Local Time 17:12 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PH and EC measurement with Webmite?
Gerad
Posted: 10:36am 30 Mar 2024
Hello
Does anyone have experience with PH measurement?
and/or EC measurement with Webmite?
Or know where I can find information?
THX
Gerad
NPHighview
Posted: 03:11pm 30 Mar 2024
Greetings, Gerad -
Is this the sort of thing you're looking for?
https://circuitdigest.com/microcontroller-projects/arduino-ph-meter discusses obtaining pH.
https://www.electroniclinic.com/arduino-hydroponics-diy-hydroponics-system-using-ph-sensor-ec-sensor-hydroponic/ discusses obtaining both pH and EC
You will need to substitute "WebMite" and "PicoBasic" for "Arduino", but the approach should be very similar.
Gerad
Posted: 07:20pm 30 Mar 2024
Hello NPHighview
Thanks for your tip
I will try with micropython or circuitpython.
regards
gerad
NPHighview
Posted: 03:30pm 31 Mar 2024
You don't have to do that! <<shudder!>> Just use the same circuitry, and pattern your code after their examples.
stanleyella
Posted: 04:40pm 31 Mar 2024
I bought this ph tester and it works but don't know how?? no batteries.
Posted: 05:29pm 31 Mar 2024
Chemistry. 2 different metal electrodes, acid, creates a voltage. That is how lead acid batteries work.
zeitfest
Posted: 11:54am 01 Apr 2024
This diy meter  may b worth a try...I was going to build the older version using a INA116 as was suggested, but didn't get to it. You will still have to read the 140mv output, and get the special glass+counter electrode combo as well. Precise work will need calibrations etc
stanleyella
Posted: 01:47pm 01 Apr 2024
  Volhout said  Chemistry. 2 different metal electrodes, acid, creates a voltage. That is how lead acid batteries work.
lead acid is one metal.
search 2 dissimilar metals
Posted: 01:57pm 01 Apr 2024
It's a single metal if the battery is flat. When charged one electrode is lead and the other is lead oxide. The electrolyte is then concentrated sulphuric acid.
A better example might have been a piece of copper wire and a zinc-plated nail stuck in a lemon. It's a very simple primary cell. The voltage will depend to some extent on how strong the lemon juice is. You can try copper and zinc in various electrolytes to see the change.
stanleyella
Posted: 03:38pm 01 Apr 2024
  Mixtel90 said  It's a single metal if the battery is flat. When charged one electrode is lead and the other is lead oxide. The electrolyte is then concentrated sulphuric acid.
I think it's lead peroxide
hydrogen peroxide h2o2
hydrogen oxide h2o
Posted: 03:56pm 01 Apr 2024
Sorry, it's lead dioxide. :)
stanleyella
Posted: 04:44pm 01 Apr 2024
and it's not concentrated h2so4 but drop this, who cares :)
Posted: 06:28pm 01 Apr 2024
Well, it becomes more concentrated as the battery charges and that changes the specific gravity rather conveniently, but yeah, lets. :)
zeitfest
Posted: 10:24pm 01 Apr 2024
The electrodes look like copper and another metal. It might be a so-called "Clarke cell", using an antimony/oxide electrode. It was cheap and used for measuring oxygen levels, but depended strongly on pH, temperature, etc and had poor results.
Edited 2024-04-02 08:25 by zeitfest
