Forum Index : Microcontroller and PC projects : Petscii on the CMM2 - sorted
You need the latest CMM2 beta posted 17:00 UTC 19/12/2023 Attached is a hack version of the Petscii code with the minor changes needed. Note this is an old version I happened to have lying around so I will leave it to the Petscii gurus to do properly pet25n.zip Changes are RGB functions for non-CMM2 colours FRAMEBUFFER commands replaced by PAGE commands LOAD IMAGE replaced by LOAD BMP (NB: missed two in the above) FLASH LOAD replaced by MEMORY INPUT UPDATE I've now added the missing colours to the CMM2 beta 19:09 UTC Edited 2023-12-20 05:08 by matherp |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5927 |
Hi Peter, What a nice achievement. I am sure this will have a follow up. If not from me, then from Martin. Personally I do not own a working CMM2 anymore. So I am waiting for availability to order a new one. I estimate that when (me/Martin) pick this up, that first we will do is make use of the video capabilities of the CMM2, and use the original graphics (VGA 256 colors). In other words, create a new sprite library. Another thing could be to perfect the gameplay details more. The CMM2 is 5-10x faster than the pico, so it will allow deeper search routines to get closer to the DOS version. I had to cut some corners there in the pico. But it is very good to hear that it is possible. Volhout The changes you made in the program, correct me if I am wrong, are in some cases using a different command. Is it an idea to harmonize that between the basic dialects? LOAD IMAGE -> LOAD BMP I guess this is just a command name change. Maybe similar for FRAMEBUFFER and PAGE ? I do expect that FLASH LOAD and MEMORY INPUT under the hood are different. Volhout Edited 2023-12-20 18:49 by Volhout PicomiteVGA PETSCII ROBOTS |
Hi Peter, Just tried your pet25n.bas on the latest (b22) MMB4W on a recent Thinkpad laptop (W10). - it starts, but quitting with <ESC> then <ESC> reveals another LOAD IMAGE error that should be converted to LOAD BMP - after fixing above, I get a "internal fault...sorry" error. Probably because we bluntly restart the game by executing "RUN" inside a running program. So the essence works, but a few more things need finetuning. Volhout P.S. it is logical, but a bit hilarious that the game runs more smooth on the pico than it does on MMB4W on this (i9 .. mind you) laptop.... ![]() Maybe that is also the keyboard repeat causing it... Edited 2023-12-21 20:16 by Volhout PicomiteVGA PETSCII ROBOTS |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
the Amiga / PSPTiles also uses only 16 Colors, but not RGB 121. To use the original Colorscheme in my test, I stored the Tiles on 2 Pages and gave every Tile a (source) x,y,page Coordinate, instead of the index. For the sprites I used a PNG file with transparents. cmm2 Petscii test It's all more programming, but you get the original colors 'no comment |
just played through MAP 1 one Timebomb kills the Evilbot map 3 Timebombs dont kill bots so its not based on RC but plays realy nice 'no comment |
No - as I said above . Think it was pet25n. Should be easy from my version to mod the latest release candidate. My assumption was this should be done with lots of IF MM.DEVICE$ statements to keep a single source |
