Local Time 05:51 18 Jun 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Questions ESP01
Posted: 03:30pm 28 Oct 2024
Here's an ESP32-C3Supermini flashed with Annex receiving serial messages from the PC and sending the message along to the PC via UDP, and also receiving UDP messages from the PC and passing them along to the PC via serial:
' passthru.bas
port=54321
serial2.mode 9600,8,7
udp.begin port
onUDP UDPRx
onSerial2 SerRx
wait
UDPRx:
 pause 500
 msg$=udp.read$
 udp.reply "ACK "+msg$ ' optional reply
 print2 msg$
 wlog "UDP msg: "+msg$
 return
SerRx:
 pause 500 ' allow time for Rx to arrive
 msg$=serial2.input$
 if msg$<>"" then
   udp.write "192.168.2.237", port, msg$
   wlog "serial msg: "+msg$
 endif
 return
On the PC, the lower right window is TeraTerm, from which serial data is sent to and received from the ESP. The upper right window shows the command for sending a UDP message from the "DOS prompt". The middle right window shows a "DOS" UDP listener.
The PC is a stand-in for a PicoMite or CMM2 or any other micro which does not have net connectivity.
The UDP sender optionally gets an "ACK" back. The serial sender could also (but doesn't in this program).
SERIAL2 is used instead of SERIAL so that system messages are not injected.
Of course, there is a world of additional things Annex can do for that device (including telling it what the date and time is.)
Edited 2024-10-29 01:32 by lizby
© JAQ Software 2025
