Local Time 18:12 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "Input" command cause trouble
Hansaplast
Posted: 03:39am 15 Dec 2023
Is there is any mistake by me (PICOMITE)?
Try this:
PRINT "Input Power ON Time (HHMMSS): "
INPUT a$
PowerOn = VAL(a$) : PAUSE 50
PRINT PowerOn
PRINT "Input Power OFF Time (HHMMSS): "
INPUT b$
PowerOff = VAL(b$) : pause 50
PRINT PowerOff
...and you will see that after the 1st. "Input" command input the software
will jump over the 2nd. "Input" command line without any input.
> RUN
? 150000
150000
?  0
What I did wrong????
Edited 2023-12-15 13:55 by Hansaplast
Posted: 04:04am 15 Dec 2023
Works for me. Others have mentioned that sometimes there is a need to clear the keyboard buffer of stray characters. Search for that.
WEB A:/> list
Print "Input Power ON Time (HHMMSS): "
Input a$
PowerOn = Val(a$) : Pause 50
Print PowerOn
Print "Input Power Off Time (HHMMSS): "
Input b$
PowerOff = Val(b$) : Pause 50
Print PowerOff
Sub mm.prompt
 Print "WEB "Cwd$"> ";
End Sub
End
WEB A:/> run
? 123456
123456
? 234567
234567
WEB A:/>
Hansaplast
Posted: 04:21am 15 Dec 2023
Under Basic it should be
LINE INPUT a$
PowerOn = VAL(a$)
PRINT PowerOn
LINE INPUT b$
PowerOff = VAL(b$)
PRINT PowerOff
Same program in QB64 work fine !
So for me it's a PicoMite BUG
Rem: Input is via USB
Hansaplast
Posted: 04:26am 15 Dec 2023
Posted: 04:28am 15 Dec 2023
It sounds like you have the end of line in your terminal program set to CRLF
Try changing that to LF
The first end-of-line character gets used up for the first input then the second end-of-line character is seen by the second INPUT command, hence the empty result.
Not a bug.
Hansaplast
Posted: 04:33am 15 Dec 2023
I use MM Edit as test platform and the MM Chat
Posted: 04:51am 15 Dec 2023
Adding this before the second input may help if you don't want to change the terminal settings.
do : loop until inkey$ = ""
Posted: 04:57am 15 Dec 2023
I suggest you update MMEdit to the latest version.
Then you will be able to set the end-of-line characters
Hansaplast
Posted: 04:59am 15 Dec 2023
Example from Geoff's PicoMite Manual, Page 22:
For example:
OPEN "numbers.txt" FOR INPUT AS #1
LINE INPUT #1, a$
LINE INPUT #1, b$
CLOSE #1
x = VAL(a$) : y = VAL(b$)
Following this the variable x would have the value 123 and y the value 56789.
Modified:
LINE INPUT a$
LINE INPUT b$
PRINT x,y
The result:
> RUN
123456
0 123456
It's a BUG !
Hansaplast
Posted: 05:00am 15 Dec 2023
in the Picomite Version MMBasic Ver 5.07.07
Posted: 05:12am 15 Dec 2023
  Quote  It's a BUG !
As Jim said there is no bug. At the MMEdit end CRLF is being sent but only CR is needed. the LF character becomes the second input.
I have just tested your program again with the terminal line endings set to CRLF and it produces your symptoms.
Adding the line in my previous post fixes it, as does changing back to CR only.
Input a$
Print PowerOn
Do : Loop Until Inkey$ = ""
Input b$
Print PowerOff
Edited 2023-12-15 15:13 by phil99
Posted: 05:13am 15 Dec 2023
The BUG is in the old version of MMEdit that you are running.
Later versions let you easily change the end-of-line.
Then you can see the differences.
amigawizard
Posted: 05:14am 15 Dec 2023
works  for  Me  2 !
LINE INPUT a$
LINE INPUT b$
PRINT x,y
      on the  command line
      using  minicom
       or telnet  on  Putty
             no  BUG !  here ..
             Wayne !
