Forum Index : Microcontroller and PC projects : Teraterm filename change
| Chrisk Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 137 |
Hi all Can I change the filename of a file stored on the SD card using Teraterm and what is the syntax if possible. Ta Chris K |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3291 |
on picomite.... Volhout PicomiteVGA PETSCII ROBOTS |
Thanks guys |
