Forum Index : Microcontroller and PC projects : Checking for Sprites being hidden or displayed?
| MarkF Regular Member Joined: 01/08/2023 Location: AustraliaPosts: 49 |
Hi all. Is there any command that allows to check if a sprite is hidden or being displayed? I have a complex graphic screen with multiple sprites moving around. Occasionally, my program will unexpectedly exit with an "sprite already hidden" error. It would be great to check if a sprite is already hidden, before executing the Sprite hide command. |
Hi MarkF, I don't know of any command that you can use for this purpose. Since sprites do not hide autonomously, it is the code that hides the sprite. So keep track of the sprites visibility in an array "visible%(nbr_of_sprites)". When writing a sprite, set the cell to 1, when hiding it, set the cell to 0. Volhout PicomiteVGA PETSCII ROBOTS |
You can use the sprite function with X or Y. They return 10000 if the sprite is not being displayed Edited 2024-05-16 19:18 by matherp |
Thank you Volhout and Mather for your recommendations. As you mentioned this is a good solution.... SPRITE(X, [#]n) Returns the X-coordinate of sprite n. This function is only active when the sprite is currently displayed (active). Returns 10000 otherwise. |
