Forum Index : Microcontroller and PC projects : WS2812 Leds
| PEnthymeme Regular Member Joined: 27/12/2023 Location: United KingdomPosts: 42 |
Possibly an "obvious" answer here - but my addled brain just cant see it. Given a strip of x5 WS2812 Leds - I understand how to set the leds and their colours using the nbr and value array. But I am having a cognitive block on how to set the colour, but vary the brightness. So say I want to create a "heart beat" where the colour is red, but the brightness varies in response to an analogue pin input? Any tips? Ps - have searched the forum and I don't "get" the answers - looking for a "dummies" guide ;-) Px Edited 2024-02-29 06:51 by PEnthymeme |
read adc and use the value to control a pwm pin to leds???a thought |
I can use this to set the brightness of individual LEDs - I am Bitbang-ing these with: BITBANG WS2812 b, pin etc so not sure PWM will work here. (But as said, brain freeze).P |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3292 |
WS2812 uses a serial data stream so PWM won't help. So if you have the RGB variant the first two digits (8 bits or 0 to 255) of &HFFFFFF control the red led, the middle two control the green led and the last two control the blue led. To get all red each element of the array should vary the first two from &H000000 to &Hff0000. &H0f0000 would be dim red. Blue is easiest as the first 4 digits are 0 you can just use a number from 0 to 255. You can get the colour numbers by Bit Shifting up to the required range. Green = 255 << 8 Red = 255 << 16 For a analogue input scale the input range (0 to 3.3) to 0 to 255 eg R = (Vin * 255 / 3.3) << 16 All colours can be had by adding the individual colours colour = red<<16 + green<<8 + blue You could also try the RGB() function which does that for you. colour = RGB(red,green,blue) 0 to 255 for each |
DOH!!!Thank you - just couldn't see it - even after reading the manual. Perfectly clear now. Px |
Bill.b![]() Senior Member Joined: 25/06/2011 Location: AustraliaPosts: 245 |
hi Px I send an integer either single or in an array of &H000000 for each led the breakdown is &H 00(Red 0 - FF) 00 (green 0 - FF) 00 (Blue 0 - FF) i.e &h400000 will turn on the RED, &h004000 will turn on the green etc. I generally use values of 0 to 40 hex as this gives max brightness and uses less current the hex FF. To very the brightness you can use a loop to very the value for 0 to 40 or use an analogue value scaled to the required range. Bill Edited 2024-02-29 08:50 by Bill.b In the interests of the environment, this post has been constructed entirely from recycled electrons. |
Thank you both - the 40 tip worked perfectly. I have a "ring" of 24 LEDS and am currently powering it externally -- will try with this and see how the 'mite gets on. Question - if you draw too much current is the 'mite protected from over current? Px |
Yes, It's called smoke but only works once. VK7JH MMedit |
I generally use a 5v 5A supply to power the leds therefore the load on the pi is only that reqired for the serial link to the first led This is a program I used at Christmas to control 4 5m strips of LEDs total of 600 ws2812 leds ' 150 WS2812 LED strip 4 channel arch control ' Bill Brown 16/09/2023 Option autorun on Option DEFAULT NONE ' Option EXPLICIT Randomize Timer Dim integer count, count1, rndnum, loopcnt, indexcount,count2, count3 dim integer cyclecount,i,x,indexcount2,loopcnt2 dim integer buff1, buff2, buff3, buff4 Dim integer buffer0(200) Dim integer buffer1(200) Dim integer buffer2(200) Dim integer buffer3(200) Dim integer tempbuff(200) Dim integer bufferRND(900) Dim integer colour1(100) dim integer LEDNum SetPin GP5, DOUT ' Strip 1 SetPin GP11, DOUT ' strip 2 SetPin GP18, DOUT ' strip 3 SetPin GP22, DOUT ' Strip 4 LEDNum = 150 'Number of WS2812 LEDs / Srip, 4 * 5m 30/m strips = 600 LEDs total '-------------------------------------------- 'Mian ---- Call each light group do LEDData flag Flash1 centerFill fillleds2 COLOURBAND fade blink colourLED flashLED randomdata randomflash FillLED3 ringcolour COLOURBAND LEDData REVFillLEDs Flash2 kit center2 fillleds Flash1 Restore loop '************************READ AND RUN COLOUR SEQUENCE**************************************** sub LEDdata 'read 6 light patterns for indexcount = 1 to 6 For loopcnt = 0 To 149 Read buffer0(loopcnt) Next loopcnt 'rotate data in buffer array For count2 = 1 To 300 'rotate data in buffer array For loopcnt = 149 To 0 Step -1 buffer0(loopcnt + 1) = buffer0(loopcnt) Next loopcnt buffer0(0) = buffer0(149) sendLED select case indexcount 'Set sequence speed case 1 pause 20 case 2 pause 10 case 3 pause 10 case 4 pause 20 case 5 pause 10 case 6 pause 20 end select Next count2 next indexcount end sub '*************************************************** SUB COLOURBAND for count3 = 1 to 3 for loopcnt = 0 to 149 if count3 = 1 then buffer0(loopcnt) = &h101000 buffer1(loopcnt) = &h000200 buffer2(loopcnt) = &h000002 buffer3(loopcnt) = &h020000 next loopcnt for loopcnt = 0 to 149 step 15 buffer0(loopcnt) = &h000030 buffer0(loopcnt+1) = &h000030 buffer0(loopcnt+2) = &h000030 buffer1(loopcnt) = &h003000 buffer1(loopcnt+1) = &h002000 buffer1(loopcnt+2) = &h003000 buffer2(loopcnt) = &h300000 buffer2(loopcnt+1) = &h300000 buffer2(loopcnt+2) = &h300000 buffer3(loopcnt) = &h303030 buffer3(loopcnt+1) = &h303030 buffer3(loopcnt+2) = &h303030 next loopcnt end if if count3 = 2 then buffer0(loopcnt) = &h000002 buffer1(loopcnt) = &h000200 buffer2(loopcnt) = &h020000 buffer3(loopcnt) = &h100200 next loopcnt for loopcnt = 0 to 149 step 15 buffer0(loopcnt) = &h303000 buffer0(loopcnt+1) = &h303000 buffer0(loopcnt+2) = &h303000 buffer1(loopcnt) = &h003000 buffer1(loopcnt+1) = &h003000 buffer1(loopcnt+2) = &h003000 buffer2(loopcnt) = &h300000 buffer2(loopcnt+1) = &h300000 buffer2(loopcnt+2) = &h300000 buffer3(loopcnt) = &h303030 buffer3(loopcnt+1) = &h303030 buffer3(loopcnt+2) = &h303030 next loopcnt end if end if if count3 = 3 then buffer0(loopcnt) = &h000200 buffer1(loopcnt) = &h020000 buffer2(loopcnt) = &h020200 buffer3(loopcnt) = &h020002 next loopcnt for loopcnt = 0 to 149 step 15 buffer0(loopcnt) = &h303000 buffer0(loopcnt+1) = &h303000 buffer0(loopcnt+2) = &h303000 buffer1(loopcnt) = &h300000 buffer1(loopcnt+1) = &h300000 buffer1(loopcnt+2) = &h300000 buffer2(loopcnt) = &h000030 buffer2(loopcnt+1) = &h000030 buffer2(loopcnt+2) = &h000030 buffer3(loopcnt) = &h303030 buffer3(loopcnt+1) = &h303030 buffer3(loopcnt+2) = &h303030 next loopcnt end if For count2 = 1 To 300 For loopcnt = 149 To 0 Step -1 buffer0(loopcnt + 1) = buffer0(loopcnt) buffer1(loopcnt + 1) = buffer1(loopcnt) buffer2(loopcnt + 1) = buffer2(loopcnt) buffer3(loopcnt + 1) = buffer3(loopcnt) Next loopcnt buffer0(0) = buffer0(149) buffer1(0) = buffer1(149) buffer2(0) = buffer2(149) buffer3(0) = buffer3(149) sendLED2 'pause 10 next count2 next count3 end sub sub flag for count3 = 1 to 4 for loopcnt = 0 To 74 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h400000 next count Next loopcnt for loopcnt = 75 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h404040 next count Next loopcnt for loopcnt = 149 To 175 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h000040 next count Next loopcnt sendLED pause 500 for loopcnt = 0 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h000040 next count Next loopcnt for loopcnt = 74 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h400000 next count Next loopcnt for loopcnt = 74 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h404040 next count Next loopcnt sendLED pause 500 for loopcnt = 0 To 74 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h404040 next count Next loopcnt for loopcnt = 75 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h000040 next count Next loopcnt for loopcnt = 74 To 149 Step 10 for count = 0 to 9 buffer0(loopcnt + count) = &h400000 next count Next loopcnt sendLED pause 500 next count3 end sub '********************fill from center ***************** sub centerFill For loopcnt = 0 To 169 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt sendLED2 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer2(loopcnt) = &h300000 buffer1(count3) = &h300000 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer3(loopcnt) = &h300000 buffer0(count3) = &h300000 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer0(loopcnt) = &h003000 buffer3(count3) = &h003000 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer1(loopcnt) = &h003000 buffer2(count3) = &h003000 sendled2 next loopcnt pause 10 '------------------------------------------------------ for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer2(loopcnt) = &h000030 buffer1(count3) = &h000030 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer3(loopcnt) = &h000030 buffer0(count3) = &h000030 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer0(loopcnt) = &h301000 buffer3(count3) = &h301000 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer1(loopcnt) = &h301000 buffer2(count3) = &h301000 sendled2 next loopcnt pause 10 '---------------------------------------------------------- for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer2(loopcnt) = &h300030 buffer1(count3) = &h300030 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer3(loopcnt) = &h300030 buffer0(count3) = &h300030 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer0(loopcnt) = &h003030 buffer3(count3) = &h003030 sendled2 next loopcnt pause 10 for loopcnt= 0 to 149 count3 = 149 - loopcnt buffer1(loopcnt) = &h003030 buffer2(count3) = &h003030 sendled2 next loopcnt pause 10 end sub '***************************ROTATE COLOUR************************************** sub ringcolour For loopcnt = 0 To 169 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt sendLED2 for loopcnt= 0 to 149 buffer0(loopcnt) = &h300000 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer1(loopcnt) = &h303030 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer2(loopcnt) = &h000030 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer3(loopcnt) = &h303000 sendLED2 pause 10 '_____________________________ next loopcnt For loopcnt = 0 To 169 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt sendLED2 for loopcnt= 150 to 0 step -1 buffer3(loopcnt) = &h303000 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer2(loopcnt) = &h000030 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer1(loopcnt) = &h303030 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer0(loopcnt) = &h300000 sendLED2 pause 10 next loopcnt '_____________________________ For loopcnt = 0 To 169 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt sendLED2 for loopcnt= 0 to 149 buffer0(loopcnt) = &h301000 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer1(loopcnt) = &h300030 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer2(loopcnt) = &h003030 sendLED2 pause 10 next loopcnt for loopcnt= 0 to 149 buffer3(loopcnt) = &h003000 sendLED2 pause 10 next loopcnt '---------------------------------------- For loopcnt = 0 To 169 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt sendLED2 for loopcnt= 150 to 1 step -1 buffer3(loopcnt) = &h301000 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer2(loopcnt) = &h300030 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer1(loopcnt) = &h003030 sendLED2 pause 10 next loopcnt for loopcnt= 150 to 1 step -1 buffer0(loopcnt) = &h003000 sendLED2 pause 10 next loopcnt end sub '**************************flash 4 colours********************************** sub blink for loopcnt = 1 to 5 for count1 = 0 to 149 buffer0(count1) = &h300000 buffer3(count1) = &h000000 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer0(count1) = &h000000 buffer1(count1) = &h003000 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer1(count1) = &h000000 buffer2(count1) = &h000030 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer2(count1) = &h000000 buffer3(count1) = &h303030 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer0(count1) = &h300030 buffer3(count1) = &h000000 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer0(count1) = &h000000 buffer1(count1) = &h301000 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer1(count1) = &h000000 buffer2(count1) = &h300030 next count1 sendLED2 pause 300 for count1 = 0 to 149 buffer2(count1) = &h000000 buffer3(count1) = &h303000 next count1 sendLED2 pause 300 next loopcnt end sub '***************************************************************** sub colourLED For loopcnt = 0 To 149 buffer0(loopcnt) = &h000000 buffer1(loopcnt) = &h000000 buffer2(loopcnt) = &h000000 buffer3(loopcnt) = &h000000 Next loopcnt for loopcnt = 1 to 6 for count1 = 0 to 149 step 10 for count = 0 to 9 buffer0(count1 + count) = &h003000 buffer1(count1 + count) = &h300000 buffer2(count1 + count) = &h303030 buffer3(count1 + count) = &h000030 next count sendLED2 pause 30 next count1 for count1 = 0 to 149 step 10 for count = 0 to 9 buffer0(count1 + count) = &h003030 buffer1(count1 + count) = &h301000 buffer2(count1 + count) = &h300030 buffer3(count1 + count) = &h303000 next count sendLED2 pause 30 next count1 for count1 = 0 to 149 step 10 for count = 0 to 9 buffer0(count1 + count) = &h003000 buffer1(count1 + count) = &h303030 buffer2(count1 + count) = &h303000 buffer3(count1 + count) = &h300030 next count sendLED2 pause 30 next count1 for count1 = 149 to 0 step - 10 for count = 0 to 9 buffer0(count1 + count) = &h003000 buffer1(count1 + count) = &h300000 buffer2(count1 + count) = &h303030 buffer3(count1 + count) = &h000030 next count sendLED2 pause 30 next count1 for count1 = 149 to 0 step - 10 for count = 0 to 9 buffer0(count1 + count) = &h003030 buffer1(count1 + count) = &h301000 buffer2(count1 + count) = &h300030 buffer3(count1 + count) = &h303000 next count sendLED2 pause 30 next count1 for count1 = 149 to 0 step - 10 for count = 0 to 9 buffer0(count1 + count) = &h003000 buffer1(count1 + count) = &h303030 buffer2(count1 + count) = &h303000 buffer3(count1 + count) = &h300030 next count sendLED2 pause 30 next count1 next loopcnt end sub '************************FAD COLOUR UP AND DOWN*********************************** sub fade For count = 0 To 449 'Reset all LED to OFF bufferRND(count) = 00 Next count sendledrnd for count3 = 1 to 60 for count = 0 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 for count3 = 60 to 0 step -1 for count = 0 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 '---------------------------- sendledrnd for count3 = 0 to 60 for count = 1 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 for count3 = 60 to 1 step -1 for count = 1 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 '----------------------------- for count3 = 0 to 60 for count = 2 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 for count3 = 60 to 1 step -1 for count = 2 to 449 step 3 bufferrnd(count) = count3 next count sendledrnd ' pause 5 next count3 '------------------------------------ for count3 = 0 to 60 for count = 0 to 459 step 3 bufferrnd(count) = count3 bufferrnd(count + 1) = count3 next count sendledrnd ' pause 5 next count3 for count3 = 60 to 1 step -1 for count = 0 to 459 step 3 bufferrnd(count) = count3 bufferrnd(count + 1) = count3 next count sendledrnd ' pause 5 next count3 '------------------------------------ for count3 = 0 to 60 for count = 0 to 459 step 3 bufferrnd(count) = count3 bufferrnd(count + 2) = count3 next count sendledrnd ' pause 5 next count3 for count3 = 60 to 1 step -1 for count = 0 to 459 step 3 bufferrnd(count) = count3 bufferrnd(count + 2) = count3 next count sendledrnd ' pause 5 next count3 end sub '*************************RANDOM COLOUR ****************** sub randomdata For count = 0 To 449 'Reset all LED to OFF bufferRND(count) = 00 Next count sendledrnd for count1 = 1 to 50 'repeat random lights 150 times for count = 0 to 1000 rndnum = Int(RND()*840)+1 'Set array size and set data - Number of LEDs * 3 BufferRND(rndnum) = count * 40 and 40 'Set Brightness of LED next count sendLEDrnd pause 100 next count1 pause 90 end sub '************************* Ransom flash*************************************** sub randomflash randomize(timer) for count1 = 1 to 100 rndnum = Int(RND()*10) Select case rndnum case 0 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 buffer0(count) = &h300000 next count sendLED2 pause 350 case 1 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer2(count) = &h000030 Buffer3(count) = &h301000 next count sendLED2 pause 350 case 2 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer1(count) = &h003000 next count sendLED2 pause 350 case 3 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 buffer0(count) = &h003030 next count sendLED2 pause 350 case 4 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer3(count) = &h303000 next count sendLED2 pause 350 case 5 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer3(count) = &h303030 Buffer1(count) = &h300030 next count sendLED2 pause 350 case 6 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer2(count) = &h03030 Buffer1(count) = &h300030 next count sendLED2 pause 350 case 7 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 buffer0(count) = &h300030 Buffer1(count) = &h300000 next count sendLED2 pause 350 case 8 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 Buffer3(count) = &h000030 next count sendLED2 pause 350 case 9 For count = 0 To 150 'Reset all LED to OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 next count sendLED2 for count = 0 to 149 buffer0(count) = &h000030 Buffer1(count) = &h300030 Buffer2(count) = &h303030 Buffer3(count) = &h300000 next count sendLED2 pause 350 end select Next count1 end sub '*****************************FLASH LEDS*************************************************************** sub flashLED For count = 1 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count For count = 0 To 149 buffer0(count) = &h300000 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149 'turn all leds&h OFF buffer0(count) = &h003000 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149'turn all leds OFF buffer0(count) = &h000030 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149'turn all leds OFF buffer0(count) = &h301000 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h003030 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h303030 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h003000 Next count sendLED pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000500 Next count sendLED pause 500 for indexcount =1 to 2 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h303000 buffer1(count) = &h303030 buffer2(count) = &h003000 buffer3(count) = &h003000 Next count sendLED2 pause 500 For count = 0 To 149'turn all leds OFF buffer0(count) = &h300000 buffer1(count) = &h303000 buffer2(count) = &h303030 buffer3(count) = &h003000 Next count sendLED2 pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h300030 buffer1(count) = &h303000 buffer2(count) = &h003000 buffer3(count) = &h300000 Next count sendLED2 pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h301000 buffer1(count) = &h000030 buffer2(count) = &h303000 buffer3(count) = &h300000 Next count sendLED2 pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h003000 buffer1(count) = &h303030 buffer2(count) = &h300030 buffer3(count) = &h003000 Next count sendLED2 pause 500 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000030 buffer1(count) = &h003000 buffer2(count) = &h300000 buffer3(count) = &h303030 Next count sendLED2 pause 500 For count = 0 To 149'turn all leds OFF buffer0(count) = &h003030 buffer1(count) = &h303000 buffer2(count) = &h300030 buffer3(count) = &h003000 Next count sendLED2 pause 500 For count = 0 To 149'turn all leds OFF buffer0(count) = &h300030 buffer1(count) = &h303030 buffer2(count) = &h303000 buffer3(count) = &h003030 Next count sendLED2 pause 500 next indexcount end sub '***************************FLASH LEDS 2*******************************************88 sub Flash2 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count sendLED for count3 = 1 to 20 buffer0(10) = &h300000 buffer0(30) = &h000030 buffer0(55) = &h303000 buffer0(40) = &h300030 buffer0(35) = &h303040 buffer0(80) = &h300040 buffer0(100) = &h303000 buffer0(115) = &h100040 buffer0(130) = &h103000 buffer0(145) = &h303040 sendLED pause 50 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count buffer0(50) = &h300000 buffer0(15) = &h000030 buffer0(45) = &h303000 buffer0(5) = &h300030 buffer0(65) = &h300040 buffer0(90) = &h303000 buffer0(110) = &h301000 buffer0(120) = &h100040 buffer0(135) = &h103000 buffer0(140) = &h303040 sendLED pause 50 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count buffer0(15) = &h300000 buffer0(41) = &h000030 buffer0(25) = &h303000 buffer0(3) = &h300030 buffer0(45) = &h303040 buffer0(70) = &h303000 buffer0(105) = &h303040 buffer0(125) = &h100040 buffer0(138) = &h103000 buffer0(148) = &h303040 sendLED pause 50 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count buffer0(45) = &h300000 buffer0(20) = &h000030 buffer0(18) = &h303000 buffer0(50) = &h300030 buffer0(4) = &h303040 buffer0(60) = &h303000 buffer0(90) = &h303040 buffer0(110) = &h100040 buffer0(125) = &h103000 buffer0(140) = &h303040 sendLED pause 50 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count buffer0(0) = &h300000 buffer0(10) = &h000030 buffer0(60) = &h303000 buffer0(80) = &h300030 buffer0(100) = &h303040 buffer0(95) = &h303000 buffer0(112) = &h303040 buffer0(122) = &h100040 buffer0(137) = &h103000 buffer0(149) = &h303040 sendLED pause 50 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count next count3 end sub '****************************FLAG*********************************************** sub newflag For count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 Next count for count3 = 1 to 3 for count = 0 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h400000 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h404040 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h000040 next loopcnt next count for count = 10 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h000040 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h404040 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h400000 next loopcnt next count sendLED pause 500 '------------------------------- for count = 0 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h404040 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h000040 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h400000 next loopcnt next count for count = 10 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h400000 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h000040 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h404040 next loopcnt next count sendLED pause 500 '--------------------------------------- for count = 0 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h000040 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h400000 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h404040 next loopcnt next count for count = 10 to 149 step 20 for loopcnt = 0 to 2 buffer0(count+loopcnt) = &h404040 next loopcnt for loopcnt = 3 to 6 buffer0(count+loopcnt) = &h400000 next loopcnt for loopcnt = 7 to 9 buffer0(count+loopcnt) = &h000040 next loopcnt next count sendLED pause 500 next count3 pause 500 end sub '*****************************kIT SIMULATION************************************************** sub Kit for count = 0 To 149 buffer0(count) = 00 Next count sendLED 'for loopcnt = 1 to 2 for count1 = 2 to 149 'Run the LED from end to end and return buffer0(count1) = &h300000 Buffer1(count1) = &h003000 Buffer2(count1) = &h300030 Buffer3(count1) = &h303030 buffer0(count1+1) = &h100000 Buffer1(count1+1) = &h001000 Buffer2(count1+1) = &h100010 Buffer3(count1+1) = &h101010 buffer0(count1+2) = &h020000 Buffer1(count1+2) = &h000200 Buffer2(count1+2) = &h020002 Buffer3(count1+2) = &h020202 pause 5 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 for count1 = 149 to 2 step -1 buffer0(count1) = &h020000 Buffer1(count1) = &h000200 Buffer2(count1) = &h020002 Buffer3(count1) = &h020202 buffer0(count1-1) = &h100000 Buffer1(count1-1) = &h001000 Buffer2(count1-1) = &h100010 Buffer3(count1-1) = &h101010 buffer0(count1-2) = &h300000 Buffer1(count1-2) = &h003000 Buffer2(count1-2) = &h300030 Buffer3(count1-2) = &h303030 pause 5 buffer0(count1+1) = &h000000 Buffer1(count1+1) = &h000000 Buffer2(count1+1) = &h000000 Buffer3(count1+1) = &h000000 sendLED2 next count1 'next loopcnt 'for loopcnt = 1 to 2 for count1 = 1 to 149 'Run the LED from end to end and return buffer0(count1) = &h000030 Buffer1(count1) = &h003000 Buffer2(count1) = &h303030 Buffer3(count1) = &h300000 pause 5 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 for count1 = 149 to 0 step -1 buffer0(count1) = &h000030 Buffer1(count1) = &h003000 Buffer2(count1) = &h303030 Buffer3(count1) = &h300000 pause 5 buffer0(count1+1) = &h000000 Buffer1(count1+1) = &h000000 Buffer2(count1+1) = &h000000 Buffer3(count1+1) = &h000000 sendLED2 next count1 for count1 = 1 to 149 'Run the LED from end to end and return buffer0(count1) = &h303000 Buffer1(count1) = &h003030 Buffer2(count1) = &h303030 Buffer3(count1) = &h300030 pause 5 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 for count1 = 149 to 0 step -1 buffer0(count1) = &h303000 Buffer1(count1) = &h003030 Buffer2(count1) = &h303030 Buffer3(count1) = &h300030 pause 5 buffer0(count1+1) = &h000000 Buffer1(count1+1) = &h000000 Buffer2(count1+1) = &h000000 Buffer3(count1+1) = &h000000 sendLED2 next count1 for count1 = 1 to 149 'Run the LED from end to end and return buffer0(count1) = &h301000 Buffer1(count1) = &h003010 Buffer2(count1) = &h300030 Buffer3(count1) = &h303000 pause 5 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 for count1 = 149 to 0 step -1 buffer0(count1) = &h301000 Buffer1(count1) = &h003010 Buffer2(count1) = &h300030 Buffer3(count1) = &h303000 pause 5 buffer0(count1+1) = &h000000 Buffer1(count1+1) = &h000000 Buffer2(count1+1) = &h000000 Buffer3(count1+1) = &h000000 sendLED2 next count1 end sub '*******************************FILL LEDS IST GROUP PATTERN************************************************* Sub FillLEDs for count = 0 To 129 'turn all leds OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 Next count sendLED x = 0 indexcount = 126 for loopcnt = 1 to 127 step 3 if x = 0 then buff1 = &h300000 buff2 = &h000030 buff3 = &h003000 buff4 = &h303000 endif if x = 1 then buff1 = &h301000 buff2 = &h003000 buff3 = &h300000 buff4 = &h300030 endif if x = 2 then buff1 = &h003000 buff2 = &h300000 buff3 = &h003030 buff4 = &h003000 endif if x = 3 then buff1 = &h000030 buff2 = &h300030 buff3 = &h303000 buff4 = &h300000 endif if x = 4 then buff1 = &h300030 buff2 = &h303000 buff3 = &h301000 buff4 = &h000030 endif for count1 = 1 to indexcount buffer0(count1) = buff1 buffer0(count1+1) = buff1 buffer0(count1+2) = buff1 buffer0(count1+3) = buff1 Buffer1(count1) = buff2 Buffer1(count1+1) = buff2 Buffer1(count1+2) = buff2 Buffer1(count1+3) = buff2 Buffer2(count1) = buff3 Buffer2(count1+1) = buff3 Buffer2(count1+2) = buff3 Buffer2(count1+3) = buff3 Buffer3(count1) = buff4 Buffer3(count1+1) = buff4 Buffer3(count1+2) = buff4 Buffer3(count1+3) = buff4 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 x= x + 1 if x > 4 then x = 0 endif indexcount = indexcount - 4 next loopcnt end sub '*********************************FILL LEDS 3RD GROUP PATTERN************************************ Sub FillLED3 for count = 0 To 149 buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 Next count sendLED indexcount = 149 for loopcnt = 2 to 149 step 2 for count1 = 2 to indexcount 'Run the Red LED from end to end and return buffer0(count1) = &h301000 buffer0(count1+1) = &h300000 Buffer1(count1) = &h300030 Buffer1(count1+1) = &h003030 Buffer2(count1) = &h003000 Buffer2(count1+1) = &h000030 Buffer3(count1) = &h303030 Buffer3(count1+1) = &h003000 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 sendLED2 next count1 indexcount = indexcount -2 next loopcnt sendLED end sub **************************REVERSE FILL LEDS ********************************************* Sub REVFillLEDs for count = 0 To 149 'turn all leds OFF buffer0(count) = &h300000 buffer1(count) = &h003000 buffer2(count) = &h000030 buffer3(count) = &h303000 Next count sendLED indexcount2 = 149 loopcnt2 = 76 indexcount = 75 count3 = 149 for loopcnt = 1 to 75 for count1 = 1 to indexcount 'Run the Red LED from end to end and return buffer0(count1) = &h000000 Buffer1(count1) = &h000000 Buffer2(count1) = &h000000 Buffer3(count1) = &h000000 buffer0(count1-1) = &h300000 Buffer1(count1-1) = &h003000 Buffer2(count1-1) = &h000030 Buffer3(count1-1) = &h303000 'sendLED2 'Run the Red LED from end to end and return buffer0(count3) = &h000000 Buffer1(count3) = &h000000 Buffer2(count3) = &h000000 Buffer3(count3) = &h000000 buffer0(count3+1) = &h300000 Buffer1(count3+1) = &h003000 Buffer2(count3+1) = &h000030 Buffer3(count3+1) = &h303000 sendLED2 count3 = count3 - 1 if count3 < loopcnt2 then count3 = 149 endif next count1 indexcount = indexcount -1 loopcnt2 = loopcnt2 + 1 next loopcnt for count = 0 To 149 buffer0(count) = &h300000 buffer1(count) = &h003000 buffer2(count) = &h000030 buffer3(count) = &h303000 Next count sendLED end sub '**************************FILL LEDS 2ND SEQUENCE ******************** Sub FillLEDs2 for count = 0 To 149 'turn all leds OFF buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 Next count sendLED indexcount2 = 149 loopcnt2 = 76 indexcount = 75 count3 = 149 for loopcnt = 1 to 75 for count1 = 1 to indexcount 'Run the Red LED from end to end and return buffer0(count1) = &h301000 Buffer1(count1) = &h300030 Buffer2(count1) = &h003030 Buffer3(count1) = &h303030 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 'sendLED2 'Run the Red LED from end to end and return buffer0(count3) = &h300000 Buffer1(count3) = &h000030 Buffer2(count3) = &h000030 Buffer3(count3) = &h003000 buffer0(count3+1) = &h000000 Buffer1(count3+1) = &h000000 Buffer2(count3+1) = &h000000 Buffer3(count3+1) = &h000000 sendLED2 count3 = count3 - 1 if count3 < loopcnt2 then count3 = 149 endif next count1 indexcount = indexcount -1 loopcnt2 = loopcnt2 + 1 next loopcnt LEDNum = 150 for count = 0 To 149 buffer0(count) = &h000000 buffer1(count) = &h000000 buffer2(count) = &h000000 buffer3(count) = &h000000 Next count sendLED indexcount2 = 149 loopcnt2 = 76 indexcount = 75 count3 = 149 for loopcnt = 1 to 75 for count1 = 1 to indexcount 'Run the Red LED from end to end and return buffer0(count1) = &h300000 Buffer1(count1) = &h000030 Buffer2(count1) = &h003000 Buffer3(count1) = &h003030 buffer0(count1-1) = &h000000 Buffer1(count1-1) = &h000000 Buffer2(count1-1) = &h000000 Buffer3(count1-1) = &h000000 buffer0(count3) = &h301000 Buffer1(count3) = &h300030 Buffer2(count3) = &h303030 Buffer3(count3) = &h003000 buffer0(count3+1) = &h000000 Buffer1(count3+1) = &h000000 Buffer2(count3+1) = &h000000 Buffer3(count3+1) = &h000000 sendLED2 count3 = count3 - 1 if count3 < loopcnt2 then count3 = 149 endif next count1 indexcount = indexcount -1 loopcnt2 = loopcnt2 + 1 next loopcnt end sub '************************************************ sub center2 for count = 0 To 76 colour1(count) = 00 Next count sendLEDrnd for count3 = 1 to 6 for loopcnt = 0 to 6 read colour1(loopcnt) next loopcnt For count1 = 226 To 443 Step 6 count2 = 444 - count1 bufferRND(count1) = colour1(0) bufferRND(count1+1) = colour1(1) bufferRND(count1+2) = colour1(2) bufferRND(count1+3) = colour1(3) bufferRND(count1+4) = colour1(4) bufferRND(count1+5) = colour1(5) ' buffer0(count1+6) = colour(6) bufferRND(count2-1) = colour1(0) bufferRND(count2) = colour1(1) bufferRND(count2+1) = colour1(2) bufferRND(count2+2) = colour1(3) bufferRND(count2+3) = colour1(4) bufferRND(count2+4) = colour1(5) ' buffer0(count2+5) = colour(6) sendLEDrnd ' pause 5 next count1 next count3 for indexcount = 1 to 6 for loopcnt = 0 to 6 read colour1(loopcnt) next loopcnt For count1 = 449 To 225 Step -6 bufferRND(count1-5) = colour1(0) bufferRND(count1-4) = colour1(1) bufferRND(count1-3) = colour1(2) bufferRND(count1-2) = colour1(3) bufferRND(count1-1) = colour1(4) bufferRND(count1) = colour1(5) sendLEDrnd 'pause 5 next count1 for loopcnt = 0 to 6 read colour1(loopcnt) next loopcnt For count1 = 226 To 6 Step -6 bufferRND(count1-5) = colour1(0) bufferRND(count1-4) = colour1(1) bufferRND(count1-3) = colour1(2) bufferRND(count1-2) = colour1(3) bufferRND(count1-1) = colour1(4) bufferRND(count1) = colour1(5) sendLEDrnd 'Pause 5 next count1 Next indexcount For indexcount = 1 To 6 For loopcnt = 0 To 6 Read colour1(loopcnt) Next loopcnt For count1 = 0 To 225 Step 6 bufferRND(count1) = colour1(0) bufferRND(count1+1) = colour1(1) bufferRND(count1+2) = colour1(2) bufferRND(count1+3) = colour1(3) bufferRND(count1+4) = colour1(4) bufferRND(count1+5) = colour1(5) sendLEDrnd 'pause 5 Next count1 For loopcnt = 0 To 6 Read colour1(loopcnt) Next loopcnt For count1 = 225 To 443 Step 6 bufferRND(count1) = colour1(0) bufferRND(count1+1) = colour1(1) bufferRND(count1+2) = colour1(2) bufferRND(count1+3) = colour1(3) bufferRND(count1+4) = colour1(4) bufferRND(count1+5) = colour1(5) sendLEDrnd ' Pause 5 Next count1 Next indexcount end sub '*************************************************************************** sub flash1 For count = 0 To 149 'turn all leds OFF buffer0(count) = &h300000 next count For count = 0 To 149 'turn all leds OFF buffer1(count) = &h003000 next count For count = 0 To 149 'turn all leds OFF buffer2(count) = &h000030 Next count For count = 0 To 149 'turn all leds OFF buffer3(count) = &h301000 Next count rotate1 For count = 0 To 149'turn all leds OFF buffer0(count) = &h303000 next count For count = 0 To 149 'turn all leds OFF buffer1(count) = &h003030 next count For count = 0 To 149 'turn all leds OFF buffer2(count) = &h300030 Next count For count = 0 To 149 'turn all leds OFF buffer3(count) = &h303030 Next count rotate1 end sub '************* Rotate colours between arches ***************************** sub rotate1 '---------------------------------------------- for indexcount = 0 to 30 For count = 0 To 149 'turn all leds OFF tempbuff(count) = buffer0(count) next count For count = 0 To 149 'turn all leds OFF buffer0(count) = buffer1(count) next count For count = 0 To 149'turn all leds OFF buffer1(count) = buffer2(count) next count For count = 0 To 149 'turn all leds OFF buffer2(count) = buffer3(count) next count For count = 0 To 149 'turn all leds OFF buffer3(count) = tempbuff(count) next count pause 400 sendLED2 next indexcount for indexcount = 0 to 30 For count = 0 To 149 'turn all leds OFF tempbuff(count) = buffer3(count) next count For count = 0 To 149'turn all leds OFF buffer3(count) = buffer2(count) next count For count = 0 To 149 'turn all leds OFF buffer2(count) = buffer1(count) next count For count = 0 To 149 'turn all leds OFF buffer1(count) = buffer0(count) next count For count = 0 To 149 'turn all leds OFF buffer0(count) = tempbuff(count) next count pause 400 sendLED2 next indexcount end sub '*****************************TRANSFER LED DATA TO ALL ARRAYS*********************** sub sendLED for x = 0 to 149 Buffer1(x) = buffer0(x) Buffer2(x) = buffer0(x) Buffer3(x) = buffer0(x) next x sendLED2 end sub '*************************************OUTPUT ARRAY DATA TO LED STRIPS************************ sub sendLED2 Bitbang WS2812 B, GP5, LEDNum, buffer0() Bitbang WS2812 B, GP22, LEDNum, buffer1() Bitbang WS2812 B, GP11, LEDNum, buffer2() Bitbang WS2812 B, GP18, LEDNum, buffer3() end sub '*********************************** CONVERT ARRAY DATA TO HEX RGB 888 ************************* sub sendLEDrnd count = 0 for i = 0 to 450 step 3 WS2812.setcolour count, bufferRND(i), bufferRND(i+1), bufferRND(i+2) count = count + 1 if count > LEDNum then count = 0 endif next i sendled end sub '**************************************************************************************** sub WS2812.setcolour(led as integer, greenness as integer, redness as integer, blueness as integer) buffer0(led) = ((greenness and &HFF)<<16) + ((redness and &HFF)<<8) + (blueness and &HFF) end sub '*********************************** Hex Array Data ********************************** ' 1 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 1 to 10 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 '11 to 20 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 21 to 30 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 '31 to 40 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 41 to 50 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 ' 51 to 60 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 61 to 70 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 ' 71 to 80 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 81 to 90 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 ' 91 to 100 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 101 to 110 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 '111 to 120 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 121 to 130 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030 '131 to 140 Data &h000000,&h300000,&h000000,&h003000,&h000000,&h000030,&h000000,&h301000,&h000000,&h300030' 141 to 150 ' 2 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h003000,&h003000,&h003000,&h003000,&h003000,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h003000,&h003000,&h003000,&h003000,&h003000,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h003030,&h003030,&h003030,&h003030,&h003030,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h303000,&h303000,&h303000,&h303000,&h303000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h003000,&h003000,&h003000,&h003000,&h003000,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h000000,&h000000,&h000000,&h000000,&h000000 ' Data &h003030,&h003030,&h003030,&h003030,&h003030,&h000000,&h000000,&h000000,&h000000,&h000000' ' fading colours ' 3 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h300040,&h400040,&h400036,&h400033,&h400030,&h400026,&h400022,&h400018,&h400012,&h400008 Data &h400000,&h400200,&h400400,&h400600,&h400800,&h401000,&h401200,&h401400,&h401600,&h401800 Data &h402000,&h402200,&h402400,&h402600,&h402800,&h403000,&h403200,&h403400,&h403600,&h403800 Data &h404000,&h394000,&h384000,&h374000,&h364000,&h354000,&h344000,&h334000,&h324000,&h314000 ' Data &h304000,&h294000,&h284000,&h274000,&h264000,&h254000,&h244000,&h234000,&h224000,&h214000 ' Data &h204000,&h194000,&h184000,&h174000,&h164000,&h154000,&h144000,&h134000,&h124000,&h114000' Data &h104000,&h094000,&h084000,&h074000,&h064000,&h054000,&h044000,&h034000,&h024000,&h014000 ' Data &h004000,&h004001,&h004002,&h004003,&h004004,&h004005,&h004006,&h004007,&h004008,&h114009 ' Data &h004010,&h004011,&h004012,&h004013,&h004014,&h004015,&h004016,&h004017,&h004017,&h004018 ' Data &h004019,&h004020,&h004021,&h004022,&h004023,&h004024,&h004025,&h004026,&h004027,&h004028 ' Data &h004029,&h004030,&h004031,&h004032,&h004033,&h004034,&h004035,&h004036,&h004037,&h004038 ' Data &h003840,&h003840,&h003740,&h003640,&h003540,&h003440,&h003340,&h003240,&h003140,&h003040' Data &h002924,&h002826,&h002728,&h002630,&h002532,&h002434,&h002336,&h002238,&h002140,&h002040 ' Data &h001940,&h001840,&h001740,&h001640,&h001540,&h001440,&h001340,&h001240,&h001140,&h001040 ' Data &h000940,&h000840,&h000740,&h000640,&h000540,&h000440,&h000340,&h000240,&h000140,&h000040 '171 to 180 ' red white and blue - Flag ' 4 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030 Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030 ' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030 ' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000 ' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000 ' ' White background ' 5 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h010101,&h000031,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h003100,&h010101' 1 to 10 Data &h010101,&h010101,&h010101,&h010101,&h310101,&h010101,&h010101,&h010101,&h010101,&h003131 '11 to 20 Data &h010101,&h000031,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h003100,&h010101' 21 to 30 Data &h010101,&h010101,&h010101,&h010101,&h310101,&h010101,&h010101,&h010101,&h010101,&h003131 '31 to 40 Data &h010101,&h313131,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101' 41 to 50 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h313100,&h010101,&h010101,&h010101,&h010101 ' 51 to 60 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h310100,&h010101,&h010101' 61 to 70 Data &h010101,&h310031,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101 ' 71 to 80 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h003100,&h010101,&h010101,&h010101,&h010101' 81 to 90 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h000031,&h010101 ' 91 to 100 Data &h010101,&h010101,&h010101,&h310030,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101' 101 to 110 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101 '111 to 120 Data &h010101,&h010101,&h010101,&h010101,&h310000,&h010101,&h010101,&h010101,&h010101,&h010101' 121 to 130 Data &h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h010101,&h003131,&h010101,&h010101 '131 to 140 Data &h010101,&h010101,&h010101,&h010101,&h310000,&h010101,&h010101,&h010101,&h010101,&h010101' 141 to 150 ' 6 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h000000,&h300000,&h300000,&h300000' 1 to 10 Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h000000,&h300000,&h300000,&h300000 '11 to 20 Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h000000,&h300000,&h300000,&h300000' 21 to 30 Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' 31 to 40 Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030' 41 to 50 Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' 51 to 60 Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000' 61 to 70 Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000 ' 71 to 80 Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000' 81 to 90 Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000 ' 91 to 100 Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000' 101 to 110 Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000'111 to 120 Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030 '121 to 130 Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030' 131 to 140 Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030' 140 to 150 ' 7 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h010101,&h020202,&h050505,&h101010,&h151515,&h202020,&h252525,&h303030,&h353535,&h404040 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h010101,&h020202,&h050505,&h101010,&h151515,&h202020,&h252525,&h303030,&h353535,&h404040 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h010100,&h020200,&h050500,&h101000,&h151500,&h202000,&h252500,&h303000,&h353500,&h404000 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h010001,&h020002,&h050005,&h100010,&h150015,&h200020,&h250025,&h300030,&h350035,&h400040 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h010000,&h020000,&h050000,&h100000,&h150000,&h200000,&h250000,&h300000,&h350000,&h400000 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' Data &h000100,&h000200,&h000500,&h001000,&h001500,&h002000,&h002500,&h003000,&h003500,&h004000 ' Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000' 1 Data &h000001,&h000002,&h000005,&h000010,&h000015,&h000020,&h000025,&h000030,&h000035,&h000040 Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000 '171 to 180 ' 8 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000030,&h000030,&h000000,&h000000,&h003000,&h003000,&h000000,&h000000,&h300000,&h300000' Data &h000000,&h000000,&h301000,&h301000,&h000000,&h000000,&h300030,&h300030,&h000000,&h000000 ' Data &h000030,&h000030,&h000000,&h000000,&h003000,&h003000,&h000000,&h000000,&h300000,&h300000' Data &h000000,&h000000,&h301000,&h301000,&h000000,&h000000,&h300030,&h300030,&h000000,&h000000 ' Data &h003030,&h003030,&h000000,&h000000,&h303000,&h303000,&h000000,&h000000,&h303030,&h303030' Data &h000030,&h000030,&h000000,&h000000,&h003000,&h003000,&h000000,&h000000,&h300000,&h300000' Data &h000000,&h000000,&h301000,&h301000,&h000000,&h000000,&h300030,&h300030,&h000000,&h000000 ' Data &h003030,&h003030,&h000000,&h000000,&h303000,&h303000,&h000000,&h000000,&h303030,&h303030 ' Data &h000030,&h000030,&h000000,&h000000,&h003000,&h003000,&h000000,&h000000,&h300000,&h300000' Data &h000000,&h000000,&h301000,&h301000,&h000000,&h000000,&h300030,&h300030,&h000000,&h000000 ' Data &h003030,&h003030,&h000000,&h000000,&h303000,&h303000,&h000000,&h000000,&h303030,&h303030' Data &h000030,&h000030,&h000000,&h000000,&h003000,&h003000,&h000000,&h000000,&h300000,&h300000' Data &h000000,&h000000,&h301000,&h301000,&h000000,&h000000,&h300030,&h300030,&h000000,&h000000 ' Data &h003030,&h003030,&h000000,&h000000,&h303000,&h303000,&h000000,&h000000,&h303030,&h303030 ' Data &h003030,&h003030,&h000000,&h000000,&h303000,&h303000,&h000000,&h000000,&h303030,&h303030 '9 Data &h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030 ' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000' Data &h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030 ' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030 ' Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003003,&h003030,&h003030' Data &h303000,&h303000,&h303000,&h303000,&h303000,&h303000,&h303000,&h303000,&h303000,&h303000 ' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000' Data &h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030,&h001030 ' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030 ' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030 ' 10 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002' data &h000002,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002 ' Data &h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002' data &h000002,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002 ' Data &h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002' Data &h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002' data &h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002 ' Data &h000002,&h303030,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002 ' Data &h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002' data &h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002 ' Data &h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002 ' Data &h000002,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002' data &h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h303030,&h000002,&h000002 ' Data &h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h303030' Data &h000002,&h000002,&h303030,&h000002,&h000002,&h000002,&h000002,&h000002,&h000002,&h303030 ' 11 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h000040,&h000040,&h000040,&h000040,&h040040,&h080040,&h120040,&h140040,&h160040,&h200040 ' Data &h250040,&h300040,&h350040,&h400040,&h400035,&h400030,&h400025,&h400020,&h400016,&h400012 Data &h000040,&h000040,&h000040,&h000040,&h040040,&h080040,&h120040,&h140040,&h160040,&h200040 ' Data &h250040,&h300040,&h350040,&h400040,&h400035,&h400030,&h400025,&h400020,&h400016,&h400012 ' Data &h400008,&h400004,&h400000,&h400400,&h400800,&h401200,&h401400,&h401600,&h402000,&h402500 ' Data &h403000,&h403500,&h404000,&h354000,&h304000,&h254000,&h204000,&h164000,&h124000,&h084000 ' Data &h044000,&h004000,&h004005,&h004010,&h004014,&h004016,&h004020,&h004025,&h004030,&h004035 ' Data &h004040,&h003540,&h003040,&h002540,&h002040,&h001640,&h001240,&h000840,&h000440,&h000040 ' Data &h000040,&h000040,&h000040,&h000040,&h040040,&h080040,&h120040,&h140040,&h160040,&h200040 ' Data &h250040,&h300040,&h350040,&h400040,&h400035,&h400030,&h400025,&h400020,&h400016,&h400012 ' Data &h400008,&h400004,&h400000,&h400400,&h400800,&h401200,&h401400,&h401600,&h402000,&h402500 ' Data &h403000,&h403500,&h404000,&h354000,&h304000,&h254000,&h204000,&h164000,&h124000,&h084000 ' Data &h044000,&h004000,&h004005,&h004010,&h004014,&h004016,&h004020,&h004025,&h004030,&h004035 ' Data &h004040,&h003540,&h003040,&h002540,&h002040,&h001640,&h001240,&h000840,&h000440,&h000040 Data &h004040,&h003540,&h003040,&h002540,&h002040,&h001640,&h001240,&h000840,&h000440,&h000040 ' 7 |R G B| R G B |R G B| R G B| R G B| R G B| R G B| R G B| R G B| R G B| Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000' Data &h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000,&h300000 Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000' Data &h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000,&h003000 ' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030' Data &h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030,&h000030 ' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000' Data &h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000,&h301000 ' Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030' Data &h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030,&h003030' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030 ' Data &h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030,&h300030' Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030 Data &h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030,&h303030 Data &h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000,&h000000 '----------------------------------- integer Array data -------------------------------------------- '18| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,00,30,00,00,30,30,00,30,00,30,00,00,30,00,30,00,30,00,30,30,00,00,10,30,30,10,00 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 '18| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,30,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 '17 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,30,00,00,00,00,30,00,30,00,30,00,00,00,30,30,30,00,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 '18| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 '19 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,30,00,00,00,00,30,00,30,00,30,00,00,00,30,30,30,00,30' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 '20| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 '21 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 data 30,00,00,00,00,30,00,30,00,30,00,00,30,00,00,00,00,30,00,30,00,30,00,00,00,30,30,30,00,30' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 '22| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 '22| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 '22| B G R| B G R |B G R| B G R| B G R| B G R| B G R| B G R| B G R| B G R| data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 1 to 10 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 ' 11 to 20 data 30,30,00,30,30,00,00,30,30,00,30,30,30,00,30,30,00,30,00,30,00,00,30,00,00,10,30,00,10,30 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 11 to 20 data 30,00,00,00,00,30,00,30,00,30,00,00,00,00,30,00,30,00,30,30,00,00,30,30,30,00,30,30,30,30 ' 1 to 10 Bill Edited 2024-02-29 10:16 by Bill.b In the interests of the environment, this post has been constructed entirely from recycled electrons. |
