Forum Index : Microcontroller and PC projects : Setting RTC From NTP
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 881 |
Hi All and belated seasons greetings. I'm fiddling with getting the Date/Time from NTP, having retrieved the Daylight Saving status from OpenWeather. NTP automatically updates DATE$ & TIME$ but, as far as I can see, one must then update the RTC by say : RTC SETTIME MID$(Date$,7,4)+","+ MID$(Date$,4,2)+","+MID$(Date$,1,2)+"," +MID$(Time$,1,2)+"," +MID$(Time$,4,2)+"," +MID$(Time$,7,2). Is there sense in having a command like "RTC SETTIME NOW". It would be up to the user to only use this before the internal clock drifted (or have I lost the plot again?). Cheers, Andrew Edited 2024-01-02 13:31 by Andrew_G |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3284 |
There is probably a better way , use Val(Mid$() to extract each value from DateTime$(now) and insert them in RTC SETTIME |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6536 |
I don't have a WEBmite with an external RTC to test but this should do it: RTC SETTIME LEFT$(DATETIME$(NOW),6)+RIGHT$(DATETIME$(NOW),9) Jim VK7JH MMedit |
> RTC SETTIME LEFT$(DATETIME$(NOW),6)+RIGHT$(DATETIME$(NOW),9) Error : Date/time format > This might do it. sub RTCSet local integer y,m,d,h,min,s y = val(mid$(datetime$(now),7,4)) m = val(mid$(datetime$(now),4,2)) d = val(mid$(datetime$(now),1,2)) h = val(mid$(datetime$(now),12,2)) min = val(mid$(datetime$(now),15,2)) s = val(mid$(datetime$(now),18,2)) RTC SETTIME y,m,d,h,min,s end sub Edit Repaired a dumb mistake, had "m" twice Edited 2024-01-02 15:57 by phil99 |
I can't count! try rtc settime LEFT$(DATETIME$(NOW),6)+RIGHT$(DATETIME$(NOW),11) VK7JH MMedit |
Yes, that is much easier. When I searched the manual the RTC chapter made no mention of using a string, just coma separated values. Though it is in the Command section, next revision perhaps? Edit This also works. rtc settime date$+" "+time$ The above uses a 4 digit year without a problem, the Command description only shows 2 as in Jim's example. Edited 2024-01-02 17:16 by phil99 |
If it is happy with the 4 digit year RTC SETTIME DATETIME$(NOW) VK7JH MMedit |
Thanks Jim and Phil. (I too had assumed that it wouldn't accept a 4 digit year) I'm thankful on two counts, one that MMBasic had the feature and two that you found it. Cheers, Andrew |
Setting RTC From GPS A little off topic but may be useful if a GPS module is configured. > If gps(valid) then rtc settime gps(date)+" "+gps(time) > ? time$, gps(time) 13:43:19 13:43:19 > Edit For better synchronization. If gps(valid) then t$=gps(time) do while t$=gps(time) loop rtc settime gps(date)+" "+gps(time) endif Edited 2024-01-03 13:26 by phil99 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5920 |
This should be in the user manual. RTC SETTIME DATETIME$(NOW) PicomiteVGA PETSCII ROBOTS |
