Forum Index : Microcontroller and PC projects : Long string on a PicoMite
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5182 |
I'm sure this has been covered before, but searching was hopless ( maybe I should fix that ). Long string on the PicoMite. I did find the C subroutines for longer string uploaded by matherp, but these didnt work on the Pico ( memory invalid address errors ). Is there an alternative or a library, or is it just a case of breaking a stream of string data into small chunks and processing them that way? Its for reading NMEA gps data, I need a bit more functionality than the built in GPS functions in PicoMite. Thanks Glenn Edited 2024-05-06 19:03 by Gizmo The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Check the manual for the LONGSTRING commands and functions. The CSUBs you reference are all built-in as fully worked commands |
Hi Glenn, I may be misunderstanding the question but the PicoMite has LONGSTRING support built in (equivalent to the old C subroutines), RTFM as it were .Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Snap .MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Argh! Thanks. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Picomite is a miracle.. Volhout PicomiteVGA PETSCII ROBOTS |
