Local Time 18:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Add days
Gerad
Posted: 02:16pm 12 Mar 2024
Hello Everybody
How can I add days? For example
Today's date (03/12/2024) plus 7 days equals (03/19/2024)
Who can help or give tips on where I can find information about this problem?
Thanks in advance
Posted: 03:23pm 12 Mar 2024
Hi Gerad,
Look at the n=Epoch(DateTime$) function. You change the date/time to a large integer number (seconds since xx), add the 7 days (in seconds), and convert back using DateTime$(n).
Edited 2024-03-13 01:23 by Volhout
Tip - look at the epoch function and the datetime$ function
Posted: 03:28pm 12 Mar 2024
The best way is to set a base date. Then you convert your date to the number of days since the base date. The next step is to add (or subtract) a number of days to (or from) your number of days. Then you convert the base date + resulting number of days to a new date.
It sounds like a long way round, but basically you need two functions:
Given a date, return the number of days since base date.
and
Given a number of days, return a date since the base date.
Your base date can be anything earlier than the earliest date you will need.
Beware of leap years!
This is how we used to do it. There are better ways now.
Edited 2024-03-13 01:29 by Mixtel90
Gerad
Posted: 04:39pm 12 Mar 2024
many thanks for your help
Gerad
cdeagle
Posted: 06:04pm 12 Mar 2024
' demo_dates.bas
' demonstrate date conversions
' March 2, 2017
print " "
print "program demo_dates - demonstrate date conversions"
print "================================================="
' request calendar date (month, day, year)
getdate(month1, day0, year1)
' request time (hours, minutes, seconds)
gettime(thr1, tmin1, tsec1)
' compute "complete" calendar day
day1 = day0 + thr1 / 24.0 + (tmin1 / 60.0) / 24.0 + (tsec1 / 3600.0) / 24.0
' compute corresponding Julian day
julian (month1, day1, year1, jday1)
' print results
print " "
print "convert calendar date and time to julian day"
print "--------------------------------------------"
print " "
print "calendar month = ", month1
print "calendar day   = ", day0
print "calendar year  = ", year1
print " "
print "time     = ", str$(thr1) + " hr " + str$(tmin1) + " min " + str$(tsec1, 0, 4) + " sec"
print " "
print "jday = ", str$(jday1, 0, 9)
print " "
print "convert Julian day to Gregorian date and time"
print "---------------------------------------------"
print " "
' compute calendar date
gdate (jday1, month2, day2, year2)
print " "
print "calendar month = ", month2
print "calendar day   = ", int(day2)
print "calendar year  = ", year2
print " "
thr0 = 24.0 * (day2 - int(day2))
thr2 = int(thr0)
tmin0 = 60.0 * (thr0 - thr2)
tmin2 = int(tmin1)
tsec2 = 60.0 * (tmin0 - tmin2)
print "time     = ", str$(thr2) + " hr " + str$(tmin2) + " min " + str$(tsec2, 0, 4) + " sec"
print " "
print "number of days between two dates"
print "--------------------------------"
print " "
print "first date"
getdate(month3, day3, year3)
julian (month3, day3, year3, jday3)
print " "
print "second date"
getdate(month4, day4, year4)
julian (month4, day4, year4, jday4)
delta_days = jday4 - jday3
print " "
print "number of days between dates = ", delta_days
print " "
end
sub julian (month, day, year, jday)
   ' Gregorian date to julian day subroutine
   ' input
   '  month = calendar month
   '  day   = calendar day
   '  year  = calendar year (all four digits)
   ' output
   '  jday = julian day
   ' special notes
   '  (1) calendar year must include all digits
   '  (2) will report October 5, 1582 to October 14, 1582
   '      as invalid calendar dates and exit
   y = year
   m = month
   b = 0.0
   c = 0.0
   if (m <= 2.0) then
      y = y - 1.0
      m = m + 12.0
   end if
   if (y < 0.0) then c = -0.75.0
   if (year < 1582.0) then
      ' null
   elseif (year > 1582.0) then
      a = fix(y / 100.0)
      b = 2.0 - a + fix(a / 4.0)
   elseif (month < 10.0) then
      ' null
   elseif (month > 10.0) then
      a = fix(y / 100.0)
   elseif (day <= 4.0) then
      ' null
   elseif (day > 14.0) then
      a = fix(y / 100.0)
   else
      print "this date does not exist!!"
      exit
   end if
   jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
   ' Julian day to Gregorian date subroutine
   ' input
   '  jday = julian day
   ' output
   z = fix(jday + 0.5)
   f = jday + 0.5 - z
   if (z < 2299161) then
      a = z
   else
      alpha = fix((z - 1867216.25) / 36524.25)
      a = z + 1.0 + alpha - fix(alpha / 4.0)
   end if
   b = a + 1524.0
   c = fix((b - 122.1) / 365.25)
   d = fix(365.25 * c)
   e = fix((b - d) / 30.6001)
   day = b - d - fix(30.6001 * e) + f
   if (e < 13.5) then
      month = e - 1.0
   else
      month = e - 13.0
   end if
   if (month > 2.5) then
      year = c - 4716.0
   else
      year = c - 4715.0
   end if
end sub
sub getdate (month, day, year)
   ' request calendar date subroutine
   do
      print " "
      print "please input the calendar date"
      print " "
      print "(month [1 - 12], day [1 - 31], year [yyyy])"
      print "< for example, october 21, 1986 is input as 10,21,1986 >"
      print "< b.c. dates are negative, a.d. dates are positive >"
      print "< the day of the month may also include a decimal part >"
      print " "
      input month, day, year
   loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub gettime (thr, tmin, tsec)
   ' request time subroutine
   do
      print " "
      print "please input the time"
      print " "
      print "(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])"
      print " "
      input thr, tmin, tsec
   loop until (thr >= 0.0 and thr <= 24.0 and tmin >= 0.0 and tmin <= 60.0 and tsec >= 0.0 and tsec <= 60.0)
end sub
barewires
Posted: 08:06pm 12 Mar 2024
Decades ago I used to type in Sky and Telescope magazine BASIC code for astronomy.
https://skyandtelescope.org/astronomy-resources/basic-programs-from-sky-telescope/
Simply remove the line numbers in a .CSV file and fix the gosub, goto and labels etc.
> run
Enter your birthday (M,D,Y)? 4,2,1950
Enter desired age in days ? 27008
You will be  27008 days old on  3 12 2024
Verify with:
https://www.timeanddate.com/date/durationresult.html?d1=02&m1=04&y1=1950&d2=&m2=&y2=
Rem DAYSOLD.BAS
Input "Enter your birthday (M,D,Y)";M,D,Y
Rem Compute Julian Day Number
J=-Int(7*(Int((M+9)/12)+Y)/4)
S=Sgn(M-9)
A=Abs(M-9)
J1=Int(Y+S*Int(A/7))
J1=-Int((Int(J1/100)+1)*3/4)
J=J+Int(275*M/9)+D+J1
J=J+1721028+367*Y
G110: Input "Enter desired age in days ";A9
If A9=0 Then G280
Rem Compute calendar date from new JD number
J2=J+A9+1
A1=Int((J2/36524.25)-51.12264)
A=J2+1+A1-Int(A1/4)
B=A+1524
C=Int((B/365.25)-0.3343)
D=Int(365.25*C)
E=Int((B-D)/30.61)
D=B-D-Int(30.61*E)
M=E-1
Y=C-4716
If E>13.5 Then M=M-12
If M<2.5 Then Y=Y+1
Print "You will be "; A9; " days old on " ;M;D;Y
GoTo G110
G280: End
Rem  ---------------------------
Rem  APPEARED IN COMPUTERS IN
Rem  ASTRONOMY, SKY & TELESCOPE,
Rem  NOVEMBER 2001, PAGE 63
Edited 2024-03-13 07:07 by barewires
barewires
Posted: 09:37pm 12 Mar 2024
https://skyandtelescope.org/wp-content/uploads/calendar.bas
Rem PERPETUAL GREGORIAN CALENDAR
Rem
Dim C$(42), D$(31), E(12)
For I=1 To 31: Read D$(I): Next I
For I=1 To 12: Read E(I):  Next I
Data "  1","  2","  3","  4","  5","  6","  7","  8","  9"," 10"
Data " 11"," 12"," 13"," 14"," 15"," 16"," 17"," 18"," 19"," 20"
Data " 21"," 22"," 23"," 24"," 25"," 26"," 27"," 28"," 29"," 30"," 31"
Data 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31
G28: Print :  Input "MONTH, YEAR";M,Y:  If Y<100 Then Y=Y+1900
Print :  Print " SU MO TU WE TH FR SA":  Print
J=367*Y-Int(7*(Y+Int((M+9)/12))/4)+Int(275*M/9)+1721031
K=0:  If M<=2 Then K=-1
J=J-Int(3*(Int((Y+K)/100)+1)/4)
K=E(M):  If M<>2 Then GoTo G48
W=Int(Y-100*Int(Y/100)):  X=Int(Y-4*Int(Y/4)):  Z=Int(Y-400*Int(Y/400))
If X<>0 Then GoTo G48
If W=0 And Z<>0 Then GoTo G48
K=29
G48: X=J-7*Int(J/7)
For I=1 To 42: C$(I)="   ":   Next I
For I=1 To K:  C$(I+X)=D$(I): Next I
For I=1 To 6:  J=7*I
Print C$(J-6);C$(J-5);C$(J-4);C$(J-3);C$(J-2);C$(J-1);C$(J)
Next I
Print :  Input "ANOTHER";A$:  If A$="Y" Then G28
End
Rem  ---------------------------------------------------------------
Rem  APPEARED IN ASTRONOMICAL COMPUTING, SKY & TELESCOPE, JULY, 1985
[CODE/]
Posted: 01:54am 13 Mar 2024
In most versions of MMBasic you can keep it simple:
 startDate$ = "02-04-1950"
 startDate$ = startDate$+" 00:00:00"
 DaysToAdd = 27008
 EndDate$= DATETIME$(EPOCH(startDate$) + DaysToAdd*86400)
 PRINT EndDate$
as suggested in the first two replies.
Edited 2024-03-13 11:55 by TassyJim
homa
Posted: 08:59pm 13 Mar 2024
great Jim
Matthias
Gerad
Posted: 09:18am 14 Mar 2024
Hello Jim,
thank you very much for the program example. It solved my little problem immediately.
Greetings to Australia.
I would also like to thank everyone else for their help
Gerad
CaptainBoing
Posted: 10:50am 14 Mar 2024
always check the libraries
https://tbsassist.com/wiki/doku.php?id=mmbasic:dateadd_function_vb_work_a_like
disco4now
Posted: 11:51am 14 Mar 2024
Hi Andrew,
Good to see you making a couple of posts.
The original fruitoftheshed.com domain was successfully transfer to the new site and registered for the next six years so will live on with its original URL.
https://fruitoftheshed.com/wiki/doku.php?id=mmbasic:dateadd_function_vb_work_a_like
Gerry
F4 H7FotSF4xGT
