Forum Index : Microcontroller and PC projects : Advice on GUI PAGE Command
martrogers
Posted: 07:58pm 27 Feb 2024
Hello All
I am coding a calendar type device using a Picomite, ILI9341 and MMBasic 5.08.00.
All goes well in sub rel_entry first time round the loop but second time when GUI PAGE 2 is called nothing is drawn on the screen. So I know that GUI PAGE 2 is a permitted screen but don’t know why it will not draw multiple times.
I would appreciate some advice on what I’ve done wrong, apologies for the unprofessional code.
Martin
'1-22 elements used
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 dim integer PDnEf, PUpEf, hourx, dayx, weekx, monthx, choose1
 dim integer exit_flag, eflag
 GUI interrupt penDown, penUp
 gui beep 300  'click on screen input
 cls
 const Enter_new=1 ' button names, so button #1 is called Enter_new
 const Up=2
 const Down=3
 const set_months =4
 const set_weeks =5
 const set_days =6
 const set_hours =7
 const done =8
 const rel_box =9
 const hourxx =10
 const dayxx=11
 const weekxx=12
 const monthxx=13
 const yearxx=14
 CONST abs_box =15
 gui SETUP 1   ' screen 1
 font #3     'large font
 gui button Enter_new, "Enter New",0,190,155,50, rgb(black),rgb(lightgrey)
 gui button Up, "Up", 170,190,50,50, rgb(black),rgb(pink)
 gui button Down, "Down", 240,190,80,50, rgb(black),rgb(gold)
 gui SETUP 2
 font #3
 gui displaybox rel_box,10,0,300,50,rgb(BLACK), RGB(BLUE)
 CtrlVal(rel_box)="Time to Alarm"
 gui button set_hours, "Hours",15,55,120,50, rgb(black),rgb(lightgrey)
 gui button set_days, "Days",15,125,120,50, rgb(black),rgb(lightgrey)
 gui button set_weeks, "Weeks",180,55,120,50, rgb(black),rgb(lightgrey)
 gui button set_months, "Months",180,125,120,50, rgb(black),rgb(lightgrey)
 gui button done, "Done",70,190,200,50, rgb(black),rgb(gold)
 gui SETUP 3
 font #1
 gui formatbox 15, DATETIME1, 170,100, 150,50,rgb(black),rgb(yellow)
 gui SETUP 4
 font #3
 gui displaybox 16,10,0,300,50,rgb(BLACK), RGB(BLUE)
 CtrlVal(16)="Repeating?"
 gui button 17, "Daily",1,60,150,50, rgb(black),rgb(beige)
 gui button 18, "Weekly",1,120,150,50, rgb(black),rgb(beige)
 gui button 19, "Monthly",1,180,150,50, rgb(black),rgb(beige)
 gui button 20, "Yearly",150,60,150,50, rgb(black),rgb(beige)
 gui button 21, "Custom",150,120,150,50, rgb(black),rgb(salmon)
 gui button 22, "None",150,180,150,50, rgb(black),rgb(gold)
 gui setup 5
 font #3
 gui numberbox hourxx,200,100,120,50,rgb(black),rgb(yellow)
 gui setup 6
 font #3
 gui numberbox dayxx, 200, 100, 120, 50, rgb(black), rgb(yellow)
 gui setup 7
 font #3
 gui numberbox weekxx, 200, 100, 120, 50, rgb(black), rgb(yellow)
 gui setup 8
 font #3
 gui numberbox monthxx, 200, 100, 120, 50, rgb(black), rgb(yellow)
 do
   select case TOUCH(REF)  ' will return 1 if button 1 is touched, 2 for button 2 etc
     case Enter_new   ' Enter_new button touched
       ''new_entry       'subroutine for this touch
       cls
       font #2
       ' display screen asking absolute or relative entry
       choose1 =MsgBox("Absolute or Relative Alarm~ Abs e.g 10 May 3:30PM~Rel e.g 5 days,10 hrs","Abs","Rel","Exit")
       select case choose1
         case 1
           abs_entry   'absolute date
         case 2        'relative time (timer)
           rel_entry
       end select
       'case Up
       'scroll_up
       'case Down
       'scroll_down
   end select
 loop
sub rel_entry
 exit_flag=0
 do            'keep returning to this screen to allow Weeks + Days+ Hours etc to be input
   eflag=0
   print "at Page 2"
   pause 700
   cls
   gui redraw all
   gui page 2   ' hrs, days, weeks, months, done buttons
   gui redraw all
   print "past Page 2"
   do
       case 7 ' Hours selected, input number of hours
         cls
         gui page 5
         CtrlVal(hourxx) = "##Hours"
         'print "Hours selected"
         do
           if PDnEf=1 then   'input box touched
             PDnEf=0
             hourx=ctrlval(hourxx)
           end if
           if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt
             PUpEf=0
             hourx=ctrlval(hourxx) 'numbers pressed
             if hourx>0 then
               eflag=1
               exit do
             endif
           end if
         loop
         print "hours" hourx
       case 6 'Days
         cls
         gui page 6
         CtrlVal(dayxx) = "##Days"
         print "Days selected"
         do
             PDnEf=0
             dayx=ctrlval(dayxx)
           end if
             PUpEf=0
             dayx=ctrlval(dayxx) 'numbers pressed
             if dayx>0 then
               eflag=1
               exit do
             endif
           end if
         loop
         print "days " dayx
       case 5 'Weeks
         cls
         gui page 7
         CtrlVal(weekxx) = "##Weeks"
         print "Weeks selected"
         do
             PDnEf=0
             weekx=ctrlval(weekxx)
           end if
             PUpEf=0
             weekx=ctrlval(weekxx) 'numbers pressed
             if weekx>0 then
               eflag=1
               exit do
             endif
           end if
         loop
         print "weeks " weekx
       case 4 'Months
         cls
         gui page 8
         CtrlVal(monthxx) = "##Months"
         print "Months selected"
         do
             PDnEf=0
             monthx=ctrlval(monthxx)
           end if
             PUpEf=0
             monthx=ctrlval(monthxx) 'numbers pressed
             if monthx>0 then
               eflag=1
               exit do
             endif
           end if
         loop
         print "Months " monthx
       case 8  'Done
         'store value as a forward DTG to file
         eflag=1
         exit_flag=1
     end select
   loop while eflag=0
   print "select ended" eflag
   if exit_flag =1 then  'all done
     exit sub
   endif
 loop
end sub
sub abs_entry
 gui Page 3
 do
     PDnEf=0
     dtg$=ctrlval(15)
   end if
     PUpEf=0
     dtg$=ctrlval(15) 'numbers pressed
     if dtg$<>"" then
       'eflag=1
       exit do
     endif
   end if
 loop
 gui page 4
end sub
sub penDown
 PDnEf=1
return
end sub
sub penUp
 PuPEf=1
return
end sub
end
Posted: 03:40am 28 Feb 2024
The GUI PAGE command does work and I'm not sure what you mean by "it will not draw multiple times".  Perhaps you are expecting it to do something other than its intended function?
Your example code does not help as it is way too big to reverse engineer.  If you could cut it down to just a few lines (<10) that demonstrates just your problem the answer might become obvious.
Posted: 04:00am 28 Feb 2024
It would also help if you told us your OPTIONs
It does look like you are doing a CLS while you are still on PAGE 2 (in a number of places).
I am the last person to give advice on GUI programming, but that doesn't look right.
Edited 2024-02-28 14:31 by TassyJim
martrogers
Posted: 09:27am 28 Feb 2024
Thanks for this, you were correct, for some reason it dosent like a CLS before a GUI PAGE. A CLS is not needed anyway because the previous page is hidden by the new GUI PAGE command.
Martin
KeepIS
Posted: 10:54pm 28 Feb 2024
FYI: On the rare occasion that you might need to use CLS, simply switch to a dummy page number first before using CLS.
NANO:Inverter V 8.2ksLinux AvrDude GUI script V4.1
martrogers
Posted: 09:25am 02 Apr 2024
Thanks Mike
I've RTFM and on page 71 it says that a CLS also does a GUI HIDE ALL . The CLS now works as I had expected by my issuing a GUI SHOW ALL after the CLS.
twofingers
Posted: 11:21am 02 Apr 2024
  martrogers said  sub penDown
 PDnEf=1
return
end sub
Just one question: what is RETURN for?
Michael
Posted: 11:43am 02 Apr 2024
  twofingers said  Just one question: what is RETURN for?
Yeah, you don't want to be doing a RETURN in MMBasic unless you are using a legacy GOSUB call. Instead either flow through to END SUB or return early with EXIT SUB. I'm surprised it isn't all "exploding horribly" in the current state.
Edited 2024-04-02 21:44 by thwill
Posted: 11:44am 02 Apr 2024
Manual, Obsolete Commands and Functions.
  Quote  RETURN
RETURN concludes a subroutine called by GOSUB and returns to the
statement after the GOSUB.
