Local Time 02:23 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IC tube packing
zeitfest
Posted: 03:09am 23 Mar 2024
Buying ics -  some years ago some arrived in tubes with an antistatic packing strip keeping the ic's from rattling around, a fairly robust and conductive black foam strip approx 6 mm wide and maybe2  mlllimeter or so thick, looks like a carbon black/polymer/rubber material. I think they have been replaced with conductive tube material now.
As it happens those strips were very useful !!! Anyone know suppliers ?
vegipete
Posted: 04:13am 23 Mar 2024
Look for "Desco 12250" ESD protective foam.
oh3gdo
Posted: 05:50am 23 Mar 2024
I do not where you can buy these strips, but I do why they were used.
I was working in Nokia Capacitor Factory in Tampere Finland at years 1974 to 1985.
At two first years the ICs were very fragile, they went broke quite easily, if you have not grounded.
Every package of ICs were filled the strips.
But about year 1986 every IC start to to last.
I do not to use grounding wires when I was touching the circuits.
The manufacturers has found the similar problem and found a solution to it.
They have added a zener diode to power supply and it was a good solution.
Posted: 07:51am 23 Mar 2024
  vegipete said  Look for "Desco 12250" ESD protective foam.
Wow!!!  AU$172.50 for one sheet.
zeitfest
Posted: 12:23pm 24 Mar 2024
Yes thats a bit expensive !!
I was after the tape/strip format instead of sheet, I suspect it is all overpriced  though.
PhenixRising
Posted: 09:05am 25 Mar 2024
Is this the same thing?
Posted: 12:33pm 25 Mar 2024
If it is, the price is much better!
zeitfest
Posted: 12:48am 27 Mar 2024
Yes it looks like the substance is the same thing, but in bulk ..maybe it can be sliced into strips
