JAQForum Ver 20.06
Local Time 10:26 10 May 2024 Privacy Policy
Forum Index : Microcontroller and PC projects : How to intentionally crash MMBASIC on the PM....
Posted: 10:17pm 11 Mar 2024
  matherp said  The H/W watchdog will work in ALL circumstances. The test CSub did not disable interrupts so the S/W watchdog still worked. To test the H/W watchdog the CSUB needs to disable all interrupts. I can't think of a simple way of doing this from a CSub because you need to link the RP2040 sdk to get the register definition but I can guarantee the H/W watchdog WILL WORK in all circumstances
That was enough of a reply to convince me that if I use the HW watchdog in the 2040 chip, and NOT the software one, this SHOULD get me around the issue.
I still have no idea WHY the PM is crashing this badly, and it is only ONE unit out of fifty or so, all with the same code.  YES - have tried swapping out for a different PM module, but the same thing happens.
It's extremely odd.....
However, if I just use the 2040's hardware watchdog as a work-around, that will settle things down till I can work out what the hell is going on.
Edited 2024-03-12 08:19 by Grogster
stanleyella
Posted: 11:07pm 11 Mar 2024
dunno about crash but dim k
k=inkeys
error
mmedit still connects and says uploading(flashing code) and sits there.
power off/on sorts it
vga usb 00b5
© JAQ Software 2024
