Forum Index : Microcontroller and PC projects : New 4 inch LCD
Page 10 of 12 | |||||
Thanks I'll try that. Is the BL 3.3v only. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 911 |
Palcal the specs are very difficult to find but here is what I have found: There is a provision for a 3 terminal regulator cct. next to the backlight cct. but on the ones I have the regulator circuit is bridged out with a zero ohm resistor and the pads for the regulator are not populated. 0A47 |
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 1810 |
The whole panel is 3.3V only. The 3.3V regulator (U1) has not been fitted and is bypassed by a link (R0). The backlight anodes go to Vdd (Pin 1) via R1 (10Ω) and Q1 switches the cathodes to ground. The base goes to BL pin via R6 (1kΩ) and to ⏚ via R7 (10kΩ). The old 2.8" ILI9341 don't have Q1, the LED anodes go direct to LED pin and cathodes direct to ground so they require an external resistor to limit the current. I inadvertently plugged the 4" panel into a 5V board without any damage but SD cards are damaged by 5V, fortunately did not use one. To use the 4" panel on a board that has 5V on Vdd remove R0 and install U1 (3.3V LDO regulator). Edit. Followed my own advice, added a regulator as above. Now running on 5V. Edited 2024-04-10 11:52 by phil99 |
Thanks for all that will follow up. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
morgs67 Regular Member Joined: 10/07/2019 Location: AustraliaPosts: 71 |
@phil99 Thanks also, just ordered some suitable regulators. Tony |
@phil99 what regulator did you use. I have identified the IN pad one should be GROUND and one OUT, I cant identify the ground pad. Also I guess these displays can't be used with the MM BackPack because the PWM signal to the backlight is 5v. Edited 2024-04-10 14:23 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
The regulator was salvaged from a dead 2.8" panel and doesn't have a recognisable type number. Too small for that. Looking at the 4" panel with SD socket top left and connector pin 1 (Vdd) top right which goes to the middle (top) pin of the reg. Connector pin 2 ⏚ goes to bottom left of the reg. Bottom right of the reg. is 3.3V out and goes to C1 and R1. The 1kΩ base resistor of Q1 is high enough to allow 5V PWM. Just 4.4mA max at 5V. Edited 2024-04-10 15:14 by phil99 |
I've searched Element14 and RS Components but can't find any with the correct footprint. I have some SMD regs I can probably wire in somehow but would like to do it properly. @morgs67 what one did you order. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
It's taken me over an hour but I finally found one at RS components MCP 1754-3302CB its 150ma, should be ok. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 1654 |
I run all my ili panels from 5V and the led/bl my ils ili9488 board |
Modified my Pico backpack to supply display with 3.3v. The 4" display that stopped working on 5v. is now alive again and calibrates ok. Now to test on MM2 with 3.3v. On the MM2 the 3.5" screen won't calibrate I get Touch Hardware Failure after two targets and it won't calibrate on the Pico so maybe a display fault. So my 4" screens now work and calibrate on both Pico and MM2. Edited 2024-04-11 07:49 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Another oddity with the 4" IPS ILI9488. The resistors near the SD socket on other panels are in series with the SD pins (to protect the SD card in the event of 5V SPI data I guess) but on this panel they are all 4.7kΩ pull-ups. When the SD SPI is connected to the display SPI Blit, Save Image and Pixel(x,y) no longer work as the 10kΩ (or 6.8kΩ) from LCD_CS to MISO can no longer pull MISO low enough. The cure is to remove R8 from SDO. A possible alternative to removing R8 may be to reduce the 10kΩ to 1kΩ - 1.5kΩ to override it. Untested, may be too low for some SD cards. The pull-ups are another reason to take care not to apply 5V to this panel unless you fit a 3.3V regulator. @Palcal, yes also found the blotch eventually reappears. Edit. To check that MISO is reading all colours from the screen this one liner counts all the blues, greens and reds. For an ILI9488 there should be 64 of each. > for a=0 to 16 step 8:m=0:for n=0 to 255:q=n<<a:pixel 9,9,q:c=pixel(9,9):if c=q then:inc m :endif :next:?:?m:next 64 64 64 > Edited 2024-04-12 16:04 by phil99 Footnote added 2024-04-17 09:00 by phil99 Now tested. All the SD cards I have are happy with this so I suggest leaving R8 in place and using 1.5kΩ or 1.8kΩ for the LCD_CS to MISO resistor. |
Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 330 |
Phil, I connected the 4'' IPS with 10k and shottky diode: 1. Your oneliner did not work for me so I changed it into a short loaded program: for a=0 to 16 step 8 m=0 for n=0 to 255 q=n<<a:pixel 9,9,q:c=pixel(9,9) if c=q then:inc m endif next ? ?m next 2. Without removing R8 (4.7k pullup) from the display board the resulting output was 0 0 0. 3. Removed R8 and the output is 7 7 7. Tested with 133MHz and 420MHz CPUspeed with the same result. > option list PicoMite MMBasic Version 5.09.00RC3 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION LCDPANEL ILI9488, LANDSCAPE,GP15,GP14,GP13,GP17,INVERT OPTION TOUCH GP12,GP11 GUI CALIBRATE 0, 3902, 3845, -1284, -872 OPTION SDCARD GP22 SD works OK. Normal display output works OK. Any thoughts why I am not getting the desired 64 64 64 output from your test program? Pluto |
That combination has always worked for me in the past. Peter uses a 6.8kΩ. On a breadboard I just grabbed what was closest to hand, a 5.6kΩ and a 1N4001 and it worked giving 64, 64, 64. Also tried a 1N4148 which is faster and has a lower junction capacitance so should be a better choice. But instead it also gave 7, 7, 7. Makes no sense. All I can suggest is try a lower resistance and different diode, or perhaps a few pF across the diode. Maybe that is the key, the capacitance gives faster rise / fall times. Footnote added 2024-04-13 10:20 by phil99 As the one-liner was too long for Pluto's window here is a minimized version. If still too long the colours can be done separately. > for a=0to 2:b=0:for c=0to 255:d=c<<a*8:pixel 9,9,d:if d=pixel(9,9)then:inc b:endif:next:?b:next If still too long replace 64 64 64 > b=0:for c=0to 255:d=c<<16:pixel 9,9,d:if d=pixel(9,9)then:inc b:endif:next:?b 64 > b=0:for c=0to 255:d=c<<8:pixel 9,9,d:if d=pixel(9,9)then:inc b:endif:next:?b 64 > b=0:for c=0to 255:d=c:pixel 9,9,d:if d=pixel(9,9)then:inc b:endif:next:?b 64 > Pixel 9,9,d with CLS d But it is Extremely SLOW. |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8601 |
Probably makes no difference but I always use a BAT54 diode |
Diode BAT43 BAT43 1N4148 1N4002 Resistor 10k 6.8k 6.8k 6.8K Works? NO NO NO YES THANKS PHIL FOR THE HELP! Now it works. A standard rectifier diode 1N4002 and a 6.8k resistor gives 64 64 64 with your test program. I didn't test your capacitor proposal. Stopped soldering when I got it to work! Pluto |
Here is an LCD test program I have developed/used for some time. You configure the LCD and SDCARD and run the program. It was useful for finding obscure faults when developing drivers for parallel displays.(e.g. display would fail if all 16 bits transitioned between 0 ad 1 but ok if onlt 15 bits changed). Still gives an SPI a good workout. You look at results on screen and the printout to verify the result. Checks Backlight, RGB colour order, blit, save imaged, load image. Where a pixel is not as expected the actual vs expected result is printed. ? "--------------------------------------------------" ? "Connected to: " MM.DEVICE$ MM.VER ? "--------------------------------------------------" ? PAUSE 1000 'Program to verify LCDPanel read and write 'Writes a pixel to every point and reads it back to check 'Does a BLIT and check is still correct OPTION EXPLICIT OPTION DEFAULT NONE DIM INTEGER s,t, x, y, r, red, green, blue, c, b,i=0 DIM INTEGER x1,y1,la DIM INTEGER x2,y2,tp,hmax,vmax,shorttest DIM INTEGER pwr=0,pb=0,tx=0,ty=0,tbx=0,tby=0,tbt=0,pir=0,pirw=0,top,bottom DIM INTEGER pwre=0,pbe=0,txe=0,tye=0,tbxe=0,tbye=0,tbte=0,pire=0,pirwe=0 DIM INTEGER myWHITE,rgbWHITE,nearWHITE,rgbmask DIM INTEGER getscanlineSupported=1,blitsupport=1,backlightsupported=1 DIM INTEGER MMVRES,MMHRES,retry DIM ok$="" 'myWHITE=RGB(&HFF,&HFF,&HFF) myWHITE=RGB(&HF8,&HFC,&HF8) 'myWHITE=RGB(&HF8,&HF8,&HF8) 'myWHITE=RGB(&HF0,&HF8,&HF0) ''nearWHITE=RGB(&HF8,&HF0,&HF8) rgbWHITE=RGB(&HF8,&HFC,&HF8) 'rgbWHITE=RGB(&HFF,&HFF,&HFF) rgbmask=&HF8FCF8 DIM INTEGER MAXTESTS=1 'Number of times to repeat test DIM INTEGER MAXPRINT=20 'How many errors to output DIM INTEGER TESTCOUNT=0,TESTFAILED=0 TESTSTART: IF TESTCOUNT=MAXTESTS THEN ? vt100.colour$("GREEN"); ? "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!" ? "!!!! "+STR$(MAXTESTS,2)+ " tests completed !!!!" IF TESTFAILED>0 THEN ? vt100.colour$("RED"); ? "!!!! "+STR$(TESTFAILED,2)+ " tests Failed !!!!" ELSE ? vt100.colour$("GREEN"); ? "!!!! "+STR$(TESTFAILED,2)+ " tests Failed !!!!" ENDIF ? "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!" ? vt100.colour$("RESET") END ENDIF s=0:t=0:i=0 pwr=0:pb=0:tx=0:ty=0:tbx=0:tby=0:tbt=0:pir=0:pirw=0 pwre=0:pbe=0:txe=0:tye=0:tbxe=0:tbye=0:tbte=0:pire=0:pirwe=0 CLS ? vt100.colour$("HOME"):? vt100.colour$("CLS") 'if MM.INFO$(LCDPANEL)="ILI9341" then getscanlineSupported=0 'if MM.INFO$(LCDPANEL)="ILI9488" then getscanlineSupported=0 'if MM.INFO$(LCDPANEL)="ILI9481" then getscanlineSupported=0:blitsupport=0 'if MM.INFO$(LCDPANEL)="ILI9486" then getscanlineSupported=0 'if MM.INFO$(LCDPANEL)="ST7789" then getscanlineSupported=0:blitsupport=0 IF MM.INFO$(LCDPANEL)="SSD1963_4" THEN rgbmask=&HFFFFFF 'RGB888 IF MM.INFO$(LCDPANEL)="SSD1963_5ER" THEN rgbmask=&HFFFFFF 'RGB888 IF MM.INFO$(LCDPANEL)="SSD1963_5" THEN rgbmask=&HFFFFFF 'RGB888 IF MM.INFO$(LCDPANEL)="SSD1963_5A" THEN rgbmask=&HFFFFFF 'RGB888 IF LEFT$(MM.DEVICE$,4)="Pico" THEN IF MM.INFO$(LCDPANEL)="ILI9488" THEN rgbmask=&HFCFCFC 'RGB666 IF MM.INFO$(LCDPANEL)="ILI9481IPS" THEN rgbmask=&HFCFCFC 'RGB666 END IF retry=1 shorttest=1 IF shorttest=0 THEN vmax=MM.VRES-1 hmax=MM.HRES-1 ELSE vmax=99 hmax=99 ENDIF tp=(vmax+1)*(hmax+1) ? vt100.colour$("RESET") ? "LCDPANEL Integrity Test " ? "----------------------- " IF shorttest=0 THEN ? "Long Test - All pixels tested" ELSE ? "Short Test - 100*100 pixels tested" ENDIF ? MM.INFO$(LCDPANEL) '? MM.INFO$(LCDPANELID) 'Check for BLIT SUPPORT''''''''''''''''' ON ERROR SKIP 1 t = PIXEL(0,0) IF MM.ERRNO<>0 THEN blitsupport=0 ON ERROR CLEAR IF blitsupport=1 THEN ? "BLIT Supported" ELSE ? "BLIT NOT Supported"" END IF 'Check for BACKLIGHT SUPPORT''''''''''''''''' ON ERROR SKIP 1 BACKLIGHT 50 IF MM.ERRNO<>0 THEN backlightsupported=0 ON ERROR CLEAR IF backlightsupported=1 THEN ? "BACKLIGHT Supported" ELSE ? "BACKLIGHT NOT Supported" END IF 'Check for GETSCANLINE SUPPORT''''''''''''''''' ON ERROR SKIP 1 t = GETSCANLINE() IF MM.ERRNO<>0 THEN getscanlineSupported=0 ON ERROR CLEAR IF getscanlineSupported=1 THEN ? "getscanline{} Supported" ELSE ? "getscanline() NOT Supported" END IF '''''''''''''''''''''''''''''''''''''''''''' ? "TEST RGB colour order" CLS RGB(RED) TEXT MM.HRES/2,MM.VRES/2,"RED","CM",1,6,RGB(BLACK),RGB(RED) PAUSE 1000 CLS RGB(GREEN) TEXT MM.HRES/2,MM.VRES/2,"GREEN","CM",1,6,RGB(BLACK),RGB(GREEN) PAUSE 1000 CLS RGB(BLUE) TEXT MM.HRES/2,MM.VRES/2,"BLUE","CM",1,6,RGB(BLACK),RGB(BLUE) PAUSE 1000 CLS RGB(BLACK) TEXT MM.HRES/2,MM.VRES/4,"WHITE","CM",1,3,RGB(WHITE) TEXT MM.HRES/2,MM.VRES/2,"on","CM",1,3,RGB(WHITE) TEXT MM.HRES/2,3*MM.VRES/4,"BLACK","CM",1,3,RGB(WHITE) PAUSE 1000 IF backlightsupported=1 THEN ? "**************************************************" ? " BACKLIGHT TEST 10-100% " ? "**************************************************" ' CLS RGB(BLUE) FOR x=10 TO 100 STEP 10 BACKLIGHT x 'pause 500 '' TEXT MM.HRES/2,2.2*x,"BACKLIGHT "+str$(x),"CM",1,2,RGB(RED) '' TEXT MM.HRES/2,2.2*x,"BACKLIGHT "+str$(x),"CM",1,2,RGB(BLUE) TEXT MM.HRES/2,2.2*x,"BACKLIGHT "+STR$(x),"CM",1,2,RGB(WHITE) PAUSE 500 NEXT x BACKLIGHT 100 ENDIF ? "************************************" ? " Doing write to Pixels colour gradiant" ? " and then read of pixels." ? "************************************" ? "writing ",tp," pixels..." s=0:t=0:i=0 CLS TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax 'c=RGB((x1<<3 AND &HF8 )OR 5 ,((x1+y1)<<2 and &HFC) or 1 ,(y1<<3 and &HF8) or 2) c=RGB((x1<<3 AND &HF8 ) ,((x1+y1)<<2 AND &HFC) ,(y1<<3 AND &HF8) ) 'c=&H48 PIXEL x1,y1,c NEXT NEXT ? TIMER," mSec" IF blitsupport=1 THEN ? "reading ",tp," pixels..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 c=RGB(x1<<3 AND &HF8 ,(x1+y1)<<2 AND &HFC,y1<<3 AND &HF8) 'c=&H48 r=PIXEL (x1,y1) ' r=r and &HF8FFF8 c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels",t ? "total pixels",s+t IF t=0 THEN pwr=1 pwre=t ? ? "************************************" ? "Doing BLIT - blit 0,0,0,0,100,100" ? " and re read of pixels." ? "************************************" BLIT 0,0,100,100,100,100 'blit 100,100,200,200,100,100 'blit 200,200,300,300,100,100 BLIT 0,0,0,0,100,100 'blit 300,300,0,0,100,100 'blit read #1 ,0,0,100,100 'BLIT WRITE #1,0,0 'BLIT CLOSE #1 'for x1=0 to hmax 'for y1=0 to vmax ' PIXEL x1,y1,PIXEL (x1,y1) 'NEXT 'NEXT 'CLS RGB(RED) 'CLS rgb(green) 'CLS rgb(BLUE) s=0:t=0:i=0 ? "reading ",tp," pixels after blit ..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 c=RGB(x1<<3 AND &HF8,(x1+y1)<<2 AND &HFC,y1<<3 AND &HF8) 'c=&H48 r=PIXEL (x1,y1) c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN pb=1 pbe=t ENDIF '''end IF MM.INFO$(SDCARD)="Ready" THEN ? ? "************************************" ? "Doing SAVE IMAGE TEST.BMP ,0,0,100,100" ? "then RESTORE IMAGE TEST.BMP 0,0" ? " and re read of pixels." ? "************************************" IF blitsupport=1 THEN SAVE IMAGE "TEST.BMP", 0,0,100,100 ? "Image saved as TEST.BMP" ENDIF CLS PAUSE 2000 ? "Loading Image TEST.BMP" LOAD IMAGE "TEST.BMP" , 0,0 TEXT 20,150, "Image Loaded above" PAUSE 5000 s=0:t=0:i=0 IF blitsupport=1 THEN ? "reading ",tp," pixels after LOAD IMAGE ..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 c=RGB(x1<<3 AND &HF8,(x1+y1)<<2 AND &HFC,y1<<3 AND &HF8) r=PIXEL (x1,y1) c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN pirw=1 ON ERROR SKIP NAME "TEST.BMP" AS "REFERENCE.BMP" END IF pirwe=t ENDIF ENDIF IF MM.INFO$(SDCARD)="Ready" AND blitsupport=0 THEN ? ? "************************************" ? "Doing RESTORE IMAGE REFRENCE.BMP 0,0" ? "and read of pixels. " ? "************************************" CLS PAUSE 2000 ? "Loading Image REFERENCE.BMP" LOAD IMAGE "REFERENCE.BMP" , 0,0 TEXT 20,150, "Image Loaded above" PAUSE 5000 s=0:t=0:i=0 IF blitsupport=1 THEN ? "reading ",tp," pixels after LOAD IMAGE ..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 c=RGB(x1<<3 AND &HF8,(x1+y1)<<2 AND &HFC,y1<<3 AND &HF8) r=PIXEL (x1,y1) c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN pir=1 pire=t ENDIF ENDIF '****************************************************************************************** ? "----------------------" ? " All Bit transistion test" ? "change by X coordinate " ? "---------------------" ? "writing ",tp," pixels..." s=0:t=0:i=0 CLS TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax 'c=RGB((x1<<3 AND &HF8 )OR 5 ,((x1+y1)<<2 and &HFC) or 1 ,(y1<<3 and &HF8) or 2) IF x1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE 'if x1 mod 2 then c=RGB(RED) else c=RGB(GREEN) 'if x1 mod 2 then c=RGB(0,0,&h40) else c=RGB(255,255,&HBF) PIXEL x1,y1,c NEXT NEXT ? TIMER," mSec" IF blitsupport=1 THEN ? "reading ",tp," pixels..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 'c=RGB(x1<<3 AND &HF8 ,(x1+y1)<<2 and &HFC,y1<<3 and &HF8) IF x1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE 'if x1 mod 2 then c=RGB(RED) else c=RGB(GREEN) 'if x1 mod 2 then c=RGB(0,0,&h40) else c=RGB(255,255,&HBF) r=PIXEL (x1,y1) ' r=r and &HF8FFF8 c=c AND rgbmask 'if r<>c then r=PIXEL (x1,y1) 'reread IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror INC t ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels",t ? "total pixels",s+t ? IF t=0 THEN tx=1 txe=t ? "************************************" ? "Doing BLIT - blit 0,0,0,0,100,100" ? " and re read of Transition X pixels." ? "************************************" BLIT 0,0,100,100,100,100 BLIT 0,0,0,0,100,100 s=0:t=0:i=0 ? "reading ",tp," pixels after blit ..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 'c=RGB(x1<<3 AND &HF8,(x1+y1)<<2 and &HFC,y1<<3 and &HF8) IF x1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE 'if x1 mod 2 then c=RGB(RED) else c=RGB(GREEN) ' if x1 mod 2 then c=RGB(0,0,&h40) else c=RGB(255,255,&HBF) r=PIXEL (x1,y1) c=c AND rgbmask 'if r<>c then r=PIXEL (x1,y1) 'reread IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN tbx=1 tbxe=t ENDIF '********************************************************************************************************************* ? "************************************" ? "Bit transistion by Y test" ? " and re read of pixels." ? "************************************" ? "writing ",tp," pixels..." CLS s=0:t=0:i=0 TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax 'c=RGB((x1<<3 AND &HF8 )OR 5 ,((x1+y1)<<2 and &HFC) or 1 ,(y1<<3 and &HF8) or 2) IF y1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE PIXEL x1,y1,c NEXT NEXT ? TIMER," mSec" IF blitsupport=1 THEN ? "reading ",tp," pixels..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 'c=RGB(x1<<3 AND &HF8 ,(x1+y1)<<2 and &HFC,y1<<3 and &HF8) IF y1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE r=PIXEL (x1,y1) ' r=r and &HF8FFF8 'if r<>c then r=PIXEL (x1,y1) 'reread c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels",t ? "total pixels",s+t IF t=0 THEN ty=1 tye=t ? ? "************************************" ? "Doing BLIT - blit 0,0,0,0,100,100" ? " and re read of transition Y pixels." ? "************************************" BLIT 0,0,0,0,100,100 s=0:t=0:i=0 ? "reading ",tp," pixels after blit ..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 'c=RGB(x1<<3 AND &HF8,(x1+y1)<<2 and &HFC,y1<<3 and &HF8) IF y1 MOD 2 THEN c=RGB(BLACK) ELSE c=myWHITE r=PIXEL (x1,y1) 'if r<>c then r=PIXEL (x1,y1) 'reread c=c AND rgbmask IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "Pixels not read as written" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN tby=1 tbye=t ENDIF '********************************************************************************************************************* ? "************************************" ? "BLIT TEST OF BLACK ON WHITE TEXT" ? "************************************" ? "writing ",tp," pixels..." CLS s=0:t=0:i=0 TIMER=0 TEXT 1,20,"IMHO",,2,2,myWHITE,RGB(BLACK):TEXT 1,60,"IMHO",,2,2,RGB(BLACK),myWHITE PAUSE 1000 IF blitsupport=1 THEN BLIT 0,0,100,0,100,100 '? timer," mSec" ? "verifying TEXT",tp," pixels..." TIMER=0 FOR x1=0 TO hmax FOR y1=0 TO vmax i=i+1 c=PIXEL(x1+100,y1) r=PIXEL (x1,y1) IF r=c THEN s=s+1 ELSE IF t=0 THEN ? "TEXT Pixels not matched in BLIT area" IF t<maxprint THEN printerror t=t+1 ENDIF IF i>10000 THEN ? "."; i=0 ENDIF NEXT NEXT ? ? TIMER," mSec" ? "correct pixels ",s ? "incorrect pixels ",t ? "total pixels",s+t IF t=0 THEN tbt=1 tbte=t ENDIF '*************************************************************************************************************** IF getscanlineSupported=1 THEN ? "************************************" ? " Testing GETSCANLINE() Range " ? "************************************" CLS TEXT MM.HRES/2,(MM.VRES/2)-50,"testing ...","CM",1,3,RGB(WHITE) TEXT MM.HRES/2,MM.VRES/2,"testing ...","CM",1,3,RGB(RED) TEXT MM.HRES/2,(MM.VRES/2)+50,"testing ...","CM",1,3,RGB(WHITE) 'pause 3000 'getscanline() testing top=0 t=1000 bottom=1000 FOR s=1 TO MM.HRES*100 t=getscanline() top=MAX(t,top) bottom=MIN(t,bottom) NEXT s ENDIF CLS ? "**************************************************" ? " TRANSPARENT TEXT TEST " ? "**************************************************" MMVRES=MM.VRES MMHRES=MM.HRES POKE DISPLAY HRES 308 POKE DISPLAY VRES 108 CLS RGB(BLUE) POKE DISPLAY HRES MMHRES POKE DISPLAY VRES MMVRES BOX 0,0,300,100,,RGB(green),RGB(green) IF blitsupport=1 THEN TEXT 150,30,"TRANSPARENT",CM,2,2,RGB(RED),-1 TEXT 150,70,"TEXT",CM,2,2,RGB(RED),-1 ELSE TEXT 150,30,"TRANSPARENT",CM,2,2,RGB(RED),-1 TEXT 150,70,"NO SUPPORT",CM,2,2,RGB(RED),-1 ENDIF ? "******************************************" ? " TEST RESULTS " ? "********************************************" ? "DEVICE ",MM.DEVICE$ ? "LCDPANEL ",MM.INFO$(LCDPANEL) '? "LCDPANELID ",MM.INFO$(LCDPANELID) ? "Size ",MM.HRES,"x",MM.VRES 'if getscanlineSupported=1 then ' ? "LCD ID1 ",hex$(getscanline(1),2) ' ? "LCD ID2 ",hex$(getscanline(2),2) ' ? "LCD ID3 ",Hex$(getscanline(3),2) 'end if IF blitsupport=1 THEN IF pwr THEN ? vt100.colour$("GREEN")+"Pixel write/read by gradiant OK" ELSE ? vt100.colour$("RED")+"Pixel write/read by gradiant FAILED!!!!!!!!!! " +STR$(pwre) +" pixels" IF pb THEN ? vt100.colour$("GREEN")+"Pixel blit by gradiant OK" ELSE ? vt100.colour$("RED")+"Pixel blit by gradiant FAILED!!!!!!!!!!!! " +STR$(pbe) +" pixels" IF tx THEN ? vt100.colour$("GREEN")+"Pixel write/read for all bit X transition OK" ELSE ? vt100.colour$("RED")+"Pixel write/read for all bit X transition FAILED!!!!!!!!!! " +STR$(txe) +" pixels" IF tbx THEN ? vt100.colour$("GREEN")+"Pixel blit for all bit X transition OK" ELSE ? vt100.colour$("RED")+"Pixel blit for all bit X transition FAILED!!!!!!! " +STR$(tbxe) +" pixels" IF ty THEN ? vt100.colour$("GREEN")+"Pixel write/read for all bit Y transition OK" ELSE ? vt100.colour$("RED")+"Pixel write/read for all bit Y transition FAILED!!!!!!!!! " +STR$(tye) +" pixels" IF tby THEN ? vt100.colour$("GREEN")+"Pixel blit for all bit Y transition OK" ELSE ? vt100.colour$("RED")+"Pixel blit for all bit Y transition FAILED!!!!!!!!!! " +STR$(tbye) +" pixels" IF tbt THEN ? vt100.colour$("GREEN")+"TEXT blit for Black on White OK" ELSE ? vt100.colour$("RED")+"TEXT blit for Black on White FAILED!!!!!!!!!! " +STR$(tbte) +" pixels" ENDIF ? vt100.colour$("RESET") IF pir THEN IF blitsupport=1 THEN ? vt100.colour$("GREEN")+"LOAD IMAGE and test of pixels as loaded OK" ENDIF ELSE IF MM.INFO$(SDCARD)="Ready" THEN IF blitsupport=1 THEN IF pire>0 THEN ? vt100.colour$("RED")+"LOAD IMAGE and test pixels FAILED!!!!!!!!!!! " +STR$(pire) +" pixels" END IF ELSE ? vt100.colour$("MAGENTA")+"LOAD IMAGE Done - visually check it appear on screen" ENDIF ELSE ? vt100.colour$("YELLOW")+"LOAD IMAGE not TESTED - NO SDCARD" ENDIF ENDIF IF pirw THEN IF blitsupport=1 THEN ? vt100.colour$("GREEN")+"SAVE IMAGE then LOAD IMAGE and test of pixels as loaded OK" ENDIF ELSE IF MM.INFO$(SDCARD)="Ready" THEN IF blitsupport=1 THEN ? vt100.colour$("RED")+"SAVE IMAGE then LOAD IMAGE and test pixels FAILED!!!!!!!!!!! " +STR$(pirwe) +" pixels" ELSE ? vt100.colour$("MAGENTA")+"LOAD IMAGE OK - visually check it appears on screen" ENDIF ELSE ? vt100.colour$("YELLOW")+"SAVE IMAGE/LOAD IMAGE not TESTED - NO SDCARD" ENDIF ENDIF IF blitsupport=1 THEN ? vt100.colour$("MAGENTA")+"TRANSPARENT TEXT tested - Check on display if OK" ? vt100.colour$("YELLOW") ELSE ? "BLIT, TRANSPARENT TEXT and Read PIXEL() not supported on this LCDPANEL" ENDIF IF getscanlineSupported=1 THEN ? "GETSCANLINE() Range ",bottom,"-",top ELSE ? "GETSCANLINE() Not Supported on this display" ENDIF IF backlightSupported=1 THEN ? "Backlight Supported on this display " ELSE ? "Backlight Not Setup/Supported on this display" ENDIF '? "COM1 Baudrate ",BAUDRATE(1,1) '? "COM2 Baudrate ",BAUDRATE(2,1) '? "COM3 Baudrate ",BAUDRATE(3,1) '? "COM4 Baudrate ",BAUDRATE(4,1) '? "Battery Voltage ",PIN(BAT) '? "Battery Voltage ",PIN(BAT) '? "Battery Voltage ",PIN(BAT) 'OPTION VCC 3.3 'OPTION VCC 3.3 * PIN(SREF) / PIN(IREF) '? "**** AFTER VCC is adjusted ********" '? "Battery Volatge ",PIN(BAT) '? "Battery Volatge ",PIN(BAT) '? "Battery Volatge ",PIN(BAT) 'CLS TEXT MM.HRES/2,(MM.VRES/2)-20,"Complete","CM",1,4,RGB(WHITE) TEXT MM.HRES/2,(MM.VRES/2)+30,"Complete","CM",1,4,RGB(RED) TEXT MM.HRES/2,(MM.VRES/2)+80,"Complete","CM",1,4,RGB(WHITE) ? vt100.colour$("RESET") PAUSE 1000 POKE DISPLAY &H28 PAUSE 2000 POKE DISPLAY &H29 IF (pwre+pbe+txe+tye+tbxe+tbye+tbte+pire+pirwe=0) THEN INC TESTCOUNT GOTO TESTSTART ELSE ? vt100.colour$("RED") ? " !!!! test " + STR$(TESTCOUNT)+" Failed !!!" ? vt100.colour$("RESET") INC TESTFAILED INC TESTCOUNT GOTO TESTSTART END IF SUB printerror ? ? LEFT$(BIN$(c,24),8)+" "+MID$(BIN$(c,24),9,8)+" "+RIGHT$(BIN$(c,24),8)+" @ "+STR$(x1)+","+STR$(y1) ? LEFT$(BIN$(r,24),8)+" "+MID$(BIN$(r,24),9,8)+" "+RIGHT$(BIN$(r,24),8) IF retry THEN r=PIXEL (x1,y1) IF r=c THEN ok$=" OK" ELSE ok$="" ENDIF '? left$(BIN$(c,24),8)+" "+mid$(BIN$(c,24),9,8)+" "+right$(BIN$(c,24),8)+" ReDo "+str$(x1)+","+str$(y1) ? LEFT$(BIN$(r,24),8)+" "+MID$(BIN$(r,24),9,8)+" "+RIGHT$(BIN$(r,24),8)+" Retry "+ ok$ ENDIF END SUB '#Include "../vt100.inc" FUNCTION vt100$(s$) vt100$ = CHR$(27) + "[" + s$ END FUNCTION FUNCTION vt100.colour$(c$) SELECT CASE LCASE$(c$) CASE "black" : vt100.colour$ = vt100$("30m") CASE "red" : vt100.colour$ = vt100$("31m") CASE "green" : vt100.colour$ = vt100$("32m") CASE "yellow" : vt100.colour$ = vt100$("33m") CASE "blue" : vt100.colour$ = vt100$("34m") CASE "magenta", "purple" : vt100.colour$ = vt100$("35m") CASE "cyan" : vt100.colour$ = vt100$("36m") CASE "white" : vt100.colour$ = vt100$("37m") CASE "reset" : vt100.colour$ = vt100$("0m") CASE "cls" : vt100.colour$ = vt100$("2J") 'Clear Display CASE "home" : vt100.colour$ = vt100$("H") 'Home Cursor CASE ELSE : ERROR "Unknown VT100 colour: " + c$ END SELECT END FUNCTION -------------------------------------------------- Connected to: PicoMite 5.09 -------------------------------------------------- LCDPANEL Integrity Test ----------------------- Short Test - 100*100 pixels tested ILI9488 BLIT Supported BACKLIGHT NOT Supported getscanline() NOT Supported TEST RGB colour order ************************************ Doing write to Pixels colour gradiant and then read of pixels. ************************************ writing 10000 pixels... 2099.456 mSec reading 10000 pixels... 5350.002 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ Doing BLIT - blit 0,0,0,0,100,100 and re read of pixels. ************************************ reading 10000 pixels after blit ... 5557.038 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ Doing SAVE IMAGE TEST.BMP ,0,0,100,100 then RESTORE IMAGE TEST.BMP 0,0 and re read of pixels. ************************************ Image saved as TEST.BMP Loading Image TEST.BMP reading 10000 pixels after LOAD IMAGE ... 5361.411 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ---------------------- All Bit transistion test change by X coordinate --------------------- writing 10000 pixels... 1559.72 mSec reading 10000 pixels... 5088.771 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ Doing BLIT - blit 0,0,0,0,100,100 and re read of Transition X pixels. ************************************ reading 10000 pixels after blit ... 5097.605 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ Bit transistion by Y test and re read of pixels. ************************************ writing 10000 pixels... 1602.467 mSec reading 10000 pixels... 5334.488 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ Doing BLIT - blit 0,0,0,0,100,100 and re read of transition Y pixels. ************************************ reading 10000 pixels after blit ... 5079.353 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************ BLIT TEST OF BLACK ON WHITE TEXT ************************************ writing 10000 pixels... verifying TEXT 10000 pixels... 6242.066 mSec correct pixels 10000 incorrect pixels 0 total pixels 10000 ************************************************** TRANSPARENT TEXT TEST ************************************************** ****************************************** TEST RESULTS ******************************************** DEVICE PicoMite LCDPANEL ILI9488 Size 480 x 320 Pixel write/read by gradiant OK Pixel blit by gradiant OK Pixel write/read for all bit X transition OK Pixel blit for all bit X transition OK Pixel write/read for all bit Y transition OK Pixel blit for all bit Y transition OK TEXT blit for Black on White OK SAVE IMAGE then LOAD IMAGE and test of pixels as loaded OK TRANSPARENT TEXT tested - Check on display if OK GETSCANLINE() Not Supported on this display Backlight Not Setup/Supported on this display !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! 1 tests completed !!!! !!!! 0 tests Failed !!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! > > Latest F4 Latest H7 |
Nice test For the ILI9488 set whites to &HFCFCFC and the same with the mask AND turn console mode off |
I use the same board for ili9488 and ips ili9488 with 10K resistor and in5818 diode no other mods and both displays work fine. maybe I was lucky. |
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3573 |
The 1N5819 has 100 pf capacitance. That may actually work better. But you also may have been lucky. Volhout Edited 2024-04-13 04:20 by Volhout PicomiteVGA PETSCII ROBOTS |
Page 10 of 12 |
