Local Time 18:20 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A baffling choice
PhenixRising
Posted: 09:54am 27 Feb 2024
The choice function looks like it should be much more efficient
a=12
b=2
timer=0
for i = 1 to 10000
 d = choice(b>a,55,20)
next
print timer/10000
timer=0
for i = 1 to 10000
 if b>a then
   d=55
 else
   d=20
 end if
next
print timer/10000
RUN
0.0095116
0.0092647
The manual states:
This function allows you to do simple either or selections much more
efficiently and faster than using IF THEN ELSE ENDIF clauses.
The condition is anything that will resolve to nonzero (true) or zero (false)
The expressions are anything that you could normally assign to a variable or
use in a command.
e.g.
print choice(1, "hello","bye") will print "Hello"
print choice(0, "hello","bye") will print "Bye"
a=1:b=1:print choice(a=b, "hello","bye") will print "Hello"
Shame because it just looks/feels better.
Posted: 12:08pm 27 Feb 2024
Perhaps a faster way, after True / False is established is to use a 2 element array.
Dim String choose(1) = ("hello","bye")
Index 0 or 1 determines the result.
I found Select Case to be a bit slow when there are a lot of options and a larger version of the array method was much faster.
The job was to to translate the 45 key codes from an IR remote control to those of another device.
PhenixRising
Posted: 12:58pm 27 Feb 2024
  phil99 said  Perhaps a faster way, after True / False is established is to use a 2 element array.
Hi Phil,
Yeah, that's a neat alternative to Select Case I get a kick out of these kind of tips. Thanks.
I'm not actually looking for faster execution because the ARMmite-H7 has already exceeded expectations; it's just that the "choice" function showed-up as I was perusing the manual and it struck me as more elegant than IF/THEN/ELSE.
I just gained 40usec by shortening variable names so I might just give a few back in order to use the "choice" function, for the sake of prettier code
Posted: 01:38pm 27 Feb 2024
If I recall correctly CHOICE was definitely faster on the CMM2.
On the PicoMite I seem to recall that for at least one flavour (VGA?) the function that implements it was kept in flash and not RAM and thus slower, but I've just checked the code and it is flagged unconditionally as:
void __not_in_flash_func(fun_ternary)(void)
... so that doesn't seem to be the case anymore.
Alternatively these are all false memories .
Edited 2024-02-28 02:31 by thwill
PhenixRising
Posted: 04:28pm 27 Feb 2024
  thwill said  If I recall correctly CHOICE was definitely faster on the CMM2.
Hmmm, I'm on the ARMmite H7 which I would assume to be similar to the CMM2.
No worries, the H7 is a speed-demon, I just wanna use that function
Thanks, Tom.
PhenixRising
Posted: 05:19pm 27 Feb 2024
I wonder if it's the function call that's robbing the time:
OPTION EXPLICIT
OPTION DEFAULT integer
dim i
dim float mcmd
mcmd=40
timer=0
for i = 1 to 1000
 if mcmd<0.2 then mcmd=0.2
 if mcmd>99.8 then mcmd=99.8
next
print timer/1000,mcmd
timer=0
for i = 1 to 1000
 mcmd=max(mcmd,0.2)
 mcmd=min(mcmd,99.8)
next
0.015143       40
0.016619       40
LeoNicolas
Posted: 10:12pm 27 Feb 2024
Usually what I like to do is not optimize prematurely the code. I prefer to have a code that easy to read and maintain, leaving the optimization to the end if necessary, which usually is not.
damos
Posted: 12:43am 28 Feb 2024
This is a move to functional programming which I have been doing over the years without realizing.
In C# and JS I pretty much always use x = exp ? val1 : val2 which is the same as choice.
I also have been using lamba expressions everywhere without realizing how much I have changed. In JS, function dostuff() {} is replaced by:
const stuff = () => { }
I really don't write much C# as 90% of my code is actually LINQ, which is all functional.
These changes have been happening to many languages.
One of the big advantages is concurrent programming. While they seem to all be different ways of doing the same thing, using a function allows the compiler to do clever things rather than being forced to implement things using branches, which creates a lot of uncertainty when they optimize pipelines.
PhenixRising
Posted: 07:01am 28 Feb 2024
  LeoNicolas said  Usually what I like to do is not optimize prematurely the code. I prefer to have a code that easy to read and maintain, leaving the optimization to the end if necessary, which usually is not.
I think it depends on your interpretation of "optimize". I like robustness and the great thing about this interpreter is that I can test, test, test, doing all the things that "will never happen" in the real world
The "I'll come back and tidy it up later" is not acceptable to me because I have lost my train-of-thought.
