Forum Index : Microcontroller and PC projects : Anyone familiar with the Dorji DRF4432D radio modules?
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5182 |
Hi Guys. I bought a couple Dorji RF transceiver modules for a rover - PC telemetry project, but I cant work them out. The datasheets are lacking, they usually show the wrong board and the setup mode instructions just dont work. If I connect the two modules to a pair of USB-Serial converters, and fire up a couple serial terminals, I do get data transfer in both directions, but its misinterpreted. For example, if I type ABC in one terminal, I get Ph( in the other, and visa versa. I've set these up using their default factory settings, I cant change these settings until a DAC13 board arrives ( apparently you need that to program them ). I think I'm missing something obvious, anyone been down this path? https://www.wiltronics.com.au/product/7622/dorji-drf4432d20-a-443mhz-20dbm-ism-rf-transceiver-module/ Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3292 |
The data sheet says RS232 interface so serial TTL may need to be inverted. I think a MM2 MX170 can invert the TTL, though that might only be the console. A pair of logic inverters might work as it doesn't seem to require both + and - signal voltages of full RS232. Edited 2024-03-28 14:35 by phil99 Footnote added 2024-03-28 15:40 by phil99 MM2 V5.05.05 manual p88 has info on inverting COM1 for RS232. |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 209 |
Ignore my last - stick with the above led Edited 2024-03-28 14:39 by led-bloon Miss you George |
Hi Glenn, I assume you have the user manual of these modules. The PC program to set them up ? Does "ABC" always translate to "Ph(" ? If that is the case the unit may be defaulted to a odd baudrate. Simple way to check is to connect an oscilloscope to the receiving end TX pin (output) and measure the shortest pulse comming out. That is the baudrate. I remember something like ESP chips that used an odd baudrate until you programmed them to the correct baudrate. Maybe this is something similar. DRF4432D20.zip According this you can simply attach a USB-UART-TTL (FTDI/CH340/2102) interface, and run their DRM tool to configure the units. Volhout Edited 2024-03-28 17:23 by Volhout PicomiteVGA PETSCII ROBOTS |
Yeah thanks for the file but thats another manual that doesn't match the module. In that manual its a different board, and has a SetA and SetB pins, I only have a Set pin. Using the factory baud rate. I cant program them yet ( using the software ) as I'm waiting on the programmer board. The suggested "short pin Set to ground" seams to put the device into programming mode ( both TxRx leds on ), but it wont respond to commands at all. So hoping the programming board can work. This is becoming one of those modules where I should have spent a little more money and bought something thats known to work, wasted way to much time on these. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
OK, progress. Found a 4049 hex inverter, and if I invert both Tx and Rx on both modules, they are talking english Thanks Phil.If I short the set pin to ground, it sends out the model number and version, but wont go any further, I cant edit the settings using the AA FA commands. Will keep tinkering. Glenn Footnote added 2024-03-28 18:49 by Gizmo More success. The software for programming the modules works now. I can change the settings, dont need the DAC13 board. Man these things need better documentation. Thanks for the help guys. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Well this was a waste of time. Once I got the two modules talking to each other, I built a couple transistor inverters for each module, mounted on on the rover and the other in a jiffy box so I could plug it into my laptops USB socket. FYI, I'm using Ardurover firmware and a flight computer on the rover, and Mission Planner on the PC. These two will talk using the modules. In the past I used a couple ESP01 modules to create a wifi connection and send serial data that way. It worked, but was range limited. So, once I built the new hardware and started testing, I had to fiddle with the settings to get a reliable connection. Ended up with a radio serial speed of 38.4 and a module to PC/FC speed to 19.2, that was the best option with a minimal packet drops. Rover was talking to PC, and visa versa. All the rover data was streaming down to the PC just fine. Next I went to arm the rover ( via Mission Planner software ), and it froze. Only a power cycle of the module at the PC end would restore it. After a couple hours testing, googling, and reading signals with the cro, I discovered the module ( PC end ) would freeze up if it was getting to much data from the PC. If I connected with a serial terminal program, I could see all the data streaming down from the rover, and I could type a few letters on the keyboard, all good. But if I typed really fast, or held a key down, it would freeze up solid. Power cycle, all good. The module has a RF Rx and Tx led, the Rx led would keep flashing as data was coming in, but none of it was getting sent out the serial port. Basically, I think the onboard CPU had a sissy fit and stopped working. Time to cut my losses and abandon these modules, they have issues. Going back to the wifi connection. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
My experience with the mission planner and arduino mega based navigation module was similar. There is abundant data exchange and you need to sustain that bandwidth. For model airplanes they have special high power (in Europe illegal) data link systems. And the ardupilot software cannot simply minimize the data exchange. It is more or less ON or OFF. Wifi offers this bandwidth. Volhout PicomiteVGA PETSCII ROBOTS |
