8A,0x2F,0x00, // Chr$(66) B 0x72,0x28,0x20,0x82,0x27,0x00, // Chr$(67) C 0xE2,0x48,0xA2,0x8A,0x4E,0x00, // Chr$(68) D 0xFA,0x08,0x3C,0x82,0x0F,0x80, // Chr$(69) E 0xFA,0x08,0x3C,0x82,0x08,0x00, // Chr$(70) F 0x72,0x28,0x2E,0x8A,0x27,0x80, // Chr$(71) G 0x8A,0x28,0xBE,0x8A,0x28,0x80, // Chr$(72) H 0x70,0x82,0x08,0x20,0x87,0x00, // Chr$(73) I 0x38,0x41,0x04,0x12,0x46,0x00, // Chr$(74) J 0x8A,0x4A,0x30,0xA2,0x48,0x80, // Chr$(75) K 0x82,0x08,0x20,0x82,0x0F,0x80, // Chr$(76) L 0x8B,0x6A,0xAA,0x8A,0x28,0x80, // Chr$(77) M 0x8A,0x2C,0xAA,0x9A,0x28,0x80, // Chr$(78) N 0x72,0x28,0xA2,0x8A,0x27,0x00, // Chr$(79) O 0xF2,0x28,0xBC,0x82,0x08,0x00, // Chr$(80) P 0x72,0x28,0xA2,0xAA,0x46,0x80, // Chr$(81) Q 0xF2,0x28,0xBC,0xA2,0x48,0x80, // Chr$(82) R 0x7A,0x08,0x1C,0x08,0x2F,0x00, // Chr$(83) S 0xF8,0x82,0x08,0x20,0x82,0x00, // Chr$(84) T 0x8A,0x28,0xA2,0x8A,0x27,0x00, // Chr$(85) U 0x8A,0x28,0xA2,0x89,0x42,0x00, // Chr$(86) V 0x8A,0x28,0xAA,0xAA,0xA5,0x00, // Chr$(87) W 0x8A,0x25,0x08,0x52,0x28,0x80, // Chr$(88) X 0x8A,0x28,0x94,0x20,0x82,0x00, // Chr$(89) Y 0xF8,0x21,0x08,0x42,0x0F,0x80, // Chr$(90) Z 0x71,0x04,0x10,0x41,0x07,0x00, // Chr$(91) [ 0x02,0x04,0x08,0x10,0x20,0x00, // Chr$(92) backslash 0x70,0x41,0x04,0x10,0x47,0x00, // Chr$(93) ] 0x21,0x48,0x80,0x00,0x00,0x00, // Chr$(94) ^ 0x00,0x00,0x00,0x00,0x0F,0x80, // Chr$(95) _ 0x00,0xC4,0x8C,0x00,0x00,0x00, // Chr$(96) ` 0x00,0x07,0x02,0x7A,0x27,0x80, // Chr$(97) a 0x82,0x0B,0x32,0x8A,0x2F,0x00, // Chr$(98) b 0x00,0x07,0x20,0x82,0x27,0x00, // Chr$(99) c 0x08,0x26,0xA6,0x8A,0x27,0x80, // Chr$(100) d 0x00,0x07,0x22,0xFA,0x07,0x00, // Chr$(101) e 0x31,0x24,0x38,0x41,0x04,0x00, // Chr$(102) f 0x01,0xE8,0xA2,0x78,0x27,0x00, // Chr$(103) g 0x82,0x0B,0x32,0x8A,0x28,0x80, // Chr$(104) h 0x20,0x06,0x08,0x20,0x87,0x00, // Chr$(105) i 0x10,0x03,0x04,0x12,0x46,0x00, // Chr$(106) j 0x82,0x09,0x28,0xC2,0x89,0x00, // Chr$(107) k 0x60,0x82,0x08,0x20,0x87,0x00, // Chr$(108) l 0x00,0x0D,0x2A,0xAA,0x28,0x80, // Chr$(109) m 0x00,0x0B,0x32,0x8A,0x28,0x80, // Chr$(110) n 0x00,0x07,0x22,0x8A,0x27,0x00, // Chr$(111) o 0x00,0x0F,0x22,0xF2,0x08,0x00, // Chr$(112) p 0x00,0x06,0xA6,0x78,0x20,0x80, // Chr$(113) q 0x00,0x0B,0x32,0x82,0x08,0x00, // Chr$(114) r 0x00,0x07,0x20,0x70,0x2F,0x00, // Chr$(115) s 0x41,0x0E,0x10,0x41,0x23,0x00, // Chr$(116) t 0x00,0x08,0xA2,0x8A,0x66,0x80, // Chr$(117) u 0x00,0x08,0xA2,0x89,0x42,0x00, // Chr$(118) v 0x00,0x08,0xA2,0xAA,0xA5,0x00, // Chr$(119) w 0x00,0x08,0x94,0x21,0x48,0x80, // Chr$(120) x 0x00,0x08,0xA2,0x78,0x27,0x00, // Chr$(121) y 0x00,0x0F,0x84,0x21,0x0F,0x80, // Chr$(122) z 0x10,0x82,0x10,0x40,0x82,0x04, // Chr$(123) { 0x20,0x82,0x00,0x20,0x82,0x00, // Chr$(124) | 0x20,0x41,0x02,0x08,0x41,0x08, // Chr$(125) } 0x00,0x04,0xAA,0x90,0x00,0x00, // Chr$(126) ~ 0x00,0x02,0x14,0x8B,0xE0,0x00 // Chr$(127) }; Gerry F4 H7FotSF4xGT |
Interesting. read pixel ok but thought read character set as said. |
